Question about Vizio L32 32 in. LCD HDTV
Screen Goes black after 20 mins- Still have sound
Power off and back on it is fine for another 20 mins. Any idea what board needs to be replaced to resolve?
    New Friend:
  • 4 Answers
There is a problem on the resistor going to jungle ic.. check the resistor
Posted on Jan 03, 2009
I have a Curtis LCD2425A flat screen tv it powers on fine with picture and sound. After about 20 minutes the screen goes black but the sound works fine. If you turn the set off and then back on the Curtis...
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jan 11, 2015 | Curtis LCD2425A TV
Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Oct 26, 2008 | Vizio Televison & Video
Samsung ln52a850. ..works fine for a few min then
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Sep 17, 2014 | Televison & Video
After 10 to 20 mins left half of screen goes to white vert lines
Sounds like power supply regulator board fault. Check all the electrolytic capacitors for any leaked or bulged one. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Jul 01, 2014 | Samsung LN32D450G1D 32 LCD TV
TOSHIBA 32bv500b screen stops working sound works fine
I'm having a hard time finding any parts for the set besides the power supply board. The T-Con is usually located top center on the back of the LCD panel. It will be under a metal cover. Sometimes, the t-con circuitry is built onto the main board. If this is the case with yours, you will have to order the main board. Feel free to send me a pic of the back of your set.
info@back2lifeelectronics.com
Jan 06, 2013 | Toshiba Televison & Video
I can turn on the tv and it's fine for about 20 min then the screen goes black with sound. I turn it off for a minute and it's fine for another 20 min. Like it's overheating.
It might also be a bad solder connection, short of checking voltages what I have done in this type of situation is with back off use a small fairly high speed fan - a hair dryer set to cool works, to cool areas of the boards inside to localize which board is causing this, with the set in failure, got it? it goes out cool it with a handheld hair dryer with air set to cool, when you find the spot where the problem is it will either instantly come back or try to.
Do it a few times to confirm which board is bad and locate a replacement board and swap it out.
Dec 15, 2012 | Proscan 47LB45H 47 in. LCD TV
My samsung LE40R74BD set works fine for about 10 mins then screen goes blank (black) . It would appear there is no back lighting. I have visually checked the psu for blown capacitors but all seem to be...
This does not seem to be a power supply issue but rather an issue with the backlight inverter board. When the screen goes black, take a flash light and focus it on the screen from a close distance and several angles. See if you notice a very faint image. Try changing the channels to make it more noticeable. Try it and let me know
May 09, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
I turn my tv on the picture and sound all work and after about 20min the picture goes to a black screen and I still have my sound. I turned the tv off wait about 5 min turn it back on the picture come on...
If you have electronics experience - check the power supply and make sure you are getting the correct voltage to your inverter boards and main av board - also do you see any movement on the screen take a flashlight and shine on the screen - if you can see a dark image on the screen check inverter boards and power first.
thanks,
michael
Mar 21, 2011 | Element Electronics FLX3210 32 in. LCD TV
Plays for 10-15 min.then pic.goes black,sounds stays on.
Resolder FBT pinns flyback transfomer on deflection board also CK capacitors 3 of them cp114,120,150 if anmy of them is puffewd up on top it is bad.cp150 2200uf 16v other 2 are 220uf 35v replace all 3.
Jan 28, 2009 | RCA R52WH73 Projection Television
Vizio L32 32 in. LCD HDTV Logo
76 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
