Question about Indesit W 123 Front Load Washer
Indesit WIDL126 washer/dryer
I do not seem to be able to undo the fluff trap at the front of my machine. I can take the front flap of the front. But I cannot undo the knob inside to release the trap where the fluff ect collects? I do not wish to force it as I may damage the knob to turn it. Any ideas would be greatly appreciated. Thanks pinklady
Use a screwdriver or pen knife or knife...thats what i did and it worked...
Posted on Jul 09, 2007
    President:
  • 1,462 Answers
No magic to it. use a pair of pliers. you are unlikely to do any damage - just the thread stiff
Posted on Apr 28, 2007
Is there a filter to catch fluff during wash?
How to Reduce Lint in Laundry - Home Ec 101
www.home-ec101.com/how-to-reduce-lint/
Sep 23, 2010 - I clean out the dryer lint trap every time and that doesn't seem to matter. ... If your washing machine is older, there is a chance that it has a built-in lint trap. If this is the case and ... Follow the directions for cleaning the lint filter.
Washing Machine Pump Filter - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 8, 2013 - Common problems and faults with a washing machine pump filter. ... a pump filter to protect the pump from a build up of lint, and obstructions such as coins. ... towel to catch water and don't take it out at all if the washing machine still ... If you can't see any blockage, or there is just the odd button in there that ...
Is there a filter to catch fluff during wash? - Fixya
www.fixya.com/support/t26006809-filter_catch_fluff_during_wash
3 hours ago - Locating fluff filter on aeg washer/dryer . After using the dryer facility the following wash resulted in garment containing patched of fluff ...
How To Clean Your Washing Machine Filter - YouTube
Dec 13, 2015 | Washing Machines
Where does the fluff go when you use the dryer on
The lint should go in the lint trap. If it doesn't go in the lint trap it goes out the exhaust pipe if the lint trap is not installed.
Jan 08, 2010 | Hotpoint Ultima WF860 Front Load Washer
My Indesit WIDL126 washer/dryer doesn't dry clothes
You have an air flow problem. This usually happens when the exhaust pipe/vent gets clogged. Clean/inspect the vent outlet, the pipe, the inlet, and the filter/lint catcher area.
Improper air flow prevents the moisture from being vented out of the dryer.
Sep 26, 2009 | Washing Machines
My Indesit Washer dryer WIDL126 will not work all the LED lights are flashing continually.I have tried turning off at the plug and then on again, but no good. Any answers please?
My guess without seeing the machine is - The motor has gone / failed.
You could get someone to check the brushes on the motor, it's only a 30 minute job.
If the brushes are ok i.e more then 10mm long, I suspect the motor has burnt out if the machine is a number of years old.
Hope this helps
jb
Jun 22, 2009 | Indesit W 123 Front Load Washer
Flashing lights on my candy washing machine
Hello Mikana, i have a brand new one and it also flashes the 90 and stain removel had the Candy eng out and it needs a new heater...all the electric goes throught this heater and if it detects a problem then it shuts down...the ones they fit at the company are not vrey good so the replacement is going to be better....ring Candy ........also if it has a large load capacity like 8kg don't under fill it it may send the drum of centre and this will stop the machine....self protection built in...hope this helps...cheers Dave
May 25, 2009 | Candy CNW156 Front Load Washer / Dryer
All the red & green led's are flashing very dull
The problem is in the power supply circuit of controller PCB. Replace C9 (680uF/10V) with a new one.
Mar 21, 2009 | Washing Machines
Removal of front panel of a stack washer and dryer mod
Their are screws between the washer and dryer. Undo those and the screws inside the dryer, next too and below the lint trap.
Jan 17, 2009 | Maytag LSE7806A Top Load Stacked...
Ido not have a manual for this machine (WIDL126 ) and don't know
http://www.instructionsmanuals.com/u2/pdf/lavadora/Indesit-WIDL126-en.pdf
Nov 20, 2008 | Indesit Washing Machines
Indesit 1200 washer/dryer instructions
probable cause is just poor water flow from outside. switch water off. undo hoses and check not kinked. in each hose, there should be a gauze filter. clean this. look inside the valve spigot and check no dirt buid-up. put hoses in a bucket and check water flow is ok. remove drawer and check holes in top of box are clear
Jun 14, 2007 | Indesit WA 115 Front Load Washer
Indesit W 123 Front Load Washer Logo
373 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
