Question about Uniden BC60XLT Handheld Scanner
On my scanneri have trunking what is that
Hello
  • 120 Answers
Trunking is a system where many radios use a few channels, the radios scan through the channels and find one that is not busy, then when you key up the transmitter it sends out a signal to the other radios in the group and switches them to the same frequency. There are at least 3 different trunkings systems that i know of, maybe more by now, but this is a basic explanation of how they work.
Posted on Jan 02, 2009
Trunk latch keeps opening
hello,do get the micro switch(trunk release button) checked,as most commonly they short to ground and keep releasing the trunk,if at all possible,detach the switch from the trunk(provided that you have another mechanical means of opening the trunk)otherwise,use a thin blade screwdriver to physically push the locking latch on the trunk,after you have detached the button,and if it stays locked,you then know that it was the switch,failing that,replace the lock assembly on trunk.cheers,,hope this helps.
Jun 24, 2014 | Galaxy Vehicle Parts & Accessories
3.8 engine ligth check engine on,Idid scannery the results code trouble P1651Buick 1999,le sabre 3.8 engine light check engine on,sccaner result code P1651,change realy and light still on
Hi there:
DTC P1651 - Fan 1 Relay Control Circuit (Buick)
Could be a fuse is blown to one of the coolant fan motors.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 10, 2012 | 1999 Buick LeSabre
2004 mercury mountaineer side mirrors don't work
Fuse,Switch or Control Knob,Mirror Motor or Module
if one applies
Don't know if you can control or check with a scanner
I would have to look at my software to see if ford offers that
Aug 03, 2012 | 2004 Ford Escape
My trunk wont open what key do i use nether will my gas tank door
Hello: Please check the valet switch in the glove box if it is on, turn it off and try the trunk and fuel door. Also there are 2 fuses for this system. The fuses are in the trunk compartment fuse block. They are labeled as follows:radio/phone fuse 10 amp and convenience fuse 20 amp. The round key should open the trunk, if not then it might be the wrong key or the trunk lock cylinder may have been replaced.
Nov 03, 2010 | 1996 Cadillac DeVille
The trunk won't open w/ remote or elct. sw. only
Hello. Chances are that the Unlocking mechanism in the trunk is either out of alignment or broken. Take a close look at it. It is where the trunk lid actually latches and locks. See if it is loose, or bent, or broken.
Nov 11, 2009 | 1997 Dodge Intrepid
Hp psc 1210 It says no scanner found ?
as the copier works its not a hardware concern.if the scanneris not found it means the drivers are not installed properly.Try uninstalling the drivers completely from the device manager as well as the printer and faxes and the scanners and cameras(if possible delete the ebtries in the registry as well that are related to the software and the VID and PID keys from there).Then try a plug and play.....see if it works....
Jun 24, 2009 | HP PSC 1210 All-In-One InkJet Printer
Dead Battery on MB c230, how do I open trunk?
hello,you can open your trunk by your mechanical key,then red cable to positive and black to negative,ty
Apr 18, 2009 | Mercedes-Benz C230 Cars & Trucks
Automatic trunk lid closing device stopped working.
Get a trunk pull down switch from a dealer. This will fix it.
Apr 18, 2009 | Buick Riviera Cars & Trucks
Uniden BC60XLT Handheld Scanner Logo
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
