Question about Jenn-Air JED8430 Electric Cooktop
Did the element fail, or the switch, or the harness?
Both sections of the dual element (front right) stopped working simultaneously. How can I tell whether the problem is in the element, or in the switch, or in the harness?
  • 135 Answers
Buying and learning to use an ohmmeter is best. You can also inspect both the harness and the burner for damage. If nothing is burnt or broken, then you probably need the switch. Hope this helps!
Posted on Jan 01, 2009
I have intermittent problem with two of the four rings - sometimes they work sometimes they don't
see this causes and proceed for fix it. God bless you
Surface Element Switch If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
Surface Element Board If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
Coil Surface Element If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
Radiant Surface Element The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
Solid Surface Element If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
Terminal Block If a surface element won't work, there may be a problem at the terminal block. The appliance has a power cord which is attached to a terminal block. Over time, the connections at the terminal block can fail and burn open. When this happens, normally all of the surface elements won't work. The solution is to replace any burned wires and replace the terminal block.
Loose or Burnt Wire Connection If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
Incoming Power Problem Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
Oct 02, 2012 | Neff Cooktops
Large burner elements ignite, and igniter spark fails to stop, then the burner shuts off as if ignition failed. Tiny central burner element does NOT light at any time. Apparently the safety cutoff...
There is a thermistor that must be in the flame area that needs to get hot. When hot it will turn the igniter off and keep the flame on. Check it's location and if it is in the flame then it needs to be replaced. not sure about the central flame problem. could be the switch.
Sep 20, 2010 | Gaggenau 36 in. KG 291 Dual (Electric &...
My Jenn AirCooktop Model CVE3401 burner problems
The part you need to replace is the switch. The switch is housed under the top and connects to the dial you are turning.
The switch for the dual burner is 12002125, and 74011242 for the single burner.
The single burner switch runs about $20.00 and the dual runs about $50.00 for the parts
Apr 24, 2010 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Right front burner fails to heat (at all) Jenn air
I suspect a faulty element or electrical connection to the element.
Mar 21, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Control for dual element has to be wiggled just so -so to shut element off, what do I need to fix it? Heats perfectly, shutting it off is my only problem.
The control you're wiggling (infinite switch)needs replacement. Model# and the position of the dual element (right or left, rear or front) is needed to get the part number.
Mar 03, 2010 | Cooktops
The dual element does not hold at medium heat.
repl the sw / not a uncommon repair .. mm . element is ok .. sw's are geting better ..
Dec 06, 2009 | Amana 29 in. ACC4370 Electric Cooktop
Power to elements
not fuse issue, but it does sound like one ofhe burner switches has gone bad, only recieving half power, and sinceall the sawitches are linked together, when oyou turn on lanother it grabs power form there, i would expect it to be an issue with the expandable( dual )infinite switch.. most likely cause
Mar 17, 2009 | Cooktops
JEC9530, dual element burner(right front) does not work the light does come on, the burner does not and the knob has play in it.
This coulb be either the switch or the burner. Either can be tested with an ohmmeter if you can read the wiring diagram. Hope this helps!
Feb 26, 2009 | Jenn-Air JEC9530 Electric Cooktop
COOKTOP
its been my experience that the dual burner switch is far more likely the culprit, unless you can physiclaly see the outer ring is broken( visual inspection works wonders. as far as trying to ohm out i generally look at theelemnet itself (4 wires lead to the elemnt you can trace 1 to the outer portion of element, and 1 to the inner portion.WITH POWER OFF Iswithc those 2 wires and the restore power try element ad watch for outer ring to work inner ring no good. now i know its the switch not sending power. reset wires and order new switch
Mar 08, 2008 | Cooktops
Stove problem - outer cirlcle of an expandable element not working
You will need to call a professional these are very complicated and not easy to service, there are no fuses either. It will most likely be the element itself that has failed and they are not cheap. It also could be the switch too however it will take a person very familiar with schematics to properly diagnose it. Or you could just replace the element and switch yourself and that would most likely solve it.
Dec 26, 2007 | Cooktops
Jenn-Air JED8430 Electric Cooktop Logo
142 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
