Question about XFX GeForce FX 6800 (256 MB) Graphic Card
Monitor goes blank after showing XP logo screen (black screen with the xp logo right after boot up screens)
How is it going? I really do hope you can provide me with some insight :) I used to have a ati 9200se card and my computer worked perfectly for 2 years. 2 weeks ago, I bought a Geforce 6800 xfx (agp) 256mb card. I installed it; drivers as well. Then connected to my mointor using the dvi to vga adapter. And wow........it worked fine. And it did work fine for 3 days. Then I had to open up my cpu case; remove heatsink; check processor etc. And now whenever I boot up the computer........its shows the first boot up screen as normal (screen which says 3.00ghz, 1.5gb ram etc etc........select xp or recovery console etc). Then it show the next normal screen........the black screen with XP logo. AND THEN........... THE monitor goes dead. Says "monitor working fine; check your connection cable or computer". This keeps on happening every single time. Could you please help me. My email id is: crescentcanada@yahoo.com (if you need) THANKS BOSS.
  • 7 more comments
  • BRIAN ZEF
    BRIAN ZEF Apr 28, 2007
    Hey......that was extremely fast reply.
    Thank you.
    While you typing reply, I was working on the safe mode. And its not all bad news.
    Safe mode works fine. The resolution was already the lowest = 800*600. I changed 32 bit to 16 bit. The DPI is 96 which i did not change. The monitor refresh rate etc are all greyed out. Nothing can be changed there.
    Then finally I reduced hardware acceleration a bit. Then restarted in normal mode.
    STILL SAME PROBLEM.
    Everything good up to xp logo...then monitor goes blank!!
    Now the onboard video part:
    I have onboard video. But if I plug in to that output............NOTHING...and absolutely NOTHING shows up. Not even the initial boot up screens. I remember......i have tried that before just for fun. But onboard video has never worked.
  • BRIAN ZEF
    Yup.......now I did the same in Enable VGA mode.
    Resolution was already 640*480 (and it even gave a notification that the display settings are very low). The other thing was 8 bit.
    Then 96 DPI and the monitor resolution was 60Hz.
    So there was nothing really to change.
    In any case.........important thing.
    WHILE I WAS LOOKING OVER THESE SETTINGS, THE MONITOR TURNED OFF (in this vga mode). As always, the computer was running; but not the monitor
    What the heck?
    Help.................... :(
  • BRIAN ZEF
    BRIAN ZEF Apr 29, 2007
    hEY.........babb;
    Hope to get a reply tomorrow. Thanks man.
  • BRIAN ZEF
    BRIAN ZEF Apr 30, 2007
    hey..thanks babb
    see....my comp. has another serious problem too. I didn't mention it 'coz that was not connected to this problem and I didn't want to complicate the scenario.
    Thing is.........it is a heat sink/thermal paste related problem. Speedfan shows temp of 85 to 90 etc. Tomorrow I am buying artic silver 5 and am gonna apply. In the current situation, the computer won't stay up for more than 2 mins (EVEN WITHOUT THE DISPLAY PROBLEM).
    Now back to our problem.........I changed the video card with my old ati 9200se. And it works fine.......so the problem has to be with the new card's drivers, as you say.
    Once I apply the paste tomorrow, i will try your method (of uninstalling the adapter and resinstalling drivers).
    Meanwhile......please tell me what you meant by "...is there a vga connector on the monitor?"
    I have tried this computer with two different monitors and both show the display problem (with the new card). One of the mointors has a slot in to which the monitor cable goes (from where the cable can be removed). It is a VGA slot (infact both monitors use VGA cables). However, the card itself used DVI and I have the DVI to VGA adapter.
    Hope to hear more from you (and as I said I will be posting back after applying the paste).
    :D
  • BRIAN ZEF
    BRIAN ZEF May 04, 2007
    Hey.......babb. I'm back again.
    I fixed the thermal paste problem. Now back to video card thingy.
