Question about Cuisinart DCC-2000
DCC-2000 the water reservoir does not empty completely. how to resolve?
  • Anonymous Sep 15, 2008
    my pot is not dumping the water, serial no #710190. This is a replacement pot that you sent me. My original pot had to be replaced within less than 8 months of date of purchase and now the replacement is doing the same thing.
    Thanks for your help
    this is my 2nd request!
My reservoir does not empty completely and since I use a variety of different coffee flavors I just flush out my coffee pot with water
until clear (never empty fully as a tefelon type of coating in the
reservoir) and just leave any clear water in. This solved my problem. Also elimated any leakage by lifting the lid and drying it
off with a dish towel as the water doesn't flow down the small opening and also dry on the back of the coffee pot to stop this
moisture. I love mine especially since there is never a "burn taste"
and it does keep the coffee pot hot. Clean mine every 3 months and put it in new filter.
Posted on Mar 06, 2009
    Problem Solver:
  • 14 Answers
Wow, I can see your question is very old. Do you still own your machine and if so have you resolved your problem with it? I would contact Cuisinart Warranty at 1-800-726-0190 and ask them what they can do for you. There is a limited three year warranty on the unit from the day you purchased it.
Coffeediva22
Posted on Jan 14, 2008
Cuisinart dcc 3000..set to self clean and nothing is happening? Both the cleaning light and power light are on. How long does the cleaning process take or is there something wrong with the coffee maker.
Press the "CLEAN" button and it will light up red. Then press the "ON/OFF" button which will light up blue. Be patient, nothing happens right away, but the cycle has begun. In a few minutes the water reservoir will begin to empty. This self-clean/decalcification process takes approximately 30 minutes. Then pour the water/white vinegar solution out of the coffee reservoir, rinse the water and coffee reservoirs and run one cycle of fresh cold water through before using to brew coffee.
Sep 17, 2013 | Conair DCC-3000 - Cuisinart Coffee on...
We've had a Cuisinart DCC-2000 coffee maker for less than a year: 1) it stops brewing about halfway through the brewing cycle (with plenty of water still in the reservoir, and 2) the "Clean" light
This problem is caused by a clogged water filter in the unit.
Unplug the coffee maker.
Open the top panel where you normally pour in the water and set the coffee filter.
Gently pull up on the tap that sticks up in the back left corner of the open top. This will free a long plastic part that has a compartment at the bottom that contains a filter filled with charcoal.
Unsnap the small compartment that holds the filter and clean it gently under running water with light brushing.
If there is a lot of coffee build-up, the water chamber where you normally pour in fresh water needs to be cleaned out. Pour in a cup of water and invert the unit over a large sink pouring out the water through the opening you normally use to fill the unit.
Repeat this until you remove the coffee grounds.
Let the unit dry fully before plugging in to run again.
Sep 30, 2012 | Cuisinart DCC-1200 Coffee Maker
Need to clean cuisinart 12 cup coffee on demand coffe pot. How do I clean?
Do you have the DCC-2000?
To delime a multi-cup coffee maker, mix white vinegar with water (1/3 vinegar and 2/3 water) and fill the water reservoir completely. Then turn the coffee maker on. Wait until the unit completes the "brewing" cycle and beeps 5 times. Turn off the coffee maker. Discard the liquid after the cycle. Then fill the reservoir with clean water and turn on again. When this cycle completes, again discard the liquid. Repeat the water rinse if you notice an odd taste to the coffee afterwards. (If the coffee maker still has deposits, repeat the vinegar cleaning cycle and rinse cycles.) There are commercial deliming products, mix them with water following the package directions.
The manual for the DCC-2000 is available as a link here: http://www.cuisinart.com/products/coffee_bar/dcc-2000.html . The direct link to the manual is http://www.cuisinart.com/share/pdf/manuals/dcc-2000.pdf .
I hope this helps.
Jun 19, 2011 | Vacuums
I have lost by cleaning manual for my dcc-1200 coffee maker. I need to clean it the light won't shut off. Thanks, Dawn Miller
Fill water reservoir with 1/3 carafe distilled white vinegar, 2/3 carafe water and hit the self-clean button - it will take about 35 mins to complete. When it is done, it will beep like it normally does when brewing regular coffee. Self-clean light should go off after this. If it doesn't, simply unplug the machine for 20 minutes or longer. The manual is available for your inspection on the Cuisinart website.
Sep 07, 2009 | Cuisinart DCC-1200 Coffee Maker
DC2000 Cuisinart Coffee On Demand will not brew
on my dcc2000 when brewing on automatic timer it only brews a part of the reservoir . Say 2 or 3 cups out of the 6 I fill to.
Apr 14, 2009 | Cuisinart DCC-2000
Coffee leaks after it is brewed
The water reservoir on this mdoel is very close to the coffee reservoir - if excess water gets between the wall of the coffeemaker and the coffee reservoir, it will leak exactly as you described. Make sure no water spills out of the water reservoir when your pour it.
-Tha Mp3 doctor
Nov 23, 2008 | Cuisinart DCC-2000
One year old coffee maker won't brew
I had the same problem, only this happened on the last 3 dcc-2000 I purchased. I called customer service today, and they informed me that there is a 3 year warranty on this product. Wow... This time they really helped. I have made 2 phone calls to customer service, and was put on hold for over 20min. each time they found out what machine I was calling about. Call customer service, and don't give up!
the number is 1-800-726-0190. you will need the serial # from the bottom of the unit (stamped in) and the model #.
good luck! Bob
Mar 30, 2008 | Cuisinart DCC-2000
Cuisinart Coffe Maker has no power
vinegar is not the best thing descaler vinegar remove calciumin little piece that might block thr rest of machine descaler produit melt calcium 1 part solution 1 part water fill the water tank start machine leave it running for few second turn off for 15 minute and repeat untill empty dont forget to rince the machine very good that stuff is very corosif but does the jobs thanks for using fixya pierre
Feb 09, 2008 | Cuisinart DCC-1200 Coffee Maker
Water won't move from reservoir/showerhead to carafe
You can try cleaning the unit first and if that doesn't work you can contact Cuisinart Warranty at 1-800-726-0190 and see what they can do for you. Do you have the original user manual that came with the machine?
As per my book on my unit (DCC-2000) you can try decalcifying the unit. I have never had any problems with that, but I use filtered water all the time and that may be the reason mine is working very well (except leak) after 18 months of age.
Per user manual....
Decalcification refers to removing the calcium deposits which form over time on the metal parts of the coffeemaker.
For best performance from your coffeemaker, decalcify the base unit from time to time. The frequency depends upon the hardness of the tap water and how often you use the coffeemaker.
To clean, fill the water reservoir to capacity with a mixture of 1/3 white vinegar and 2/3 water. Turn the coffeemaker on by turning the ON/OFF knob. One cycle should be sufficient to adequately clean the coffeemaker. When the cycle is completed and the five beeps sound, turn coffeemaker off. Repeat operation, this time using fresh cold water.
Good luck and I hope this helps your problem.
Coffeediva22
Jan 05, 2008 | Cuisinart DCC-2000
Reservoir will not empty completely
I had the same problem I used straight vinegar. I just poured it into the coffee maker and let it run through the cycle after it was done then I poured plain water and ran it through it That seemed to help my problem. I hope this helps
Apr 28, 2007 | Cuisinart DCC-2000
Coffee Makers & Espresso Machines Logo
171 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
