Question about Acer Aspire 5101WLMi Notebook
Mouse Pad is not working
Hello I have a gateway 250x laptop and my mouse pad is not working the pointer is stuck in the middle of the screen. Any help???
  • timsoos123 Dec 29, 2008
    Yes as soon as it Boots.
  • djxtreme979
    djxtreme979 May 11, 2010
    Does this happen right away after it boots up?
  • 151 Answers
Did this start happening right after a change in the system? IE: a new installation or update. Reboot pc and tap f2 while it is starting. That should get you to safemode. While there uninstall and new software you added. If you did not install anything new, still go to safe mode and post again what you see.
Posted on Dec 29, 2008
Gateway HDMI laptop T series charger output 19 vgets v.hotbut works . burser pointer starts jumping frm place to place on screen dificult to control ?
run it in battery to see if fixes cursor problem
also try a different mouse see if that makes the cursor move correctly
this way you see if its the mouse or power supply
might also a touch pad problem anything that controls the cursor
May 07, 2015 | Gateway Computers & Internet
Gateway Pointer Unresponsive
To troubleshoot this problem, first you must get a USB mouse and connect it to the laptop. Now, there are various laptop that have the ability to deactivate the pad control, it's different for every laptop, so you should check on the keyboard if you see anything that resemble the mouse pad. If it does, press it. There also could be a driver problem, just in case re-download the drivers by going to the Gateway website and click on the support tab. Just follow the instructions on the website. You should have an icon at the bottom right of your screen, where the date, battery, etc... are. Right click the mouse pad icon (if any) and check your options. If you need more help I'll be more than glad to help you out, but I'll be needing more info as to the laptop. Best of luck.
Jun 19, 2013 | Computers & Internet
Gateway Laptop with windows 8. Mouse pointer gone and won't come back
See if the mouse pad has been accidentally turned off. This can be done via the "Function" button on your Gateway laptop. To enable your mouse clicker again on your Gateway, head on over to the "Control Menu" in Windows and double-click on the "Control Panel" icon. Click on the "Mouse" option under the "Printers and Other Hardwareicon1.png" tab. In the next menu that pops up, click on the tab listed as "Device Settings." From this menu, you should be able to locate a listing for the mouse pad on your Gateway laptop. Click on this listing. From here, you should be able to enable the mouse again. Click "OK."
  • Head over to the official Gateway site online (see Resources). The above enabling of the mouse device under "Device Settings" may not have worked. Make your way to the "Software and Drivers" area of the site.
  • Check over your Gateway manual and find your specific serial number for your machine. Enter the number into the Gateway site when prompted and check to see if any driver updates exist for your mouse on your machine. If so, click to download the update, and then double-click the file on your computericon1.png to install it. Restart your Gateway laptop to have the changes take place. Your mouse should now work.
  • Jan 26, 2013 | Gateway Ne56r34u 15.6inch Laptop Black
    My touch scroll stopped working for my Gateway NV53A. Can I fix it?
    1_9_2013_6_10_09_am.jpeg check it first , by , connect a mouse , go control panel disable it , and use mouse ,turn the notebook , turn on & enable it , may be works , other wise hardware problem.
    Jan 09, 2013 | Gateway Computers & Internet
    Gateway nv5 mouse pad frozen in the middle of screen.
    Return the laptop to the place of purchase, the sensor pad has failed, or device driver issue.
    Apr 16, 2012 | Gateway NV5384u Laptop
    Mouse stopped working on Compaq Presario CQ57
    The Touch pads the Mouse Pointer uses is pressure sensitive and sometimes without warning WILL fail to work I own a CQ50 And Have a On Off Option for the mouse pad Yours does not Apparently it Is a bad sensor If you have a warranty send it in If not best suggestion for you is buy a USB mouse and use it Otherwise trying to have it replaced without a warranty can be costly.
    Feb 03, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
    Acer aspire lap top mouse not working arrow stuck in middle of screen
    try restart your laptop first..if the pointer doesn't move still, check the sensing pad status by pressing Fn button together with the mouse logo button on your keyboard.what's the model name of your acer laptop if you dont mind?
    Dec 28, 2010 | Acer Computers & Internet
    Pointer stuck in middle of screen on my acer laptop,Help!!
    Are you using a mouse or the touch pad? Make sure the touch pad is turned on.
    Jan 06, 2010 | Acer Aspire 5100 Notebook
    Cursor stuck in middle of screen
    If you are using an external mouse, unplug it and see if it will go with the pad.If it works with the pad then its the exteranal mouse.
    If you are using the pad you may have to replace the pad or recalibrate it using the pointer device, you can use the tab key to go through to the start menu then use the arrow keys to go to control panel.
    Hope this helps
    Nov 28, 2007 | Compaq Presario 5000 PC Desktop
    Open Questions:
    Acer Aspire 5101WLMi Notebook Logo
    52 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
