A thermostat is a switch. It connects 24vac from one terminal to another depending on the request. The 24vac comes from a transformer, usually located in the furnace and connects to the R terminal. Since you are using RH and RC without a jumper between it means there are two transformers, one in the furnace for heating (RH) and one in the air conditioner condenser used for cooling (RC).
Your old thermostat was probably mechanical and did not have a C (24vac common) terminal. Your new thermostat requires power to operate therefore needs a wire connected to a C terminal. I would get rid of the transformer you added and look for an unused wire in the bunch at the thermostat. If it's there connect it to C on the thermostat and to C on the furnace. Remove any jumper from R to RC or from RH to RC depending on your thermostat and connect wires same as the old thermostat.
Just means you havent installed Asus Express Gate on to the Primary HDD.
If you're not going to use it and want to get rid of the message. Go to
your Bios setup. Go to the last tab, and disable Express gate.
RC 7 = Reserved for future use (found in use on protected screener copies of MPAA-related DVDs and "media copies" of pre-releases in Asia)
RC 8 = International venues such as aircraft, cruise ships, etc.[1]
RC ALL means all 8 flags are set and can play on ANY player
0 or no region means no flag is set can be played anywhere or flags 1-6.
Hi, An E1 error message usually indicates that the thermistor (see the following link) is defective and needs to be replaced. http://www.appliance411.com/data.php?rc=548392 pls rate my suggestion...
B means "blower" in the antique language of the tradesmen, but nowadays it means "reversing valve". RC means "red cool" or "put 24 volts here to power the cooling system".
The blue wire was not connected to RC because it would not bring 24 volts to the RC terminal.
