Question about NorStar M7310 Corded Phone
Phone not working. "Shifted" is displayed. Buttons do not work.
One of our many telephones is not working. The message "shifted" is showing on the display. None of the buttons work but the phone can be called from another internal office phone.
There is a triangular button on the phone, there might be a light on it. That is the "shift" button for the "Speed dial buttons". They have 2 "positions on each, normal and "Shifted"
Posted on Jan 02, 2009
Screen shifted to the left
boot in (safe mode) Hold F8 when restart in safe mode right click anywhere on desktop change display mode
Should work
gl the ed
Mar 12, 2015 | Samsung SyncMaster 2333HD
Tip
How To Fix Your HP Fax Phone Off Hook
<ol> <li>If you don't know your product number, <a href="http://h20270.www2.hp.com/ediags/gmn2/welcome.aspx?lc=en&cc=us">click here</a> to automatically detect it.</li> <li>Manually download your drivers by <a href="http://h10025.www1.hp.com/ewfrf/wc/siteHome?lc=en&dlc=en&cc=us&lang=en&softwareitem=oj-40521-2&os=228">clicking here</a>. Enter your Printer Model Number, e.g. Deskjet D2680</li> <li>Unplug the power cord from the back of the printer and from the wall outlet. Reconnect the power cord to the wall outlet, but don't connect the power to the printer just yet.</li> <li>Perform a partial reset by disconnecting the power cord from the wall. Then, hold the # and 3 while reconnecting the power cord. Release the buttons once the cord is plugged in. When you release both buttons, the issue should be resolved.</li> <li>Perform a semi-full reset if the partial reset did not work by pressing and holding # and 6 while reconnecting the power cord to the printer and hold for 1 min after plugging in the power cord. When you release both buttons, the issue should be resolved.</li> <li>Verify that the phone cables are properly inserted into the wall jack and the back of the printer if you are receiving a "Phone off the hook" error message.</li> <li>A Phone Off Hook message indicates that the telephone line is open. This message would be expected in the following situations:</li></ol> <ul> <li>A modem on the phone line is accessing the Internet. When the other device is no longer using the phone line, the display should revert to the normal message.</li> <li>A phone connected to the HP fax (or the same phone line) is using the line, or the handset has been lifted.</li> <li>A credit card machine is using the phone line.</li> <li>Another electronic device is using the phone line.</li> <li>Telephone Answering Machine using the phone line</li> <li>The Start Fax button was pressed with no telephone number entered. Pressing Stop or Cancel should return the display to a ready state.</li></ul>Check this website for further help from HP: <a href="http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00322712&cc=us&lc=en&dlc=en&product=441125">http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00322712&cc=us&lc=en&dlc=en&product=441125</a>
on Feb 22, 2011 | Office Equipment & Supplies
Motokrzr k1 display shows white blank how do i got
Hi there
The problem with your phone is the flex,
The flex is a cord that connects the screen to the phone panel,it is found in all flip and slide phonesthe flex of your phone has either shifted position or is too weak..
Try opening up your phone,you will see a cord that connects the screen to the panel of the phone. try removing it(be very careful) and fix it back in place.
Assemble the phone and put it on to see if works,if it doesnt work then the flex has to be changed for your screen to come up again.
Please if you can do this yourself you should get a person with experience to do it for you
GOODLUCK!
Jul 08, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
I bought a toyota vista ardeo with shiftmatic on the steering wheel and I dont know how to use it.kindly help.
Hi, i have the same kind of Ardeo and this is how the steer matic shift works.
Stop vehicle and shift gear lever to DRIVE position then press on the steermatic shift button and M will high light above the top of the semi auto shift high lighter to show that you are in the steering wheel gear shift manual mode.At this point you can use the down shift buttons on the front part of the steering and the up shift buttons on rhe rear side of the steering.the down shifted or up shifted gear will high light on the dash.if you want to boot back to semi or automatic drive press steermatic button again.ENJOY YOUR DRIVE
Jul 01, 2010 | Cars & Trucks
Whenever we enter into to operate the camera in the display we are shown that operation failed
Hi,when ever you enter into to operate the camera and it displays operation failed,it means that the camera is faulty or is not connecting properly.
You can check if the camera has shifted by loosening the phone. After checking it if the camera has not shifted and doesn't still work,you will have to replace the camera with a new one.
Good luck.
Jun 28, 2010 | Cell Phones
My phone shows a dark screen when turned on. it's nokia 6124c
Hi, when a phone displays a dark screen,it means that the screen of the phone has shifted or has stop working.
Unscrew the phone to check if the screen shifted. adjust if shifted.
But if not shifted, that means screen will be replaced.
Take care.
Jun 02, 2010 | Nokia 6124 classic Battery
Phone was dropped and I can no longer use the key pad buttons. other buttons on the front face, eg menu buttons are working.
When a phone drops on the flow it can develop a problem from anywhere in the phone.
You can check the flex of the phone and see if it has shifted from the position it was. After checking the flex of the phone, you can also check the from board where the screen is.
The place that my have caused the keypad not to function will be from the flex of the phone.
Take care.
Mar 24, 2010 | O2 Samsung SGH-E250 Cellular Phone
My entire monitors display was shifted to the right (half is off screen) when I accidently pressed the auto select button instead of the off button (on the monitor) HOW can I get it BACK to where it SHOULD...
It sounds like you just shifted the whole display over. I don't know how your monitor works exactly, but you should be able to use the buttons to navigate through a simple menu system, and either pan the display back to the left, or just reset to the default settings...
Mar 21, 2010 | HP f1905e Monitor
Cannot show hidden text in Word
Select the text you want to hide. On the Format menu, click Font, and then click the Font tab.
Select the Hidden check box(under Effects) .
Note To view hidden text on the screen, click Show/Hide on the Standard toolbar (toolbar: A bar with buttons and options that you use to carry out commands. To display a toolbar, press ALT and then SHIFT+F10.).
In order to display Standard toolbar:
 On the Tools menu, click Customize.
Click the Options tab.
Under Personalized Menus and Toolbars, select the Show Standard and Formatting toolbars on two rows check box.
under the file, edit, menu, insert format you will see the standard toolbar at the exterme right just beside Read, ?, box showing in percentage(100%) you will find and symbol just place the mouse cursor on it will show "show/hide".
Q) The only other problem I have met is that the keyboard cannot be shifted to Spanish language.
A)In Microsoft Windows XP 2002 , on the Windows Start menu, point to All Programs, point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office 2003 Language Settings.
I
Click the Enabled Languages tab.
In the Choose the language that defines default behavior in Microsoft Office applications box, select the language you want, and then click OK.
A message appears describing the effects of the change. To continue, click Continue and lose customizations
 now when you enter in word document click Tools----->Click Language---->Language settings and select the language and click default and then continue....
Thank you
M. Sridhar
Dec 31, 2008 | Microsoft Office XP Professional OEM w/...
Phone not operational
Dec 29, 2008 | NorStar Meridian M7310 Phone
NorStar M7310 Corded Phone Logo
263 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
