Question about Canon CanoScan 4400f MultiFunction Color Printer
Error message: Can not scan. Not enough space on target disk
The "target disk" has over 100Gig of disk space available. Tried other disk's and get the same message, even tried to "copy" directly to a print... same message? Any ideas on how to solve this problem?
  • vivi158 Mar 10, 2009
    and the above doesnt cure it
    help?!
I have just cured this"not enough space on the target disc" on my set up.I had the problem from day one after buying scanner but learned to get around it.Today I went into Toolbox and opened settings and made a note of the target address. Then checked properties of the target folder and found there was 86mb in a space for 80mb.This was the default setting chosen by the installation programme. I went to my documents and made a new folder and called it Canoscan, clicked ok and it became the new target and the fault is gone. Hope it works for others.
Posted on Jan 23, 2009
  • joefabbs Sep 25, 2010
    When I got into the properties of the canon toobox, I clicked on "customize" and changed the default setting from "documents" to "pictures". It worked!
Why is there an error message: Space Not Enough when trying to copy DVD?
There is some space reserved for dvd information, error information etc. So solution is make the file archive by right click on file ->proprties-> click archive. After that use winrar and compress. http://www.rarlab.com/download.htm
Aug 22, 2013 | EZ Dupe Computers & Internet
Can not scan. Get message "Unable to scan. Make sure there is enough space on target disk". Changed default temporary disk location, have plenty of disk space.
Had this before and after a day of playing about with cleaning out the windows temp folders, I simply uninstalled all the driver and toolbox software, downloaded the latest version from Canon's site and reinstalled it. After doing a bit of research, found out it was caused by a windows update conflicting with the drivers
Dec 27, 2010 | Canon CanoScan LiDE 70 Flatbed Scanner
Scanner sends message "Unable to scan. Make sure there is enough space on target disk"
Check the resolution settings.  If you're trying to scan at 9600dpi, the image will be huge, it may not fit into ram either, so the swap file would be used and you would need twice the file space to scan the image.
Scanning at 600dpi is generally fine enough for most uses (300 or less for web use), including scanning photographs (you may want to scan negatives at 1200 though.)
JBV^_^
Sep 01, 2010 | Canon CanoScan LiDE 70 Flatbed Scanner
Using Canoscan Lide 70. When trying to scan receive message "not enough room on target disk" When I reinstall Toolbox it works (for a while, then same repeats).
When you scan a picture, you send it to a "Target" folder which you can set up in your scan options or settings.
At a guess your current destination or target folder is getting to large for the hard drive that its registered on
You've 2 options, clean out the target drive or use the scan options to send your pictures to a new destination with plenty of space.
Mar 05, 2010 | Canon CanoScan LiDE 70 Flatbed Scanner
Unable to scan.make sure there is enough space on the target disk
Do a "reset".
•Go into the CanoScan toolbox,
•click Settings,
•click the Defaults button on the bottom
•then click OK.
It will take a few seconds to reset and you should be good to go.
Jan 24, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
Won't scan - says not enough disk space.
I had the same problem. Solved it by going into the "CanoScan Toolbox" - "Settings" - and pressing the "Defaults" button in that panel - and then "OK" button. Afterwards everything worked fine. Hope this helps you.
Dec 18, 2008 | Canon CanoScan 8600F Flatbed Scanner
LiDE 600DF - Unable to scan
Hi Peter
Have had the same problem, seems to come and go a bit... Quickest & easiest fix is to go to CanoScan toolboox > Settings then press the 'defauls' button at bottom... this sets everything back to factory settings and should fix your problem. Cheers.
Jun 08, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Canon CanoScan 4400f MultiFunction Color Printer Logo
574 people viewed this question
old marine
old marine
