Question about Logitech Cordless Mouse
The scroller does not scroll horizontally - side to side
When I scroll vertically it works, however side to side - horizontally is does not work - what do I do to make it work?
    President:
  • 2,692 Answers
I do not know the model number of your cordless mouse or if it has a drive ball. If it has a ball , rumove the boottom to drop out the ball then remove tjhe lent and dirt from the two rod that the ball drives. If it is the non ball type , I don't know, sorry.
Posted on Dec 30, 2008
The scroller on the top of the mouse does not scroll the page
Go to your control panel of the computer. Click on the tab "Change mouse whell settings" If you do nto find such tab then search for that tab by puttin word "mouse" in the search box.
There you can change scrolling setting. If it doesn't work then remove the wire of your mouse, shut down computer.
Insert the wire and restart computer. This will surely work. If not then contact I'll give you other remedy.
Sep 22, 2012 | HP Wireless Optical Mouse
For my compaq tablet tc4400, the right side of the touch pad has a column of horizontal lines that I believe HP calls the "scoll zone." The problem is for a right hander as myself, whenever my...
Go to control panel -> Mouse -> "Device Settings" tab (has the synaptics logo to the left of it) -> Select your touchpad -> "Settings" -> expand "Scrolling" -> "One-finger Scrolling" -> uncheck "Enable Vertical Scrolling" and also uncheck "Enable horizontal scrolling"
If you don't have "Device settings" in the mouse setting window, then you need to install the drivers from http://www.synaptics.com/support/drivers
Dec 31, 2010 | Computers & Internet
Scroll pad not working on hp laptop mouse still works though
Need to enable Scroll function on the notebook.
Scrolling function is not working:
  1. The scroll function may stop working if the scrolling feature is disabled in Mouse Properties. To enable the scroll function, follow the steps below.
  1. Click Start , Control Panel . Select Classic View from the left side of the Control Panel window.
  1. Double-click Mouse in Control Panel, and then select the Device Settings tab in the Mouse Properties window.
  1. Click Settings , Virtual Scrolling . Select the boxes labeled Enable vertical scrolling and Enable horizontal scrolling .
  1. Click OK to save and exit the Mouse Properties window.
  1. After changing these settings, the scroll function on the touchpad will be enabled.
Jul 24, 2010 | HP Pavilion dv5000t Notebook
Inbox scroller on RH side does not scroll (yahoo mail)
1. This problem is due to the busy Yahoo! Mail server.
2. Because of busy server all the features or options of any particular web page don't become enable!
3. Such a web page is not completely loaded on the web browser, and it produces errors!
4. You should try to Refresh / Reload the page to prevent this problem!
5. Login to your account, and delete the old & uneccessary mails from your mail box.
6. Cluttered and full mail box can also create such problems!
please rate this advice if it helps...tc! :)
Jan 12, 2010 | Yahoo Mail
Hi, my laptop mouse pad works fine but at the side and bottom where i can use it to scroll down the page wont work, can sum one tell me how to get it back again, thank you
go to the control panel > mouse and pointing devices > go to device settings tab > highlight the touchpad listed and click on settings > look half way down the list where it say "scrolling" click on that and make sure both vertical and horizontal scrolling is checked. If it is and the scrolling still doesn't work,
go to control panel > device manager > scroll down to mouse and pointing devices > highlight the touchpad and disable it > wait 45 seconds, then re-enable it > hit apply and ok. Reboot
Oct 01, 2009 | Dell Inspiron 1525 Laptop Midnight Blue
Ball wont scroll downwards. Ball will only scroll from side to side. Cant access any of my applications.
Cause:
The sensitivity of the trackball/trackwheel might be less
Faulty Hardware
Resolution:
Increase the sensitivity by following procedure
Option -> Screen and Keyboard -> Horizontal Sensitivity and Vertical Sensitivity to 100
if still not working contact service center
Jul 08, 2009 | RIM Blackberry Curve 8300
Vertical scrolling not working
you can activate this by
1. going to the control panel on your vista machine, make sure you are in classic view
(2) double click the mouse icon.
(3) From here you will select the "Device Settings" tab,
(4) make sure your Synaptic Pointing device is highlighted and then click the settings button located directly below the "port" column, this will bring up properties for this device.
(5) With all categories in the left hand column collapsed, select "Virtual Scrolling" here is where you will find the box that needs to be checked to enable vertical and/or horizontal scrolling.
(6) make sure the "Enable Vertical Scrolling" box is checked.
(7) don't forget to hit apply!
May 22, 2009 | Compaq Presario CQ60-220US PC Laptop
Scroller jammed
The scroller only goes to number 3 for sound and when scrolled down to music it goes so fast and wont stop
Jun 02, 2008 | iRiver H10 MP3 Player
Scroll ring intermittent / non functioal
I have a similar symptom, that is, apparent loss of scroll ring functionality as homercles1 noted, but in fact the scroll ring functionality gets toggled between horizontal scrolling and vertical scrolling as Rithas has noted. A window that is not wide enough to require horizontal scrolling will give the appearance of loss of scroll ring functionality when the scroll ring is in horizontal scroll mode. Likewise, a window that is not tall enough to require vertical scrolling will give the appearance of loss of scroll ring functionality when the scroll ring is in vertical scroll mode.
Solution that worked for me:
My upper right-hand button is defined as "Allow Horizontal Scroll" and by clicking this button, the scroll ring function toggles between horizontal and vertical scrolling. In fact, what can appear to be a nonfunctional scroll ring in some windows is very useful when moving around in large windows.
Hope this comment will be useful to you.
Nov 20, 2007 | Kensington K64325 Trackball
No horizontal red convergence control
Probably the red convergence output IC has failed. The chip is basically a stereo amplifier that serves as a horizontal amplifier and a vertical amplifier. I suspect the vertical part has failed and is not uncommon. Should be generic STK392-150's or maybe STK392-110/120 I believe. By the way when the line moves up and down that means the vertical is working when it moves side to side the horizontal is working.
Feb 03, 2007 | Philips 60PP9202 60" Rear Projection...
Logitech Cordless Mouse Logo
105 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
