Question about Amana Heating & Cooling
My thermostat has no power. the wires to it has no power. The fuses on the heater chip board are okay. What else can I do? Where can I locate the transformer to the A/C/Heater?
In the control box to your furnace or air handler, there should be a transformer near by.be careful though, it has high voltage going to it though.just follow the high volt wires, the large ones,from the wall plug to the machine, into the control box to the transformer or the fuse chip board.the big black wire will go to terminal L1 at the board and the white wire will go to nuetral at the board.unplug your wall cord first so you won't get shocked. it is hard to see into the control box and board connections.also, plug a light or lamp into he wall socket to see if you have 110volts to the plug.
do that for a split system.an airhandler wont have a wall socket.it will have a disconnect box with fuses in it.it is also 240volts so be carefull.
Posted on Dec 29, 2008
1993 Goodman gas furnace keeps blowing fuse when first turned on
You can take each thermostat wire off the control board and use a ohm meter and test to ground, should not have any resistance. Another way is turn off power take each wire off the board, then place one wire at back on the control board terminals ome at a time, untill the one you get to the one that blows the fuse. If the wires check out good sometimes the thermostat itself can have a internal short and cause the fuse to blow.
Nov 27, 2012 | Heating & Cooling
We have a honeywell chronothern iv plus thermostat heater/cooling system which is not working. We suspect it is a blown fuse problem. Do you have any pointers of where the fuse is located?
Hello, typically the fuse will be located in the control board. The control board is located inside the blower compartment, will be a 3-5 amp fuse. If the the thermostat is blank sometimes a condensate safety switch can kill power to tje thermostat if the drwin line is backed up. If no safety switch check the fuse or transformer.
Jun 30, 2012 | Heating & Cooling
Installing a Honeywell RTH2310B thermostat, only 4 wires but the unit will not turn on the fan or the air condition (heat pump). Orange wire, (O) blue wire (C), black wire (E) were not used. Jumper put in...
Hello my name is Heath it will be my pleasure to assist you. First thing to do is go to the furnace take off the lower blower door and locate the circuit board turn the power off to the furnace. In the circuit board there should ba a small car like fuse usually 3 or 5 amps check the fuse it is probably blown replace the fuse with the same amperage fuse and then turn the power back on on the furnace and check the operation of the furnace.
Sep 05, 2011 | Honeywell Programmable Thermostat Heater
Honeywell thermostat short and then went blank by mistake i short the thermostat with a wire and then became blank
Check the transformer in the air conditioner/heater. There should be a fuse on teh 24 volt side. Shut power off to the furnace. Locate and check the fuse. If there is no fuse, you probably destroyed the transformer.
Jul 17, 2010 | Honeywell Programmable Thermostat Heater
My air handler is blowing the 3 amp fuse on the curcuit board. what does it control
Its not what it controls but what it protects. It protects
the transformer. Disconnect the thermostat wires and mark where they go. Replace the fuse and turn the power on. If it does not blow the fuse the problem is in
your thermostat or thermostat wires.
Jun 30, 2010 | Goodman GMS80453ANA Open Flame Mid-Size...
Gooman heater connected to electronic lux 500 thermostat. no response from heater at all. tried changing batteries in thermostat.could thermostat possibly be bad. had both for approx.11 years
Remove t-stat and remove red and white wires and connect them, if unit starts then it was the t-stat.
If not go to furnace and remove same two wires at furnace and jump out at circuit board or connect wires FROM furnace, if it starts the problem is in wires.
If you have power to furnace?? and nothing happens it is either a bad board or inducer motor (little one) is not starting. Remember that their is a fuse on corcuit boards that need to be checked.
Feb 04, 2010 | Goodman GMS80903BNA Heater
My honeywell RTH230B won't do anything. I put fresh batteries in it, tried everything and nothing happens. What is the probelem and what can I do?
If this is a typical air handler unit then turn the fan switch to on, if the fan does not come on then you have a control problem or no power to unit. Check fuses/Breaker.
If fuses and breaker are ok then try this. Turn the power off to unit, try and locate control board usually
located in the lower panel where the blower might be.
Disconnect thermostat wires that go to probably
r/w/g/y/c and remember what color goes to where.
If you can make a jumper wire or you have aligator
clips, jumper r and w. Put door back on, turn power on and heat should start up.
You can also put a jumper between r ang g terminals
instead and the fan should come on.
If either of the two cases happen, then you need another thermostat or check wiring to thermostat.
Another possibility is that there could be a car fuse
located in the control board that is blown
Good Luck
Jan 12, 2010 | Honeywell Programmable Thermostat Heater
Mr. Heater Natural Gas Garage Heater - 45,000 BTU. Power 120 volt and 24 volt good. Thermostat calling for heat, but nothing happening??
Check for a fuse either in-line or on the circuit board. There should be 24 volts going to the thermostat. If not, you have either a bad transformer or a bad thermostat wire. Jump out the terminals that the thermostat wires are connected to. This should force the unit to fire. If not, bad circuit board.
Dec 23, 2009 | Mr. Heater Natural Gas Garage Heater -...
Heater and AC run even though thermostat is off
It sounds like you have a short in the control unit at the ceiling pack. Remove the inner shroud from the AC and pull down the control unit. Remove the cover from the control unit to access the relays. With the thermostat off, check for power at the white (or orange depending on the unit) wire coming from the thermostat to the relay board. Also check power from the yellow and gray wires from the thermostat to the control board. None of these should be hot with the thermostat off. If there is power then you have a short in the wiring between the tstat and the upper unit. If there is no power, then you have a bad control board.
Hope this helps,
Jeff
Rate please!
Jun 24, 2009 | Dometic Rooftop RV Air Conditioner
I have a Carrier 38tra048340 ac 4 ton unit outside, heater in attic. Thermostat is Totaline P374-1100. Power went out than back on after a few hours due to vehicle crashing into power pole. AC was running...
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Jun 23, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
278 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
