Question about Microtek ScanMaker X6 Flatbed Scanner
Anyway to make the epp version work without a printer port?
I have the Microted X6 scanner with the epp port. I now have a computer that does not have a printer/parallel port. Is there any convenient way to get this scanner to work at a reasonable cost?
I have thought about getting PCI IEEE 1284 card an puting in my computer. I have tried the usb to IEEE 1284 cable, doesn't work.
Any suggestions or should I just through my hands up and get a new scanner? I also have the medium sized light box that goes with it. That is why I hate to give it up.
Thanks for any help you may offer...
2 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Connecting a scanner
Hi, Based on your post/description, I will assume that your scanner then is X6 EPP and that: 1. you have the original CD installer or downloaded the 3 .exe files from http://support.microtek.com/downloads/drv_specific.phtml?cnntn=a&x=21&y=20&slct_os=8&step=2&prod=87&bymdlnme=1&drvgrp=87 2. you followed the instruction in your manual or at http://support.microtek.com/tech_faqs_stp.phtml?request=FAQ-PCDI&point=KB-00003#stepbystep and still "...the "test connection" says there is no connection..." A possible workaround: Power off and reboot, on restart hit del, F2 or whatever it is that will allow you to go to BIOS. In the BIOS setup, look for the "Parallel Port Mode", you might have several choices are ECP, SPP, EPP, ECP + EPP; select EPP, save, exit, reboot. Try your scanner. If this doesn't work, try the ECP + EPP or the others (might as well). If still a no go, double check that you have the right drivers for the right Windows. Hope this be of help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Posted on Aug 29, 2007
sunluvinbum
  • 62 Answers
SOURCE: Microtek Scanmaker X6EL
Yes you can still use the scanner. The beauty of todays technology is that there are adapters for everything. You can get a SCSI to USB adapter for just a few dollars at most best buy stores.
Posted on Apr 29, 2008
HELP PLS THE cartridge of my printer EPSON STYLUS T10 IS NOT RUNNING THE RED LIGHT IS BLINKING...
First try printing with the printer directly connected to the computer without any switchbox, Zip drive, scanner or any other parallel port device connected to the same port. If this is the problem then install a second parallel card for LPT2.
Make sure to use a printer cable no longer than 6 feet.
Next make sure your hard disk has a minimum of 30 - 50MB contiguous space available to spool the data to be printed. Run Scandisk to make sure there are no cross linked files and then run Defrag to see if your hard disk needs to be defragmented.
Your computer's parallel port must be set up properly for your printer.
* Check how LPT1 is set in your computer's CMOS/BIOS setup. It should be set to either Standard (SPP), Normal, or Compatible (contact your computer manufacturer/vendor if necessary).
* Check how LPT1 is set in Windows 95. If set to ECP Printer Port, you should change it to Standard Printer Port. An ECP or EPP port seems to cause some communication problems and out of paper messages.
Use the following steps to change the port type:
1. Click on Start
2. Go to Settings
3. Choose Control Panel
4. Double click on System
5. Click on the Device Manager tab
6. Double click on "Ports (COM & LPT)"
7. Click on the Printer Port (LPTx) to highlight
8. Click on Properties
9. Click on Driver tab.
10. Click on Change Driver
11. Click on Show All Devices
12. Click on Printer Port (not ECP) under the Standard Port Type for the manufacturer
13. Click on OK until you get out of the System Properties
14. Reboot Computer
Dec 08, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Cannot communicate with printer. Told to Turn
Restart your computer.
Press <DEL> to enter BIOS SETUP.
Find the setup-screen that changes the mode of the printer (PP/"Parallel Port" or EPP/"Extended Parallel Port", or ECP/"Enhanced Port"). Select EPP or ECP.
Then, 'SAVE' the updated BIOS settings,
and exit from BIOS SETUP.
The box will _not_ be "grey".
May 14, 2010 | Canon PIXMA iP3300 InkJet Photo Printer
I try to scan a document and it says that I am not set up on pc. I use just the scan button and it still won't scan. Help please!!!
Verify cables connected properly to the back of the scanner
If the scanner is a parallel port scanner it is likely it has two available connections on the back of the scanner. Verify that the cable coming from the computer is connecting to the IN, Computer IN, computer, or similar connection.
