Sony Cyber-shot DSC-W50 Digital Camera
Problem for Sony Cyber-shot DSC-W50 Digital Camera
Flash
By Memphis Girl on Apr 28, 2007
I have a sony cybershot DSC-W50. Everything has been working fine until one day it stopped flashing. I have tried pressing the flash options button, but nothing happens. However, whenever I turn the camera on E:91:01 and a little squiggly arrow flash. Please help me!
Same Problem
Jan 04, 2009
-   flash will not work error code e91.01-   brookes25
Oct 29, 2008
-   ive had this same problem for months, i tried the reinitialize button, and it went away but then as soon as i went to snap a picture it came back!-   Guest
Aug 07, 2008
-   no flash -   smurfette10
Aug 07, 2008
-   I have the same problem no flash E:91:01-   Guest
Jun 25, 2008
-   I have a DSC-W50 which was purchased in January 2007. The flash has stopped working, error code E91:01 and the "lightning" symbol flash continuously and the Self-timer lamp is permanently ON. I've Initialized the camera several times (Setup 1) and removed the battery for an extended period. It is fully charged. Any suggestions??-   Best peasant
Best Solution
posted on Mar 18, 2008
Helpful)
Abbydog
Rank: Apprentice
Rating: 94%, 4 votes
I have the same problem as Memphis Girl. I've checked settings, battery is fully charged, all other functions seem to work and still the flash does not work. I re-initialized as Memphis Girl was instructed. Took a trial picture and surprise---the flash worked. The second picture, same settings, same lighting, the flash did not work. I tried re-initializing again and still the flash does not work. Any suggestions?
Was this helpful?
Yes
No
Solution #2
posted on Oct 13, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Wow!! it worked at once.Great.sitesh
Solution #3
posted on May 18, 2007
Helpful)
lsintv
Rank: Apprentice
Rating: 92%, 41 votes
Did you try to reinitialize? Setup menu go down to the third Setup#1 menu and make sure you click OK to reinitialize. That's what the manual said.
Was this helpful?
Yes
No
Solution #4
posted on Nov 03, 2007
Helpful)
macaloney6
Rank: Apprentice
Rating: 89%, 12 votes
Thanks to fixya site and memphis girl I was able to solve my 91:01 just as she said to do .I lost my manual and really did not want to take it to get repaired. I love my camera thanks again for your posted suggestions.
from Macaloney6@aol.com
Was this helpful?
Yes
No
Solution #5
posted on Nov 05, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Worked perfect and for good!!
Solution #6
posted on Aug 09, 2009
Not Rated)
MAYITTO
Rank: Apprentice
Rating: 0%, 0 votes
Well, I have the same camera DSC-W50, and the first time I got the problem with the flash, I read the whole manual, but nothing related about how to fix the flash. Until one day I discovered that when you plug the camera with the cables and into the video and sound plug on any TV, you turn the camera on, and I started to take some pictures, the flash started to work perfectly. I don't know the relationship between the cables for the TV and the flash, but for me this issue is resolved every time when the flash stop working. In 3 years the flash of my camera has been stop working 6 or 7 times and always I do this tip, and after that it works perfectly. Good Luck!
Was this helpful?
Yes
No
Solution #7
posted on Aug 27, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i have the same problem... yall know anything?
Popular Solutions for Sony Cyber-shot DSC-W50
Questions and Unsolved Problems for Sony Cyber-shot DSC-W50
Do you recommend Sony Cyber-shot DSC-W50 Digital Camera?
Answer
Answer
I can't switch my camera on -- it comes up access -- then turn the power off and on again. I can... (More)
Answer
No LCD Screen at switch on, but its there to show the photo just taken
Answer
Error on Start of Camera"Turn off power and than Turn On"
Answer
when i try and turn on my camera it autimaticly shuts off and tells me the battery is not correct
Answer
When I turn on my SONY Cyber-Shot model: DSC-W50, I can't get beyond the set-up screen and pressing... (More)
21 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jun 25, 2008
sony cyber-shot dsc-730 won`t flash
Comment by DSCW50, posted on May 29, 2008
HELP!!! i have tried everything to get rid of this E:91:01 error code. i can still snap photos but without flash. i need to flash! how can i fix this without sending it out to get repaired?!
also i dont understand how someone said memphis girl helped them fix it, i read what she wrote and it doesnt explain anything... unless im reading the wrong thing?!
Comment by Guest, posted on Apr 21, 2008
I have a Sony DSC-W50 . The flash stopped working and I get a flashing code E-91:01. Have tried to re initialize but it does no good.
Comment by Guest, posted on Mar 31, 2008
MY CYBER-SHOT DSC-S700 FLASH HAS STOPED WORKING
Comment by RiicanMamii, posted on Mar 30, 2008
i have the same error code flashing on my screen (E:91:01) and i tried reinitializing it 3 times and it'll work for the first picture and then go back to the error code blinking on the screen :( i dont know what else to try i have tried looking everywhere to find a solution to my problem and still nothing has helped... Someone please help me, thanks.
Comment by caa587, posted on Mar 25, 2008
I have the same problem E:91:01
I already reinitialized it twice.
Please help.
Comment by garyjeff, posted on Mar 25, 2008
sony dsc w 55 error message E:91:01 NO flash at all. Do not want to take it back for warranty. It takes too much time to be without it. How do I clear the error code???PLEASE, ANYONE KNOW???
Comment by Guest, posted on Mar 18, 2008
The flash on my Cyber-shot DSC-W50 is not working. I checked settings according to the manual and everything seems fine. I also re-initialized like suggested for Memphis Girl's flash problem. Oddly it worked for once. The second picture I took (same settings and lighting) did not work. I reinitialized again and the flash is still not working. Any suggestions?
Comment by Guest, posted on Mar 13, 2008
I've had my camera for less than a month and already the flash has stopped working. What should I do? Can I fix it myself without taking it in for repairs?
Comment by tebrock, posted on Jan 27, 2008
flash doesnt work E:91:01 blinks on screen
flash doesn't work 91:01 blinks on screen
Comment by noflash, posted on Dec 24, 2007
Everything on my Sony Cyber shot works fine, but the flash will not go off. It does not matter which photo mode I am in. If I use the forced flash mode it still does not flash.
Comment by felilorenzo, posted on Dec 06, 2007
Hello porfavor not that wave with this error e: 91: 01 inizialice and nothing have to me tired you do not pass the solution already to me
Comment by b_montero118, posted on Nov 30, 2007
I have the same problem the E:91:01 error comes on my LCD
Comment by Guest, posted on Nov 17, 2007
I have the problem the camera doesn't flash and error E:91:01 flashes regulary. I tried to fix it with the flash option but doesn't work at all.
Bishnu R Koirala
Nepal
Comment by Guest, posted on Nov 11, 2007
I have the error message E:91:01 message flashing on my camera
Describe your Digital Cameras problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital Camera Experts
Top Camera & Camcorder Repairmen
in , IL
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
