Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. D:\Documents and Settings\Home>ipconfig Windows IP Configuration Ethernet adapter Local Area Connection 2: Connection-specific DNS Suffix . : IP Address. . . . . . . . . . . . : 192.168.1.10 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 192.168.1.1 D:\Documents and Settings\Blank>IPCONFIG /ALL Windows IP Configuration Host Name . . . . . . . . . . . . : home Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Unknown IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No Ethernet adapter Local Area Connection 2: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) 82562V-2 10/100 Network Con nection Physical Address. . . . . . . . . : 00-1D-09-95-97-6F Dhcp Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IP Address. . . . . . . . . . . . : 192.168.1.10 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 192.168.1.1 DHCP Server . . . . . . . . . . . : 192.168.1.1 DNS Servers . . . . . . . . . . . : Lease Obtained. . . . . . . . . . : Tuesday, October 02, 2012 4:18:59 PM Lease Expires . . . . . . . . . . : Friday, October 05, 2012 4:18:59 PM
Took another look by fixing word wrapping in notepad.
It's missing DNS Servers. Check your NIC settings and make sure you don't have a DNS server manually set to another IP. Plus, you might try resetting the router to default in case there is a DNS modification there.
I'm not sure if this is the cause, but I couldn't hurt. It's part of trouble shooting.
Good Luck!
JD
SOURCE: I just got a Linksys WRT160N router. I cannot
you are right, need cd for you lan card for it to work right,,but if you dont have it go to linksys web site and download the files you need
SOURCE: Laptop connects to wireless with Erthnet cable but
RE INSTALL THE LAN DRIVERS AND DISABLE THEWINDOWS FIREWALL
SOURCE: I am trying to wirelessly connect to a netgear
I am having exactly the same problem - driving me mad! It seems it does not pick up the ISP addresses.
Only thing noticeable is NO Ethernet adapter Local Area Connection 2. Check the Network Connections. Why are there 2 with same name? Same IP config?
