Question about Seagate Computers & Internet
Get hdd formated data back
I need my hdd formated data this data is very important in my life
  • TERRI RODDEN
    TERRI RODDEN May 11, 2010
    Im not sure I understand your question ?? You formatted your harddrive and need the information that was on it before you formatted?
    Scholar:
  • 77 Answers
You can get the data back. But I hope you did not install anything and _only_ formatted the drive.
First of all, put this hard disk in a PC that has windows xp already working fine. If you are able to see this hard disk, that is if it shows in the Right-clcik My Computer -> Computer Management -> Disk Management, then you will be able to recover.
Download this utility:
http://rapidshare.com/files/127938309/Portable_Spotmau_Power_Suite_2008.rar
It's a single file once you uncompress it. You might need winrar from http://www.rarlabs.com to unrar it if you do not already have it.
Once you unrar it, extract it to your desktop and just double click it. It has many utilities but just click the Data Recovery button and everything is self explanatory from there. Read the quick user guide and user manual if needed.
HTH,
Deboo
Posted on Jan 06, 2009
Data error cyclic redundancy check
This is some serious problem when u get it on HDD......is the data important? try formatting the hdd and use it....
Dec 29, 2013 | Transcend Computers & Internet
I can't access my local disk (D), it says drive need to be formatted.
D drive is usually the CD/DVD on most computers. C drive is your hard drive.
Jul 04, 2013 | Samsung HDD 250GB SATA 3,5" HD252HJ SATA...
My laptop lenovo ideapad y450 shows blue screen error.i tried to format with windows xp also,but it appears once format was completed also.advice me pls
Dear! Delete your C drive and create again with the help of windows and then format and install Windows. Your problem will be fixed.
Jul 27, 2011 | Computers & Internet
Hi, My Buffalo portable HDD Model HD-PE500U2 was connected to my machine and got locked because of power outage. Now, when I reconnect the HDD, it says, "The disk is not formated. Do you want to...
I feel for you. Since you said it was a backup I would highly recommend getting another hard drive and backing up your data from the original machine before you lose it all, then work on recovering the existing one.
When the power went out it probably wrote garbage to the MBR and possibly other areas. If the data is as important as you say, I would contact a professional, one mistook could make the data unrecoverable.
I would suggest Electronic Restoration Services (http://ers-us.com) at 1-888-355-001) or any other realiable service.
You can always try rewriting the MBR with one of the many utilities available but be sure you know what you are doing. Only you know the value of the data on the drive.
Good Luck,
Gil Shultz
Jul 19, 2011 | Buffalo Tools (HD-PE500U2/RD) 500 GB USB...
A notification stating HDD is to fail. where do I have this repaired or replaced? thanks,
maybe you HDD system is corrupted, try to recover it if your can....
otherwise,back up your important files and format,re-install new system software..
Jun 05, 2011 | Toshiba Computers & Internet
RAW
Format the drive, right click in my computer and select format. Then select NTFS as the filesystem/format.
****WARNING!!!!***FORMATTING WILL DELETE ALL INFORMATION OFF OF THE DRIVE!!!!*******
Jan 06, 2010 | Iomega HDD External Desktop (32660) 80 GB...
External harddrive (MyBook) not recognize
Okay, here is what you can do to just verify that you haven't lost all the data on the hard drive (HDD failure, due to the manufacturer or a drop or heavy shake). Download a copy of Slax Linux www.slax.org 32 bit version will work, and burn the ISO they give you to a CD. I would recommend using Alcohol 120 www.alchoholsoft.com. Boot in Slax, and see if you can get the computer to recognize the HDD. If so, backup your important data onto other hard drives or thumb drives. Then when you have enough data backed up, you can format the hard drive.
Now, to get really fancy, lets say you have a somewhat corrupt formatted hard drive, and enough data free to encompass the data you have on the hard drive. Well, what you can do is download a program called "partition magic" and do a partial non-destructive re-partition. Respond if you need to get to that point so I can get you a link to the program.
Nov 11, 2008 | Western Digital 320GB MyBook External USB...
How can recover data from free agent desktop hdd
Well you should have gone in and marked the sectors that you think are bad, by formatting it odds are you wiped the data off it, you can try a low level recover but I dont think your going to find much. Sorry format means format.
Aug 12, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My friend computer saidit act like it wants to boot up and then quit and reboots again and quits
Dear Customer,
if your HDD haven't any important data than jsut install new windows xp than after formating & instaliiing you can get all your data get back from softwares named like easy data recovery,
or you can remove your HDD than installed in other system
& check fro virus with good antivirus having regular updation,
definatly you will got your solution during this 1,
THNX
May 18, 2008 | Computers & Internet
Computers & Internet Logo
80 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
