Question about Cell Phones
I just got a LG DVD-Recorder DR6921W, and I was fiddling with the setup, and put some 'Progressive Scan' or something on, and then I couldn't see anything! I can hear everything, but no see. Is there a way to reset it or something? I have read the Owners Manual but I cant find anything in there, and I have un plugged it for 12 hours and still no difference. Help Please!
  • 59 Answers
HEY. MY NAME IS RUAN NOORDMAN FROM OCEAN ELECTRONICS
DO THE FOLLOWING
PRESS AND HOLD THE POWER BUTTON FORAT LEAST FIVE SECONDS.
THIS WILL FORCE TO POWER OFF.
PRESS THE POWER BUTTON AGAIN TO TRUN UNIT BACK ON.
UNPLUG THE POWER CORD,WAIT AT LEAST FIVE SECONDS, AND THE PLUG IT IN AGAIN.
TRY THIS, THE UNIT WILL RESET AND YOU WILL NEED TO DO THE SETUP FROM THE START.
HOPE YOU CAME RIGHT.
IF YOU ARE IN SOUTH AFRICA CALL ME ON MY CELL:078-620-7908
Posted on May 11, 2009
While going thru the settings on the dvd part of my sanyo dvd/vcr reciever it went to progressive scan mode and now i can't get back to the setup part to turn it off, can you help me?
If your TV has component video inputs then it will work (and give you improved video quality) in progressive mode. If not try leaving it unpluged for several hours to see if it resets itself. Otherwise refer to your owners manual to see how to reset the settings.
Aug 17, 2011 | Sanyo Cinematic Progressive Scan DVD...
PROGRESSIVE LIGHT WAS SET BY MISTAKE, AND IT HAS BEEN SET ON AUTO HOW CAN I SOLVE THIS PROBLEM BECAUSE THERE'S ONLY A BLACK SCREEN AND SOUNDS THAT COMES ON.
According to the operating instructions (page 97), Progressive Scan can be cancelled (or turned off) by pressing and holding PAUSE (on the main unit) continuously for 5 - 10 seconds, until the progressive indicator goes out, or turning it off in the setup menu. Your recorder should now be back to normal interlace video output. I recommend that you check your setup menu after this procedure to make sure nothing 'AUTO' is set, that shouldn't be set, and subsequently turning off any function that isn't required.
Apr 30, 2011 | Sony RDR-VX515 DVD Recorder/VCR
HOW DO I GET MY DVD OFF PROGRESSIVE SCAN
You do either of the following; refer to your instruction manual (if you still have it) and look for general output settings to turn off progressive scan, or you can try something much simpler.
On the front of the unit, without a disc inserted, and the drive selected as DVD, press and hold STOP button for 10 seconds (on the unit, not the remote), then release. This may revert progressive scan back to normal interlace for your TV, and thus turn progressive off.
This trick works for Goldstar, Samsung, some LG, Magnavox, and Zenith DVD players. Give it a try before referring to the manual.
Apr 13, 2011 | JVC DR-MV150B DVD Recorder/VCR
RDR-GX315 was accidentally reverted to "Factory Settings" ... now we can get sound but no picture and progressive is turned on and we need to turn it off.
If your TV has progressive scan capability, you may be able to view the on-screen setup menu via the recorder - select 'SETUP' press 'ENTER' on your DVD recorder's remote to bring up the menu - with the remote arrow buttons, scroll down to select 'VIDEO' then 'PROGRESSIVE' - highlight it then set it to OFF (you cannot do this with a TV that does not support progressive scan from this unit). Once done, exit the setup menu and it should work fine with all the other settings. If your TV doesn't have progressive scan, connect the DVD recorder to one which does and turn its progressive output off there. I assume you still have the user manual for your recorder (if not, you can download it online for free as an Adobe document - .pdf. Page 73 details the setup steps for this model). I hope this tip helps somewhat.
Feb 11, 2011 | Sony RDR-GX315 DVD Recorder
My recorder is stuck on progressive scan and can not take it off can youhelp me fix this problem please lg dvd recorder dr6921w
you need to connect to tv with pb r cr connectivity and go tp menu and do progressive off
Jun 28, 2009 | Televison & Video
PLAY REGION 2 DVDS ON DVD RECORDER
Press "Setup"
Go to "Lock"
Press 0 seven times.
Press "Return"
Dec 23, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Unlock regan cod
Sorry i was a way . The Model lg DR6921W DVD Recorder
Jan 25, 2008 | Televison & Video
DVD recorder: Changed the settings, now
we could go through the setting like, you can see the monitor. using the remote do the following steps:
Step 1. press set up button.
Step 2. press down arrow once. ( playback)
Step 3. press OK.
Step 4. press down arrow once. (video (selection))
Step 5. press OK. (progressive scan)
Step 6. press OK, again.
Step 7. press down arrow once. (progressive scan off)
Step 8. press OK
you have now turned progressive scan off.
Dec 19, 2007 | Philips Magnavox MWR10D6 DVD Recorder
PROGRESIVE SCAN
I have the samne problem, hoiwever when I press the menu/setup button it says setup on the display but nothing changes on the tv, it does not have a navigation menu, any suggestions on what to do to remove the progressive scan from my screen
Nov 05, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Cell Phones Logo
71 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
