Question about Indesit WA 125 Front Load Washer
Winding sound, with a smell of burning
I have a indesit front load washer, i turned it on all i get is the water not loading but a winding sound and smell of burned rubber. I stop the washer and find that half the clothes are wett and the other half dry.its just a consant winding sound and nothing else happening.
  • 34 Answers
I recommend to stop the use of the dryer immediately and call an expert repairman to your home. The smell of burning can only mean bad things, so better safe than sorry.
Posted on Dec 29, 2008
My LG washer stopped mid-load at spin cycle, how can I fix this?
It sounds like a serious fault if there is no power the fuse has gone or some item has burnt out . You will have to arrange for a service engineer to look at it more closely.
Apr 28, 2015 | LG WM-2277HW Front Load Washer
Electrical/rubber odor when load is complete
Not many machines are belt driven these days, but the symptoms are those of a slipping belt, or friction against a failed rubber mount.
To find out more you will need to remove the case (or enough of it to see what happens while it is working.
Be on the lookout for some rubbery thing (either a part, or something from a previous load) jammed somewhere where the rotating drum scrapes it.
A burning rubber smell is different to a burning motor windings or transformer smell but maybe only to afficionados. Could be a winding failure on the motor too.
Unplug, un-case and plunge your schnozz into the works seeking the odiferous source. Sounds like I am kidding, but I am not - really try it. You may need to dry run it for a while to elicit the smell before unplugging etc.
Please post how you go, and what it eventually turns out to be.
Feb 03, 2018 | Bosch WFMC 3200 Front Load Washer
Screeching sound; smell of burned rubber
What is the model number of the unit?
Oct 31, 2012 | Washing Machines
Every time i start the machine it keeps filling with water and won't stop then there seems to be a burning smell wot is the problem? its a indiset we125
Sounds like it could be a sticking inlet valve, or the pressure switch is not working that controls the water level, could be a blocked pressure chamber, this is located at the bottom rear of washer.
Jan 16, 2010 | Indesit WA 125 Front Load Washer
Won't fill, drain or spin out properly. Error Code od on panel. Sounds as though pump is running but no water drains out. Also, no water runs into machine when it is started.
sounds like you might have a broken belt. If there was a time you might have smelled rubber burning. The belt will stop all the above mentioned.
Dec 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer won't do anything but fill.
It is very likely that the motor has burned out. What happens is that the water solenoid allows water to fill to a certain point where a fill sensor stops it. The program then moves on to activate the motor which will agitate the wash. So when power is supplied to the motor, it tries to start, overheats because of a break down of insulation in the windings, and you smell burning. Replace the motor.
Nov 18, 2009 | Maytag Atlantis MAV6260AWW Top Load Washer
Maytag washer sounds like a jackhammer when rinsing - this is a new thing with all loads. Yesterday it shut down mid cycle while still full of water and we smelled a burning rubber smell. Any ideas?
There is only one belt on the machine (the burning rubber smell, probably). Sounds like something is wrong with the clutch /drive mechanism. Unless your an accomplished DIY'er, it sounds like a job for the Maytag Man.
Sorry.........................
Sep 15, 2009 | Maytag PAV2300 Top Load Washer
Maytag top load washing machine leaking water from bottom
The machine is leaking water from the bottom, I think the leak is in the area near where the motor is mounted. Before we noticed the water comes from underneath the washer, we smelled like burning rubber.
Al Bana
Jun 26, 2009 | Maytag PAV2300 Top Load Washer
Drum filling with dirty water
hi as your machine got a non return valve on it to stop water from getting into your machine via waste pipe. worst case is call indesit as i am sure you now get 5 years parts g/tee as indesit is now part of hotpoint still cheaper than another machine hope this helps
Jul 11, 2008 | Indesit W 123 Front Load Washer
Indesit WA 125 Front Load Washer Logo
349 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
