FixYa.com
Tags:
Sony PSYC ZS-D55 Cassette/CD Boombox
Auto-stop malfunction and stuck cassette door (by 2 users)
posted by Kiraragnar on Apr 28, 2007
My Sony ZS-D55 is two years old and has been used in a clean environment with batteries only. It has recently begun clicking at the end of a fast-forward or rewind action, and sometimes shuts off, sometimes not (as if auto-stop is trying, but failing). Yesterday, it decided not to release the tape-drive path machinery and will not do anything but click three times, and, accordingly, the cassette door will not open.
Meanwhile, a rented audio-book cassette seems to have found a comfortable new home with a lock on the door!
Comment by Kiraragnar, posted on May 05, 2007
Thank you, Fairlane, for your help. I tried removing all power (batts and ac) for a couple of days, and when I reinserted the batteries and pressed "power," the cassette door opened and released the trapped tape. I think you are right on the slipping drive belt: it occurs only during FF and RW, not during play, and I have ordered a factory manual to assist in checking/swapping the appropriate belt.
I appreciate your time and expertise!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by sudha_vinod, posted on Dec 28, 2007
My Sony zs-d55,s CD player stopped functioning first. It would start spinning and THEN STOP. NOW THERE IS A CLICKING SOUND if i try to play a tape. The radio alone works now. Its so upsetting as i bought it on a trip to America and i cant find anybody to repair it for me here. They say the lens is the problem and charge me for a new lens, but i still seem to have the same problem.
Best Solution
posted on May 02, 2007
Helpful (85)
fairlane
Rank:Wiz Wiz
Rating: 88%, 356 votes
Hi
I'm not familiar with your particular model, but the auto stop problem is common and is usually the result of a slipping drive belt, or bad idler/reel drive. The auto-stop works by popping a small tooth like plastic or nylon piece attached to an arm, when you runout of tape and takeup reel pulls the tape tight. The auto-stop mech can get contaminated with dust, and not work, or the reel for some reason does not pull the tape tight enough to fully engage that piece and the result is a ticking sound.
As the deck now has your tape, I suspect the main drive belt is broken or probably slipping, and all will work fine if it is replaced.
Although changing the belt is not difficult, you should probably take it to a repair shop, as getting the right size is important, and the deck may have to be dismantled to change it.
Hope this helps, good luck!
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Boomboxes problems?
Boomboxes
Boombox radio plays but cd...
my radio on my insignia boombox... Answer This...
Boomboxes
Circuit Diagram
The above music system was... Answer This...
Boomboxes
owners manual
I have a fisher boombox model... Answer This...
Boomboxes
Panasonic SA-AK57 stereo...
Stereo is on for a while, then... Answer This...
It wont turn on
My Sony ZS-D55 all over sudden... Answer This...
Repair Service
Find Boomboxe Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
