Question about Vizio GV46L 46 in. LCD Television
VIzio channels won't change
We have had our new tv for about 6 months and this morning the channels won't change. What do we do? Mine did the same thing about two weeks ago. I've had it for 8 months and it's worked perfectly. Two weeks ago I was watching it during the day and everything was good. Came back that night and the channels wouldn't change unless I manually entered them and the HD channels wouldn't come in. The channel up/down doesn't even work on the TV. For a while if I switched it over to antenna, the channel up/down would work, but now that doesn't even work. Need some assistance - more than just unplugging it.
  • 1 more comment
  • Anonymous Mar 27, 2009
    same damn thing how do i fix it?
  • Anonymous Mar 31, 2009
    i have the same issue the remove is not changing the chanels by using the + or - for channels... all other butons work... and in tv also the channel buttons dont work... does any one have any info about this how to be solved...
  • michaelc1978 Apr 25, 2009
    same thang
3 Suggested Answers
  • 101 Answers
SOURCE: 47" Vizio Flat screen HD LCD freezes up and remote will not work.
could it be Ch 9's digital signal is not broadcasting right? what is your refresh rate on your tv? 60 or 120hz? if its 120hz, then its more then likely the digital broadcast, if its 60hz I think its your tv can't keep up with their signal that may be at 120hz. Make since??
Posted on Apr 28, 2010
caroldon
  • 17130 Answers
SOURCE: channel up/down button on remote for 37" vizio tv
It is possible that the pads are worn out or there is damage on the main board, possible carbon track failure . you might need to reform the tracks or use a remote control repair kit to retrack. Also in some cases the controller IC can be defective as it fails to detect the selected port.
Please try this link for some tips:
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
Posted on Oct 04, 2011
I LOST MY REMOTE TO MY 39INC VIZIO FLAT SCREEN T.V. MODEL D390-BO HOW DO I CHANGE CHANNELS AND ADJUST VOLUME MANUALLY?
Unfortunately, the Vizio D390-B0 only has a Power and Input button on the TV. You need a replacement remote (XRT020) or a universal remote with the code for Vizio that was programmed 6 months after the TV was released. The D390-B0 documentation suggests that the TV was released in 2014.
I hope this helps.
Aug 14, 2015 | Vizio Televison & Video
We have misplaced our remote to vizio smart tv. I ordered new one but it will not be here for another month. Can I change channels without remote. We are stuck on hallmark channel :(
On some of the Vizio Smart TVs, there are volume and channel buttons along the side panel. They are pretty well concealed, but there are there. If you can give me a model number, I can be more specific.
Jan 01, 2015 | Vizio Televison & Video
MMy Vizio 32" tv only gets 16 channels
If your Vizio TV has a built-in HD converter, 16 channels is what you can expect. If the channels are identified with decimals such as 10.1, 10.2, etc. they are HD. The cable connection you refer to must be connected to an antenna, otherwise you would have a cable box and a monthly bill from some cable company
Dec 04, 2012 | Vizio E322VL 32 in. LCD TV
Tv wont go past the start screen
I have the exact same problem and am seeking a solution too ... it won't boot past the Vizio logo on the screen and the remote and side buttons won't work :(
Apr 18, 2012 | Vizio L32 32 in. LCD HDTV
Ive had my vizio for 4 months and just recently the volume on the same 4 channels slowly decreases til you cant hear much. With a change of the channel or a commercial the volume returns. Recently moved to...
First - connect DVD player preferably to the same input (unless you are using RF connector) and make sure that same issue does happens while you are watching movies. If it does - main board in your TV have to be replaced. If it does not - it still cable signal problem.
Aug 11, 2010 | Vizio SV421XVT 42 in. LCD TV
Jun 16, 2009 | Vizio VO47L 47 in. LCD TV
32" VIZIO PROBLEMS
The main board is bad. I have seen a lot of TV has the same problem like you have. Replace main board will fix it. If you bought these TV from Costco and less than 2 years then they all still under warranty.
May 05, 2009 | Vizio L32 32 in. LCD HDTV
My 37'' Vizio Flat Screen TV keeps shutting it's self off
I had a problem with mine shutting off randomly and (luckily under warantee still) the guy came out and replaced the mother board. If you're under warantee still just call vizio.
Dec 17, 2008 | Vizio L37 Television
Can't change channel using the remote or buttons on tv
Simple Fix
I had the same problem, couldn't change the channels with the remote or on the side of the TV. This was for a Vizio 37"
Here is the fix:
1. Turn on TV
2. With remote, press the Menu Button
3. Go to Antenna Menu
4. Select Auto Search
Let it search, it could take several minutes. It may not finish to 100%, mine got stuck at 79% for 10 minutes. It's fine if that happens, go ahead and cancel.
5. It should be done, your remote will work perfect along with the TV channel buttons.
Sep 07, 2008 | Vizio L32 32 in. LCD HDTV
press the menu button in the middle of your remote and scroll over to the middle tab that's labled "TV" and then scroll down to "auto search". click on this option by pressing the right arrow key on your remote so that your T.V. and "re-scan for channels. It might take awile. I took me about 5 minutes but for majority of the time it was stuck on 45% while it was scanning.
Jun 28, 2008 | Vizio L32 32 in. LCD HDTV
Vizio GV46L 46 in. LCD Television Logo
515 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
