Question about Plumbing
Changed filters on Whirlpool Reverse Osmosis and now water leaks.
What would cause the water to leak out of this hole now.
    Novelist:
  • 148 Answers
The tube going from the ro cartridge is clogged or the drain tube going from the faucet to the drain p trap is clogged
I have installed many ro systems a=nd have had that problem Not only do youhave to replace the filters but make sure the drain hoses are clear
use a pipe cleaner or a a stiff wire
I also remove the connection going into the ptrap and clean back to faucet...it is usually real nasty
Posted on Dec 30, 2008
Leaks on the top of black box of culligan water softner under sink system
Is this a reverse osmosis drinking water system? If it is it is an H8 RO. If so shut the water off that feeds the RO. The leak is probably coming from one of the fittings, they can be cut by the compression fittings and leak.
RJ
Feb 13, 2011 | Culligan Under Sink Water Filter
I have a GE smartwater reverse osmosis system model number GXRM10GBL02. Water leaks daily from the small hole on the faucet on my counter top. Any idea why water comes out that small hole? Otherwise the...
That is the drain for the reverse osmosis system. You have what is referred to as an AIR GAP faucet. The waste water is pushed up there before it goes to drain just as the drain for a dishwasher does. If water is coming out of the faucet the drain is most likely plugged or the line is kinked causing water to back up and overflow. Check the drain line for kinks and clean out the drain where it attaches to the stand pipe.
RJ
Oct 22, 2010 | General Electric GE SmartWater Household...
Ice maker mal-formed ice
no "slug" is available however you could just use a reverse osmosis diaphram pressure tank to boost the water pressure. you can also use a water supply tube to bypass the in-refrigerator completely.
Jul 22, 2010 | KitchenAid Superba Architect KSCS25IN Side...
Water filter system leaks at tap
The line from the faucet to the drain was plugged. I cleared the line and the system is working well.
Apr 14, 2009 | Plumbing
GE smartwater R.O. system making noise from hole on side of fauce
Probably some gunk clogging the drain line. First step would be to remove the drain line from underneath the sink and check to see that it is clear. If it isn't, the next thing that may happen is when it gets completely clogged, water will start shooting out of the weep hole. As an added measure< i would say to force compressed air down the weep hole to clean out any clog in the line that you can't reach.
Feb 13, 2009 | General Electric Profile Smartwater Ultra...
The water input to the water filter is leaking - admiral model GC2224GEKB
my water filter water line is leaking from the bottom in the back of my refrigerater. How can i get to it to repair it.
Aug 19, 2008 | Admiral 26 cu. ft. Side-By-Side...
Reverse osmosis causing poor water flow
cheak the main water flow and clean the machine inlet water filter
Jun 17, 2008 | Whirlpool GD5SHAX Side by Side...
Slow water flow on Whirlpool Gold 25.6 cubic
The water line tap may be screwed back into the water line or you did not sufficiently poke a hole into the water line with the tap. We had the same problem. Shut off the water supply, remove the tap from the line and check the size of the hole. my bet is the hole is very small. Either drill out the hole with a drill and replace the tap (with a new rubber grommet) or add a tee into the line with the proper size compression fitting (that is what we did) and the water will flow freely..
Apr 20, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Plumbing Logo
370 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
