I want to establish a local area network. my question is, what should be the maximam lenth of cat5 cable between switch to computer???
  • 46 Answers
The maximum length (maximum certifiable length) for CAT 5 patch or crossover cables is 328 feet (100 meters). Beyond that, you run the risk of signal loss and other complications.
Posted on Dec 29, 2008
I need networking cables, which cables are best for use.
CAT6 cables & jacks are better than CAT5E.
CAT5E cables & jacks are better than CAT5.
CAT5 cables & jacks are better than CAT3.
CAT3 cables have problems going faster than 10Mbit/second.
CAT5 cables support 100Mbit/second, and seem to work with 1000Mbit/second ("gigabit") devices.
Apr 01, 2014 | Computers & Internet
Setup belkin wireless network
1.Connect a Cat5 cable into the Ethernet port on the back of your cable or DSL modem. Plug the other end of the cable into the "Connect to Modem Internet/WAN" port on the back of the Belkin Router.
2.Connect a Cat5 cable into the "Ethernet" port on the back of any desktop or stationary computers and then plug the other end of the cable into one of the LAN ports on the back of the Belkin Router. Start with port one and work your way up with subsequent computer connections.
3.Turn the Belkin Router on by plugging the router into a power outlet. Allow 30 seconds for the router to fully boot up. All computers tethered to the modem via a Cat5 cable have access to the Internet.
4.Open the Wi-Fi Wizard on your laptop and turn on the Wi-Fi antenna. Once turned on, the Wizard finds all network connections in your area. Connect to your network to establish an Internet connection. Complete this step for each computer not tethered to the Belkin Router with a Cat5 cable.
Thanks for using Fixya
Oct 04, 2010 | Computers & Internet
Switch to switch connection
in the 1st end of your cat5 cable the color codes are: white orange, orange,white green,blue,white blue,green,white brown,brown and in other end codes are: white green, green, white orange, blue, white blue,orange,white brown,brown....gud luck
Jan 16, 2009 | PC Connection Cross-Over Cable (363003X)
Transfering data from one computer to another
I think there is no way to do that. You CAN do it, however, with a crossover cable. It looks the same as a regular cable, but it's not. With the crossover cable, just connect the two computers and give 'em two IP's in the same network. Then enable file sharing and it should work. Sorry, I can't go into much detail because I haven't done that in a looong time, but I think that's about it. Hope it helps.
Sep 11, 2008 | Cat5e Computers & Internet
Buffalo-N Nfinity WZR2-G300N Router Setup
Work and play - further and faster! Your AirStation Nfiniti combines Ethernet networking with extended wireless range and speed. It offers excellent compatibility with most wireless clients, giving superb performance with Wireless-N, Wireless G, and legacy Wireless-B clients. For best overall performance, use with Buffalo Technology Nfinity wireless clients. System Requirements: • A high-speed (Broadband) Internet connection or existing local area connection. • A computer with a network connection (wired or wireless) and a good web browser. The screenshots in this manual were taken with Firefox, but Netscape and Internet Explorer are also supported in versions 4.5 or later, and Safari 1.0 and later are supported with Macintosh OS X 10.2 and later. Package Contents: • WZR2-G300N AirStation with built-in antennas • AC adapter • CAT5 LAN cable • Utility CD with Manual • Quick Setup Guides • Warranty Statement
see link for details and a fix for your issue
Jan 02, 2018 | Buffalo Technology WHR-G54S Wireless...
Difrence of lan wan
The Lan limit on unshielded twisted pair cable (UTP) is 300 ft for a local area network (lan). The cable uses the 802.3 Of course if fiber is used in a LAN then this # can be extended substantially.
Now the main difference between the LAN and Wide Area Network (WAN) is that LANs typically have 1 brodacast domain and froward packets at data link (layer 2 of the OSI) level using MAC addresses.
The WAN operates at the network level (layer 3 of the OSI). WANs are and reads IP addresses. Routers can extend far distances (as you said 40-60km) and band with depends on distance. the further away, the more attenuation on the line.
I hope this helps.
A wide area network
Jul 10, 2008 | Computers & Internet
Network cable stopped being recognized
rj45 (cat5) sockets have 8 internal tensioned wire prongs, (six are used for cat5 ethernet)
use weakens the tension and they can be dislodged sideways vertically or disconnected from the internal cabling. Likewise solder connnections to the motherboard fail.
a possible fix is to power down the pc, and with a jewellers screwdriver ensure that all the internal wires are present, straight, aligned, and protruding across the opening.
If there are missing wires(broken) then the rj45 socket shoould be replaced at your local pc store, (not walmart)a796c91.jpg
Jun 28, 2008 | Sony VAIO PCV-RZ40C1B PC Desktop
PC2716 Connectivity
Goto start
Open control panel
Open network connection (XP)
Right click on Local Area connection
Goto properties
click on Internet protocol TCP/IP
Click on properties
Try to change the Ip address on that window
If it does not make any difference then TRy to disable the firewall that is installed on the computer.
Jun 04, 2008 | Dell PowerConnect 2716 16-Port Gigabit...
Computers & Internet Logo
190 people viewed this question
David Payne
David Payne
