Hello i have a handstamp which has ink inside already, do you know if I can refill those handstamp ? thanks Tj
  • 34 Answers
Check a local hobby store and they should have stamp ink refill kits. I recommend Hobby Lobby or even Wal-Mart.
Posted on Dec 29, 2008
.i already refill the cartridge
Hello!
All Canon printer shows Low Ink Level after refilled. But, there is no problem and there is no error. So you don't need to worry about that. its nature ... thanks
Sep 13, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Dell 926 Printer ink refill instructions
*see the manual and follow the instructions and fill it
* contact manufacturer about details
Jul 02, 2008 | Dell 962 Photo All-In-One InkJet Printer
Hello, I have replaced the ink cartige with an kit refill ink, not with some original cartige. At first it worked, now it shows me that the Black cartige is empy even if if have made the refill. I do not...
all you have to do is to press and hold Resume button for more than 5 seconds, this procedure will by pass the ink level counter and your printer will work with no problem.
Jun 06, 2011 | Canon Office Equipment & Supplies
Printer does not print though properly connected
Hello there... Please check it's ink level. If it already has run out of ink then you replace the ink cartridge with a new one or refill it (refill is not advised to under warranty printers). Hope this helps. More questions, pls reply here... Ai-ai :)
Dec 03, 2009 | HP DeskJet 5650 InkJet Printer
HELLO! I HAVE A SHARP FAX MACHINE (UXA1000- INK CARTRIDGE UX-C70B)AND I WANT TO KNOW IF I CAN GET THIS CARTRIDGE REFILLED AT WALGREN'S STORES LIKE MOST CARTRIDGES.
You should be able to, but the problem is this:
they only refill it, if there is a problem with the cartridge it doesn't help.
there is more to just putting ink in a cartridge.
1- you must clean the inside removing dried ink
2-you must clean the nozzles tomake sure the ink can flow
3-replace any pads inside
4-refill ink
I have heard complaints about Walgreens so take your chances, a better solution may be a company called Rapid refill ink ( they do all the above to their ink crtgs)
Jul 30, 2008 | Sharp Office Equipment & Supplies
Ink cartridge question
Try Soaking the print head in Warm water for about 3 minutes. Dry off the print head with a paper towel. If you don't see any ink on the paper towel, then the print head is clogged and it will be difficult to unclog the cartridge.
If the warm water doesnt work, then next try some Windex with amonia. Only soak the bottom of the cartridge where the ink comes out. Soak the printhead for about 3 minutes, and then try wiping off the bottom again. Press a dry paper towel on the bottom. If there is no ink then it is probably time to get a new cartridge. In the future, always try to refill your cartridge right away as soon as possible so that the ink in the cartridge/print head doesnt get a chance to dry out.
I hope this helped.
Please leave a rating if I have helped you with your question/problem.
Have a good day and good luck.
Mac =)
May 20, 2008 | HP Easy Refill Kit for (HP) Black Inkjet...
Ink or printers problem
Most likely the ink cartridges for this printer have a chip on them. This chip tells the printer how much ink is left and when it is low or out, you must replace the whole cartridge otherwise if you just refill it, the chip will still report the same amount of ink as it doesn't go by the actual ink level inside the cartridge, it determines the ink level by calculating approximately how much ink has been used while it was printing. So it doesn't matter how full the cartridge is, unless you replace the cartridge or reset the counter on the chip somehow, it will still display the calculated amount not the actual amount.
Jun 10, 2007 | Compaq Armada M700 Notebook
Flashing ink refill light
Sometimes refilling them over and over doesn't work well. Once ok...but i suggest that you buy a new cartridge. I know that they are expensive but it will help. Also take some Rubbing alchohol and a q-tip...clean inside where the cartridge sits..that will help...this is for sure a bad ink cartridge
Feb 28, 2007 | HP DeskJet 810c InkJet Printer
126 people viewed this question
jasbo
jasbo
