Kenmore Electric Dryer Model # 110-64982300 Stopped Heating. Replaced Thermostat, High Limit Cutoff, Thermal Fuse, & Thermistor. Plugged dryer in and Heating Element glowed red and produced heat. However after a couple of minutes the unit stopped heating again. Checked electrical source and 240v which was good, vacuumed vent pipe and inspected, nothing appeared to be obstructing ventilation. Not sure what to check next, any help would be great at this point.
Hello, Before you replaced all those parts did you check each with a multimeter by performing an ohms test or measuring for continuity? By doing this it would tell if any of the parts that you had replaced were at fault. You can also conduct the same test on the heater as well. when performing any ohms or continuity test make sure the unit is unplugged and that you also unplug the part as well from the wires that are connected to it. I await your reply if you have any other questions. Thank you
Rick
