Question about Sharp AL-1641CS Laser Digital Copier
My Sharp AL-1641cs thinks it has a paper jam.
My sharp AL-1641cs had a paper jam that I cleared. It still thinks that the paper is jammed. What do I do to clear its mind.
  • 15,935 Answers
Http://www.sharpusa.com/files/cop_man_AL1641CS_1631.pdf
Manual
Please start at page 63, and follow the guide.
You may think you have gotten all the papers out, but it indicates the 3 areas in which to check. There is no manual reset.
Posted on Dec 29, 2008
  • 2,386 Answers
You need to turn it off and turn on again. it will clear its memory.
but first clear all paper jams first.
    Novelist:
  • 163 Answers
Is there any error display on the screen?
Tip
Sharp AL-1641CS Scanner Manual Download
Free Sharp AL-1641CS Scanner Manual Download
Models: Sharp AL-1632 / Sharp AL-1641CS
Would you like to review the features of the Sharp AL-1641CS Scanner?
Have you lost your Sharp AL-1641CS Scanner Owner's Guide?
Would you like a free digital, searchable, pdf version of the Sharp AL-1641CS Scanner Manual?
Follow this link
(& click FREE) to download a pdf version of the Sharp AL-1641CS scanner documentation.
I hope that helps.
___________________________________________________
on Jul 24, 2010 | Office Equipment & Supplies
Tip
Sharp AL-1641CS Copier Manual Download
Free Sharp AL-1641CS Copier Manual Download
Would you like to review the features of the Sharp AL-1641CS Copier?
Have you lost your Sharp AL-1641CS Copier Owner's Guide?
Would you like a free digital, searchable, pdf version of the Sharp AL-1641CS Copier Manual?
Follow this link
(& click FREE) to download a pdf version of the Sharp AL-1641CS Copier documentation.
I hope that helps.
"P" is blinking in display Sharp AL-1641cs
There is a small white gear that drives the fuser module. It wears out at 30 to 40 thousand pages.
If the sound is a jumping to gringing noise that would be the problem.
That gear jumping will cause the machine to say out of paper,, jam,, give all kinds of problems from things bouncing around.
Aug 02, 2010 | Sharp AL-1641CS Laser Digital Copier
Tip
Follow this link
I hope that helps.
on Jul 24, 2010 | Sharp AL-1641CS Laser Digital Copier
Need to reset the drum counter on the AL 1740 sharp while changing to a used drum
Entering in the simulation mode:press Clear - Interrupt - 0 - Interrupt -Main code - Start -Subcode - Start.
When the clear all key is pressed the simulation mode is cancelled.When the interrupt key is pressed,the proces is interrupted and the screen returns to the subcode entering display.After cancelling the simulation mode be sure to turn OFF/ON the power and check the operation.
Main code 20 subcode 1 =Maintenance counter clear.
Main code 21 subcode 1 =Maintenance cycle settimg
subcode 2 =Mini maintenance cycle setting.
Maincode 22 subcode 1 = Maintenance counter display
subcode 2=Maintenance preset value display
subcode 3=Jam memory display
subcode4=Total jam counter display
subcode 5=Total counter display
subcode 6=Developing counter display
subcode 7=Developing preset counter value display
subcode 9=Paper feed counter display
subcode 12=Drum counter display
Maincode 24 subcode 1 =Jam counter clear
subcode 2=Trouble memory clear
subcode 7=Drum counter clear
subcode 8=Copy counter clear
Maincode 26 subcode 22=Language setting
Maincode 42 subcode 1=Developing counter clear
Maincode 43 subcode 1=Fusing temperature setting
Maincode 46 subcode 1=Copy density level adjustment
subcode 19 AE mode picture quality change
Nov 20, 2009 | Sharp AL-1641CS Laser Digital Copier
Paper misfeed indicator light continues to blink even after paper
some machines will want all covers to be opened, then closed, for good reset. if you are having jams in the adf, then open all adf covers, and lift the adf upward, if it allows. also, try turning unit off, then back on. some jams only clear that way.
Apr 02, 2009 | Sharp AL-1641CS Laser Digital Copier
Papaerjam lite stays on, no paper jam
It is possible that there may still be a small piece of paper blocking or lodged in the exit sensor area. It is also possible that when removing the jammed paper that the sensor arm became dislodged and thus creating a false jam code.
Jun 25, 2008 | Sharp AL-1641CS All-In-One Laser Printer
Sharp al 1655 false paper jam message,
Check that the paper feed roller is clean as if the roller slips it causes a late paper pickup jam but nothing will be in there also maybe a small torn piece in the machine some where. and check the fuser make sure that is it not stuck in there if no to all these then is will need a control board.
Thanks J
Nov 17, 2007 | Sharp AL-1655CS Laser Printer
Sharp AL-1641CS Laser Digital Copier Logo
82 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
