Question about PANDIGITAL 7" Digital Photo Frame With Interchangeable Frames
Memory stick I transfered photos from the memory stick from my sony cybershot, but i can't figure out how to get the sstick out of the port.
I had this too and after using a pair of tweezers on the two frames I bought I put a small piece of masking tape at the end to pull them out.
Posted on Dec 31, 2008
  • 34 Answers
There is either a lever to push or you simply push the stick in further to activate the spring release.
Posted on Dec 29, 2008
How to transfer pics to computer
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Jun 12, 2012 | Sony Cybershot DSCW310 Digital Camera
My Sony memory stick pro duo magic gate mark 2 is not shows images on pc but in my camera, but the photos are visible on Sony cybershot camera
Some Sony Cybershot camera's have a small amount of memory built into the camera. Double check that the camera is set to put the pictures onto the memory stick.
If the camera is set up correctly, the memory stick may not be formatted correctly for your computer. If at all possible, connect the camera to your computer directly with the USB cable that should have come with it.
May 31, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
How to transfer pictures from computer to camera memory card?
Below is how to transfer your photos incomputer to a memory stick in Windows XP operating system 1. Insert the memory stick into a compatiblememory stick reader. Plug the memory stick reader, with the memory stickinserted into it, into the computer's USB port. 2. After a moment, a screen thatsays "Removable Disk" will pop up and prompt you to take an action.Click on "Open folder to view files using Windows Explorer." Thiswill open the folders on the memory stick. Select and open the folder whereyour photos are stored. 3. With the memory stick folderand the photo folder open simultaneously, use the mouse to click-and-drag thephotos to the memory stick folder. 4. Close all folders and removethe memory stick reader from the USB port. 5. To ensure that your photos havebeen transferred, plug the memory stick back into the USB port. When the"Removable Disk" screen pops up, select "Open folder to viewfiles using Windows Explorer." Once you see the photos on the memory stickfolder, you can close the folder and remove the memory stick reader from theUSB port.
Jan 08, 2011 | Fuji FinePix J10 Digital Camera
Is it possible to transfer the photos I took on my Cybershot camera onto my memory stick?
To copy the images from the Internal Memory of the Camera to the Memory Stick select the COPY option from the Memory Stick Tool Menu of the Camera to OK.
To select the Copy option, press MENU-->SETUP-->MEMORY STICK TOOL-->COPY-->OK.
The copy option will copy all the images in the Internal Memory to the Memory Stick in the Camera.
Thanks for using FixYa
KenSolutions
Dec 06, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
How to get pics off the sony cybershot 10.1 pixel camera - there is no usb port - and the sd card won't fit in my computer
Treat yourself to a mulicard reader. Ensure it reads the Sony memory stick your camera uses. It should come with a USB cable to connect the reader to your PC.
They're not terribly expensive, photo retailers or ebay should be able to supply.
Mar 29, 2010 | Sony Cybershot DSC-T77 Digital Camera
New sony cybershot camera with a sony memory stick
Hook one end to the computer the other to the camera, turn the camera to review picture mode
Open up my computer, look at the external drives, you should see the camera after a minute or so.
Click and drag
Mar 06, 2010 | Video Cameras
Transfering photos from my compuer photo gallery to my camera
Make sure photo files name must be under DSC00001 to DSC99999
connect your camera to computer, click My Computer, Removable Disk, Folder and copy photo files from computer and paste in that folder. If file name is different, camera will not show it in playback though file is in memory stick.
May 18, 2009 | Sony Cybershot DSC-T200 Digital Camera
Sony Cybershot - the memory stick is full
More than likely the camera still thinks the photos are on the stick, especially if you deleted the images while it was hooked to the computer. I would safely move the rest of the photos off the stick onto your computer then format the card through the camera and with the camera disconnected from the computer. this should clear the card.
Feb 03, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
Memory stick - delete all photos
Need to delete pictures of a Sony Cybershot DSC_W90 and can't find book. Need help
May 15, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
PANDIGITAL 7" Digital Photo Frame With Interchangeable Frames Logo
44 people viewed this question
Top PANDIGITAL Audio Players & Recorders Experts
Tom Chichester
d3yavu3
Are you a PANDIGITAL Audio Player and Recorder Expert? Answer questions, earn points and help others
