Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loading Washer Model GHW 9200 LW
Washer is level but still lots of vibration during spill cycle. Drum looks like it's out of kilter when spinning. Do you have a visual of how the gasket should look like as it seems ours may not be correct.
What shoul I need to fix when the light sensing on and the dryer does not start ( it still hot ) .
Whirlpool dryer GEW9200LW
reply to
Posted on Aug 18, 2009
How do you fix a Whilpool Duet frontloader GHW9400PL0 that is loud during the spin cycle?
There are bearings on the drum that go out and sadly on the WP Duets, they aren\'t replaceable. You have to purchase an outer rear drum and replacing them is annoying. There are lots of youtube videos but unless you find a used one for parts, you will spend about $300 just on the drum and the labor for it will be ridiculous.
Aug 06, 2014 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool duet ghw9250 smells like burning rubber and very loud
Does the drum turn, if not then the drum bearings may have siezed.
Dec 30, 2012 | Whirlpool Washing Machines
After our move, the drum has a lot of play and vibrates loudly during spin cycle. Seems to have come off of one of its mounts, perhaps. Sadly, we failed to reinstall the drum stabilizers for our move.
You can take off the lower front panel (three small screws by the floor ) and inspect the 4 shocks for proper operation it sounds like maybe one has come loose
Oct 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Excessive vibration while on spin cycle.. front loading washer
first make sure the washer is check the floor to see if it gives,try placeing a 3/4 " plywood under the washer.
Jan 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Drum shakes during spin cycle
I have a 7 year old duet washer. It started to shake during the spin cycle. It is level and the shocks and springs holding the drum are working. When the washer gets to the spin cycle, it is apparent that the drum is off center.
I tore the machine apart and found that there is a bracket at the back of the drum. This bracket sits in water so it was covered in slime. I found several large cracks in the bracket. Once these cracks occur, there is now way the drum can spin correctly. The bracket is welded to the back of the drum, so it has to be completely replaced.
What a poor design. I would guess that many, many other people will be seeing the same problem within a couple years. I was lucky in that I did not pay for a repairman to try to fix it.
Oct 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Is there a way to increase the water level on a whirlpool front load Duet washer model GHW-9150
If the machine is underfilling, check the water level switch. This diaphragm like device has a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the tube and when it reaches a certain level, it activates the switch to shut off the water and signals the timer to advance to the appropriate cycle. Make sure the plastic tube has no damage or obstruction. An obstruction can cause the switch to be activated too early.The switch can be tested for continuity using a multimeter or ohmmeter. A lack of continuity would indicate a faulty switch. Hope this helped and best wishes.
Aug 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
We have a Whirlpool Duet HT washer Model GHW 9200 LW The washer is level however during spin cycle vibration is very bad. Do you have any suggestions? What should the seal connecting to the drum be very...
It appears your vibration damper has failed in this instance.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control locked on ghw920 can u help me unlock
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Jul 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
620 people viewed this question
Dan Webster
Dan Webster
Sal De
