Question about RCA D61W20 61" Rear Projection Television
Rca d61w130yx1 61 rear projection
When I turned on my TV I got a red screen with white lines it turned off a started again 3 times then turn off I was told it could be my red lamp please advise thanks
    Genius:
  • 1,030 Answers
These rca sets have a processor that will shut it down it has a problem. red screen indicates yes.. it possible a red crt...difficult to replace. and expensive if not under warrenty. around 200 just for crt plus labor.... sorry
Posted on Dec 08, 2007
SOURCE:
My KP-51HW40 clicks off after running for a period. The red power light blinks when it goes off but screen stays dark. When TV is shut off for a while it restarts and runs fine. The "On"...
KP-51HW40 shuts off due to incorrect white balance and blue arch lines is an evidence of that incorrect white balance. I hope tv standby red light would flashing 5 times then 3 seconds pause and again 5 times when tv shuts down.
This is rear projection tv that has three picture tubes (red-green-blue) inside to generate picture that projected at front screen. These three picture tubes must be drive with correct drive voltage to produce good picture of each color.
Solution for your tv problem is Screen Voltage adjustment that can be done easily if you are handy with electronics stuff repair.
Let me know your expertise level to guide you more and if you feel unconformable by tv repair then local tv repairman will help you to adjust white balance in tv.
Hope these info will help you.
Let me know if you have additional questions.
Thanks.
Nov 05, 2010 | Sony KP-51HW40 51" Rear Projection...
Thin red line, green line and yellow line going across the screen
the problem is vertical collapse,i am not so sure you can trouble shoot this on your own but you can send the board to eithor pts electronics or tristate module for repair
to get a price get the number off the sticker--left hand board(looking from the back) it will start CTC195---- write down entire number before you call them
Sep 02, 2009 | RCA P52926 52" Rear Projection Television
Picture turned red then tv turns off
The red picture tube is bad, you must replace before it cause damage to the boards.
Feb 24, 2009 | Sony KP-57WS500 57" Rear Projection...
Thin vertical lines
Those lines are called retrace lines. They are there all the time on projection TVs but you should be able to see them. When you do see them, that's an indication that the kine screen settings are too high or the supply voltage to the kine driver circuit is low or missing. There is a small, black control unit located behind the speaker grill assy in the front of the TV that has 2 sets of 3 controls. A red, blue, and green focus and screen controls. See if you can make the lines dissappear by turning the screen controls counterclockwise. If you can't you'll need to have service come out to troubleshoot it.
michtech
Feb 02, 2009 | RCA D52W19 52" Rear Projection Television
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Question
have convergence rebuilt........
Jun 01, 2008 | RCA HD52W56 52" Rear Projection HDTV
Sony turns on and off again
My tv too had a blue screen problem. Then it started to shut down after staying on for less than a minute. I thought that I would with a huge repair bill but I followed the directions at this link: http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html and now my tv works perfectly.
Apr 27, 2008 | Sony KP-57WS500 57" Rear Projection...
RED LINES
Your red CRT socket may be loose or have cracked solder if not, try turning down the red gun screen control inside the set just a little. Youre experienceing what is known as retrace lines
Jan 21, 2008 | RCA P52771AT 52" Rear Projection...
What is this?
Likely to have a bad high voltage transformer: white square thing with large red wire coming out and possible horizontal output transistor maybe C5148: on metal heat sink behind transformer. Must use original transformer Average cost $300.00 according to which repairman. Be sure picture was good before it went out!
Nov 01, 2007 | RCA P46924 46" Rear Projection Television
RCA D61W20 61" Rear Projection Television Logo
123 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