Ensure that the scanner is getting power
If your scanner is not getting power it is recommended that you check the connections ensuring that they are connected properly to the back of the computer and from the scanner to the wall. If you have the scanner connected to a power strip and or surge protector it is temporarily recommended that you connect the scanner directly to the wall.
If the computer scanner is getting power, you should notice the inside light come on when the power is first received by the scanner.
After checking the connections you still get no power to the scanner, it is recommended you contact the manufacturer of the scanner.
Additional parallel port scanner troubleshooting
If you have another device connected in between the scanner and the computer, turn off the computer and temporally disconnect the devices connected to or from the scanner. If, after disconnecting these devices, the scanner works, it is likely that another device may have issues or may be unable to work with other parallel devices.
PC Windows users verify no TSRs are running in the background
Press CTRL + ALT + DEL and end task all currently running software except explorer and systray and attempt to scan again. If this resolves your issue it's a possibility that an application in the background such as a virus utility is preventing your scanner from scanning.
Verify the LPT port mode
PC users ensure that the LPT port mode within the computer BIOS is set to either EPP or bi-directional mode and/or try alternating between these two modes.
Update the drivers
Verify that the latest drivers are installed for the operating system being used on your computer. A listing of computer scanner manufacturers and links to the drivers pages can be found on our scanner drivers page.
Nov 19, 2009 | HP LaserJet 3055 All-In-One Printer
I have an Hp Pavillion a170n System by can't
Go to Printers . Put curser over the Printer icon . Press Right button on mouse . Go to bottom of meue PROPERTIES> when open at top menue selct ports. Configure port. other approach deleat printer and reinstall new printer. during set up will ask what port. USB sometimes uses virtual printing Ports. Another aproach is if USB ..Just pull cable from computer and stick in some other USB port forcing computer to reload driver to that port.
Nov 07, 2009 | HP Pavilion a1700n PC Desktop
I am unable to "enable bidirectional communication" with my AIO 966
Is it connected via a parallel port? If so, then you need to change the parallel port type in your computer's BIOS Setup to EPP or ECP type; Windows will register the new port type and you should be able to establish a bi-di connection.
BTW, does it not work without this bi-directional connection? The only thing you lose is some fancy stuff like ink levels monitoring etc.
Oct 30, 2009 | Dell Photo 964 All-In-One InkJet Printer
XP Cannot able to print on Epson LX 300+
This is XP's parallel port problem
try changing the settings:
find: Start Button, Control panel, System
Device Manager, then Ports !
Change the settings for LPT1 to enable
Detection of Legacy Plug and Play devices
o and Here is the service manual for this printer:
http://ca.geocities.com/artiedc/LX300SvcMan.pdf
Ed
May 25, 2009 | Epson LX-300 Matrix Printer
Can't scan documents
For the system to work completely; you need the print driver, scan driver and smarthru4.
Once you install the scan driver (available on Samsung website); the issue will go away.
Also, another trick; instead of using the smart thru - which is kind of awkward, download Picasa 3 and if you have installed the scan driver correctly, you can use Picasa to import the scans by controlling the printer. It also allws for some other tweaks that are not so easy to get to in Smart Thru.
In addition to Picasa you can use several other graphic applications to scan the image.
Good luck.
Jul 31, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Software and driver
You should be able to download the proper drivers for your Operating System directly from Microtek:
http://www.microtek.com/
Since you didn't tell us which country you're located in, or which OS you're using, I can't provide any more specific information for you...
The Download page is located here, for users in the US:
From what I could determine, the X6 model was discontinued some time ago, and there were at least THREE versions of it; you'll have to find it listed under the Product Category in the Discontinued Products section, then choose the version (parallel port / EPP, SCSI, or USB), in order to download the driver you need. Seems that the SCSI version has drivers ONLY for Apple computers; if you're using Windows, you'll need to choose one of the other options...
Jan 27, 2008 | Microtek ScanMaker X6 Flatbed Scanner
Lx 300+ detected by xp but test page fails
hello,
please go to bios setting and change parallel port type spp+epp or epp or normal try to change type and try again.
Oct 14, 2007 | Epson LX-300 Matrix Printer
Aug 29, 2007 | Microtek ScanMaker X6EL Flatbed Scanner
Open Questions:
Microtek ScanMaker X6 Flatbed Scanner Logo
Top Microtek Office Equipment & Supplies Experts
Tony
shelmnot
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
