Question about Kenmore Elite 45986 Front Load Washer
F02 what does it mean
My washer is not draining or spinning on every load. It is displaying an F02 when it gets to the drain and spin part. I have unpluged and that did nothing. I just keep starting the drain and spin cycle over and over till it works again. Can someone tell me what the F02 means from the manuel?
  • 3 more comments
  • Anonymous Dec 13, 2007
    F02
  • Anonymous Jul 08, 2008
    error code f 02
  • mssharman Oct 20, 2008
    I am done with this machine. I HATE IT! Today, the problem is the F 02.....yesterday it was the F11. I keep resetting it to go back to drain and spin...it works for about 10 minutes and the....beep, beep, beep...F 02.....F 02. HELP
  • Anonymous Oct 24, 2008
    Mine doesn't drain all the way on any cycle, I have to repeat a drain/spin cycle to get the machine to finish.
  • WiseFun Jan 20, 2009
    F02 error. weak clicking noises instead of the normal stronge clicks when it use to wash correctly.
I have had this issue more than once. It was an easy fix for me (maybe a 20 minute job and best of all no money). For my F 02 error it was my 4 year olds socks that some how got down the drain line and stuck in the clean out. Here is what you do. There are 3 screws bottom of the front access plate. Remove these and the lower access plate will pop right off. Right in front you will see the pump and the drain line. It has a clean out right there. Unscrew the cap (be ready for alot of water to rush out, so have alot of towels ready). Once the water is drained remove the cap. The cap has a trap so that larger items do not get to the pump. This is where I find the socks stuck. Clean it out, tighten the cap back into place, put the access panel back on, and hit run. Has worked for me at leaste 3 times. Those pesky kid socks every time.
Posted on Nov 14, 2008
F02 is a drainage problem see codes here. There may be blockage in the drain tube or someone may have to go inside the machine to remove bockage befor the outside drain tube. good luck
Posted on Dec 13, 2007
    Novelist:
  • 114 Answers
THESE ERROR CODES ARE UNIQUE TO EVERY MANUFACTURER. MY BEST GUESS IS THAT YOUR LOADING DOOR SAFETY SWITCH IS BAD. IT IS THERE TO SHUT DOWN WASHER IF A SMALL CHILD OPENS THE DOOR DURING ANY MODE WHERE THE AGITATOR OR DRUM IS SPINNING. IT SHOULD NOT BE AN EXPENSIVE REPAIR SO BEWARE!!!
Posted on Apr 28, 2007
  • Joseph Reckinger
    Joseph Reckinger Apr 28, 2007
    THERE IS ALSO ON SOME NEW MODELS A LOAD BALANCE SENSOR THAT KEEPS YOUR WASHER FROM "WALKING ACROSSTHE FLOOR"
    ALWAYS MAKE SURE YOU NEVER GO OVER YOUR WASHERS SPECIFIED LOAD LIMIT. AMD MAKE SURE THE ARTICLES YOUR WASHING ARE EVENLY DISTRBUTED IN THE WASHER.
At the end of the normal wash cycle my washer begins to beep repetitively and shows an error code of F 02?. It will not spin and drain. We've began to switch it to Drain/Spin cycle and this works about...
Hi
Error F02 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Jan 30, 2011 | Washing Machines
F02
The f02 error code is caused when the unit control thinks there is still water in the tub after it has tried to drain. If the washer is full of soap suds it will also display an f02 error code. You will need to use only name brand HE detergent. If your washer is not draining the water out you will need to clean the pump filter. I have provided the instructions below. Run the washer in a drain and spin to ensure the pump is running. If the washer has no water and no suds the problem will be either the pressure switch or a plugged pressure hose. To check the pressure hose you will need to remove the top and remove the hose from the pressure switch.
Jan 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore Elite HE3 model 44832 200 washer. Will spin sometimes, but doesn't seem to get to full speed. Often won't spin at all and gets F02 error, but it does roll during wash/rinse cycles. ...
he F02 message is a long drain error and it may mean the pump is clogged or bad. You don't provide a lot of detail about if the water is draining out or not but the first thing to check for this error is the drain pump.
The image below shows how to access the pump and remove the filter. This may be your only problem. With the access panel removed you can also make sure the pump is running. Remember to unplug the washer before removing the access panel.
Check the pump for the F02 and make sure you're using HE detergent and there's not excessive suds.
Jan 20, 2011 | Kenmore Elite 45986 Front Load Washer
Keeps showing code f 02 and wont completely empty water it never finishes spin cycle?
F02 error means if the drain time has exceeded more than 8 minutes. After four minutes suds will be displayed on the screen and again after 4 minutes the F02 error code appears.
Check the drain line for any clogs or blocks which hinder the draining procedure..Use of more detergent can even cause this condition..
Be sure you are using only 2 tablespoons of HE soap and not more than that. Check your drain filter also and replace them if needed.
Remove the 3 Torx head screws (located left, center, and right) from the front bottom kick panel of the washer. The drain/filter/pump is right in front
Jan 18, 2011 | Kenmore Elite 45986 Front Load Washer
During the Normal washing cycle. 02 F appears. and cycle stops. Cycle hasn't finished rinse or spin.
Hi
Daniel
Jan 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error Code 02 F. Won't rinse, drain, spin
Check the drain line for any clogs or blocks which hinder the draining procedure..Use of more detergent can even cause this condition..Be sure you are using only 2 tablespoons of HE soap and not more than that.
Check your drain filter also and replace them if needed. Remove the 3 Torx head screws (located left, center, and right) from the front bottom kick panel of the washer. The drain/filter/pump is right in front.
Dec 04, 2010 | Kenmore HE2 Plus Front Load Washer
F 02 I reset it to drain and spin for the first load. already took the bottom panel off and cleaned out the white container. still not working for the second load, still flashing F02.
f02 means long drain. something is stopping it from draining. takes the pump out and look in at the impeller, something could be caught in it
Feb 06, 2010 | Kenmore Elite 45986 Front Load Washer
I have a GHW9100LWl washer. It sometimes flashes F02 and stops. Alson when it is in the spin cycle, it is very loud and had a knocking sound. Please help.
Hi
F02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
What does the "sud" message mean?
hello fo2 means if the drain time exceeds 8 minutes the water valves are turned off and f/02 flashes. things to check / check the drain hose for any kinks and blockages check the electrical connection to the pump make sure the pump is running / check the drain pump filter make sure its not block if these do not sort the problem replace the pump. to clear the display press pause and cancel to clear good luck
shaun
Mar 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Get error code f02
Long Drain
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
to resolve
Mar 02, 2009 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
Kenmore Elite 45986 Front Load Washer Logo
454 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
