Question about StarTech.com StarView SV211K 2-port KVM Switch
Just entered the codes and two minutes later the signal scrambled
Hi I just entered the codes i got and two minutes later the signal scrambled again, are there new codes available? thank you
  • 3 Answers
What are u running off? ntl? cw? tw?
Posted on Dec 29, 2008
Why is my Humax 4000 very slow, freezing and scrambled saying bad signal.
Check the signal level and quality. Reseat all aerial connections.
Jun 18, 2016 | Humax Televison & Video
Scrambled laptop screen
Scrambled is a subjective term that is useless in trouble shooting.
Sounds like a virus.
Mar 31, 2014 | HP Computers & Internet
HL-P4663W - picture is scrambled - tv problem or cable box problem? have directv hd
Tries tv and box unplug,replug back like an hour later.The box now should have it software updated and tv resetting itself.Tv shoud be working again.Still have the same problems,tv the cause main tv Tuner signal board is dying.Get an estamate from shops and get it repair.
Feb 18, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
Hi I have the mitsubishi WD 62525 and I have replace all the bulgy capacitor, now the tv is working, but after a few minutes the picture start distorsionated to the point that is scramble. I turned off...
You have a multitude of surface mounted capacitors that have to be changed on the DVM module which is part of the Light Engine Assembly. Mitsubishi's are notorious for this problem. Mits charges $300.00 to refurb the Light Engine Assembly , which is not a bad price.
Dec 27, 2010 | Mitsubishi WD-62526 Projection TV
Cable company switched to digital, now my Ant A port on the vs-50603 does not receive signals. I can somewhat view the analog signals through my PIP only. other tv's in the house came back with signal 5...
When the cable company offers you digital cable, you typically need a cable box to unscramble the digital channels. Therefore you need to connect either a coaxial cable from the cable box's RF output, if it has one, or connect 3 RCA cables from the yellow, white and red jacks on the rear panel of the cable box to the TV. Analog channels only (if available) will go straight thru over the coaxial RF hookup. They are not scrambled. Select the proper input source on the TV for the cable box.
Aug 26, 2010 | Mitsubishi VS-50603 50" Rear Projection...
Laptop screen scrambled and now won't turn on
maybe overheating graphics card, check the fan is actually turning on, usually you can hear it whirring around.
Mar 21, 2010 | HP LCD Display for Compaq Presario R4000
Starview box
Hi Craig,
You could try thechatterbox.cc toolbar which has something called keymaster in the menu which provides all the updated codes, which is where all the ones that get posted on Fixya tend to come from..
http://thechatterboxcc.ourtoolbar.com/
Here's the last ones posted:
ALL CHECKED AND WORKING 17:40 23RD DECEMBER
LATEST KEYS ALL AREAS
EX C&W KEYS -- KEYROLL 23/12/2008
PROVIDER CODE: 5C 01
KEY 00 = D8 53 39 BD 3D CA 86 C1
KEY 01 = EF 38 DF 11 3D 85 FE 2F
TELEWEST KEYS -- KEYROLL 23/12/2008
PROVIDER CODE: 5A 01
KEY 00 = E7 D3 69 2E 6F 38 EA 78
KEY 01 = E8 C9 E5 6E B0 49 53 F5
PURE NTL KEYS (UK) -- KEYROLL 23/12/2008
PROVIDER CODE: 54 01
KEY 00 = 7F CD 76 82 BB 22 0A C5
KEY 01 = 97 9B 22 E0 5B 13 B1 C7
Try these codes again, and check Keymaster too, if you are still scrambled then maybe the codes that are coming through don't cover your area? I'm not really sure, mate, but check the toolbar anyway..
Good Luck
Chris (ziraffa)
Dec 23, 2008 | StarTech.com StarView SV211K 2-port KVM...
Digivox DV3 cable box
You need to Enable the Emulator as this is what clears scrambled channels. Main Menu -Factory Settings enter code 1570 which should give you a new CAS menu. Go down to EMU and switch it on with >vol key. Go up to Negravision and select your area providerer and press OK. Exit and scroll down to Default and hit OK. Will flash "Saving". Exit all the way out.
With certain channels when you first switch to them they may take a minute to upload data automatically.
Good Luck.. Tom (Dublin)
If unsuccessful it is because the code above does not work on your Box. You will know straight away when you enter it if the CAS menu doesnt appear
Jul 08, 2008 | Televison & Video
Monitor problem: screen goes black, then comes in scrambled
It sounds like this one needs component-level troubleshooting, probably in the power supply section. One or more backlights may be going out, too.
Dec 31, 2006 | View and View Technologies VNV AquaView...
StarTech.com StarView SV211K 2-port KVM Switch Logo
89 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