    I installed the latest nvidia drivers and there is QUICK RESULT. Computer gets past the initial screen and I can work for a long time without a problem.
    But once in a while (during game play or not), the monitor says "switching off power" and it shuts down. Computer is still running. I then have to manually press the restart button and....then comp. boots up and everything is normal for a stretch of time. Later same thing happens.
    What do you think BABB?
  • skiingelvis Nov 03, 2007
    I have a toshiba Sattelite laptop. I started running a dual monitor and now the secondary monitor is the only one working. When I try to identify it it says the external monitor is #1. I have gone to the setting under properties. Changed it, tried Fn f9 - still nothing - Got any ideas
    Mark
    skiingelvis@hotmail.com
  • Anonymous Dec 12, 2007
    i have the same problem jus after the windows xp logo it blacks out, i have even bought another monitor and still the same problem.
  • mc5892 Dec 28, 2008
    Could have had some virus had a add that kept poping up called spyware guard 2008 could not get rid of it. Cpu was very slow also. Bought some soft ware to try and clean up the system but it would just lock up after running for 5 or 10 min. Decided to try a system restore and now after the window XP logo the screen just goes black.
  • Anonymous Mar 24, 2014
    I have a Sapphire 7970 that starts to load windows, gets to the splash screen with the windows logo, blanks out but you can tell it is still booting windows cause the hd light still is working and you can hear the Windows bootup music, even after the monitor goes black. I installed another 7970 and everything works fine.
    Thanks Lonnie
    Novelist:
    Scholar:
  • 104 Answers
There are different reasons why this might happen. Let's try some. 1.) Does your board have an onboard video card, cause if it does, then XP might be using that as the primary monitor. TRy plugging into the onboard video when you start up! If that works then you need to disable the onboard video.(try disabling it in bios!) if not then 2.)When booting at the select xp or recovery console, press F8. You'll get the menu with safe mode and what not. Go down to Enable VGA Mode then press enter. If that works, go to display settings and lower your resolution then restart. But usually when this happens your monitor says "Out of Range" but u can still try Well if that doesn't work, tell me more! Regards, Armando
Posted on Apr 28, 2007
  • 3 more comments
  • Armando  Babb
    Armando Babb Apr 28, 2007
    Don't go to safe mode, safe mode doesn't load the VGA drivers. Look for Enable VGA mode, it loads the driver but at the minimum, then you can set it properly!
    Regards,
    Armando
  • Armando  Babb
    Well lower the resoultion in Enable VGA mode!!
  • Armando  Babb
    Armando Babb Apr 29, 2007
    Well, the only other thing i can say is a last resort technique! While in enable VGA mode, go to device manager and uninstall the display adapter(video card)! When u reboot in normal mode, the drivers will automatically re-install (you might need the driver / cd) and hopefully you will be able to adjust settings, try to see if you can get the latest driver for your card!! Try that and see if that helps!!
    Regards,
    Babb
  • Armando  Babb
    Hey another thought! Quick question is there a regualar VGA connector on the monitor????
  • Armando  Babb
    Armando Babb Apr 30, 2007
    Sorry about that, what i meant was if there was a VGA connector(as opposed to DVI) on your video card! But regardless I still think re-installing the drivers might work!
    Regards,
    Babb
Been following this for a while. seems that this problem stretches across many types of display. I have onchip vid display. have DVI and VGA. VGA (2nd) boots up first then i usually have to hit properties and enable "digital display" instead of "monitor". lately (today) it was just the 2nd monitor. My VGA. I tried disconnecting so that the DVI would boot up, nope. switched my VGA cord to my primary (larger) monitor and DVI to the smaller secondary. works like a charm. I think that if you are trying to run DVI for a higher res monitor the system looks to the VGA? seems to be a common thread since alot of people will want the larger higher res monitor to be the Primary, but probably most drivers will look to VGA on startup.
