Question about Panasonic DMR-ES10 DVD Recorder
Tray will not open
Greetings, my Panasonic DMR-ES10 DVD recorder tray will not open. I opened the unit, and the RUBBER BAND that drives the tray to open is broken. Can I buy replacement RUBBER Band anywhere? Thank you Pal369
  • Anonymous Mar 21, 2014
    changed a faulty capacitor as machine failed to start up one morning. Then found out after some tests that a capacitor had failed. Replaced it with a new one and everything was fine until I updated the Freeview channels now the dvd don't open or shut. It is telling me I must press remote to activate the dvd drive. Just wandering if anyone has had or heard of this problem. Also had to order a new remote control as mine is damaged but is it worth buying one or is the recorder totally broken and not worth wasting the money.
Thank you for your help, but like I stated, the rubber band, (belt) that drives the gear to open the tray is BUSTED. Found a place that sells them, will replace this week end. I don't think holding any keys down will open the tray, since it's driven by the belt from the tiny motor. Thanks.
Posted on May 04, 2007
Didn't read your problem properly. Sorry
Sorry - forgot to mention. You need to hold "Stop" and "Channel Up" buttons for 5 seconds. Tray will then eject. Also - May be in manual "Troubleshooting guide/Operation/Cannot eject disc". Had same problem myself once and searched internet for solution.
Posted on May 03, 2007
Put the machine in standby mode (ie switch power button on machine or remote) then, press and hold the STOP and CHANNEL UP buttons simultaneously. This will force the disk tray to open.
Panasonic DMR-ES10 DVD Recorder- does not read discs
this unit has an optical-eye, not recording heads. opening the drawer then unplugging unit will expose the eye. never look into the eye when unit has power. this x-ray can and will burn your owh eyes lens&retina. good luck. clean with 90% isopropyl alcohol and q-tip. mch
Mar 08, 2009 | Panasonic DMR-ES10 DVD Recorder
DMP-BD30 Blu Ray Player Disc tray will not open. I tried unplugging and also the instructions in the manual to open the tray. No Luck.
WHEN THE UNIT IS SWITCHED OFF, press and hold the STOP (black square) and Channel Up ( /\ ) buttons ON THE UNIT for 5-10 seconds. It takes longer than you might imagine and the unit does, of course, still need to be plugged in and power to be available for this to work!
Mar 01, 2009 | Panasonic DMR-ES10 DVD Recorder
No user guide
hi....Download instruction manual of DMR-ES10 by clickiing this link http://service.us.panasonic.com/OPERMANPDF/DMRES10.PDF. It is PDF file and can be open / print through adobe reader . for adobe reader, go to www.adobe.com.
thank u
rate me
Feb 08, 2009 | Panasonic DMR-ES10 DVD Recorder
Instrucion manual dmr es10
Download instruction manual of DMR-ES10 by clicking Panasonic Support. It is PDF file and can be open / print through adobe reader.
Good luck.
Jan 14, 2009 | Panasonic DMR-ES10 DVD Recorder
Panasonic dmr es15 dvd recorder
My Panasonic Recorder DMR-ES10, will not play discs sent to me from the U/K,
using a L.G dr275 recorder, onto a DVD+R disc, how can i overcome this problem. regards Tom Escott.
Aug 30, 2008 | Panasonic DMR-ES10 DVD Recorder
DVD Recorder/player
Go to an electronics store and purchase a DVD drive cleaner. They have recorded operation instructions.
Aug 20, 2008 | Panasonic DMR-ES10 DVD Recorder
Stuck in self check mode
Manually pull down the front shield, then somewhat forcefully pull down the inner shield and maybe two little white pins so the tray is exposed with nothing blocking it. Have someone plug the machine in while you are holding everything out of the way and the tray should start to open. Pull your fingers out quickly so you don't block the tray from sliding out.
Mar 16, 2008 | Panasonic DMR-ES10 DVD Recorder
Panasonic dvr,
If you hear the motor whirring then the drive belt may be broken. Pushing the buttons will not work. Someone will have to open it, remove the disc and replace the belt (if it's broken).
Feb 17, 2008 | Panasonic DMR-ES10 DVD Recorder
Dmr-es10 dvd recorder panasonic
does it record?We have noticed that these problem is occured by dirt on optical .First you have to clean optical lens .take cotton sworb and open the dvd-ram assy ,open top cover and claen leser.If problem still persist than only solution is to change dvd-ram drive thats optical assy.
Dec 18, 2007 | Panasonic DMR-ES10 DVD Recorder
PANASONIC dmr-es10
The DVD RAM drive is mis-aligned and does not load the disc correctly.
contact our local service center for a quote
Dec 14, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-ES10 DVD Recorder Logo
461 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