Posted on Jan 21, 2008
I have armor command but can't get it to work on xp sp2 despite trying every setting combo in the compatibility window. how do i get it to work?
WinXP SP2:I've tried other systems too with no luck either. However, I've had this working (almost properly = every once in a big while it would hang and reboot was the only recourse) using an Intel D845GEBV2 motherboard with a 2.0GHz intel P4 w/ 1GB ram. I've found that the trick is the AGP card. The system stayed up long enough to play for hours. I had a Rosewill AGP Radeon ATI 9200SE video card. Apparently the 'rage' :) was AGP at the time this game hit the streets (1998) and this game is very AGP touchy.
I've also tried to run this on my P4 641 OC to 4.0GHz with 2GB ram with a Sapphire Radeon 9600 Atlantis AGP 8x video and ... no go. Similar issues with hand and config.
Right now I have it working on a just built Seattle 2 PII 440BX ATX motherboard (aka MICRON PC). It has a PIII @ 650MHz and 768MB ram. Boot to MS-DOS or Win98SE2. The video card on this one is an ATI Rage Mobility-L. A dinky little card, you can find one easily on EBAY for really cheap, but mine (bought on EBAY years ago for like $48) was out of an older MICRON system (not this Seattle 2 MB). Works fine. Really had to look on web hard to find a video driver for it ...This config also works great for these DOS games that I miss ... DOS Protected mode box within Win98 works perfect for Commander Keen and the original Duke Nukem!
Sep 14, 2010 | Ripcord Games Armor Command for Windows
I have a ATI Radeon 9200se m61d128x20jy 128mb agp
hi try to download this software and hopefully ur problem will be solved http://www.driver-download.net/ati/video-adapters/radeon-9200-se-128mb-ram/
Jun 07, 2009 | ATI RADEON 9200 SE (128 MB) AGP Graphic...
ATI mobility radeon 9200 on windows 7
I am using a HP Compaq Presario X1000 with a ATI Mobility Radeon 9200 display.
I have recently installed the Windows 7 RTM and tried various display drivers with no good results.
I am now using the driver from ftp.asus.com.tw/Pub/asus/nb/A4D/VGA_XP_2K_060102.zip
At first I unzipped the folder and run the setup program inside but it was not successful.
Then I go to the Device Manager, choose the display driver and choose "Update Driver"->"Browse my computer for driver software"->"Let me pick from a list of device drivers on my computer"->"Have Disk"->"Browse"
click to the subfolder inside your extracted folder and find the folder named "2KXP_INF" and choose the inf files there and click "OK"
A list of device is displayed and I choose "ATI MOBILITY RADEON 9200"
the computer will install the driver and ask to restart the computer.
After restarting the computer my display was automatically set to 1680x1050, I found the following driver was installed:
Driver Provider: ATI Technologies Inc.
Driver Date: 1/19/2005
Driver Version: 6.14.10.6512
Digital Signer: Microsoft Windows Hardware Compatibility Publisher
I went on to test Suspend and Hibernate and they WORKED!
I have not tried this on Vista as I was running XP and Ubuntu in the last few years.
May 26, 2009 | ATI RADEON 9200SE Graphic Card
LOST DRIVER
If the ATI driver doesnot work, try to redownload it. If it still doesnot work, try reformatting again because sometimes some things might stay behind.
otherwise try e-agent, will costs you about USD20 but for 1 year support and updates and it provides correct drivers and updates for all components in your PC.
Aug 07, 2008 | ATI RADEON 9200 Graphic Card
DRIVER
www.Update-Drivers.com/ATI
Jun 04, 2008 | ATI RADEON 9200SE Graphic Card
LOST DRIVER
help
ATI 9200SE/M6D12820JY
Dec 25, 2007 | ATI RADEON 9200SE Graphic Card
XFX GeForce FX 6800 (256 MB) Graphic Card Logo
6,706 people viewed this question
Top XFX Computers & Internet Experts
1400Slugg
Alun Cox
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
