Question about Samsung RS2630SH Side by Side Refrigerator
Side by side makes a whistling sound--Model RS2630
I have a Samsung refrigerator that bought almost 4 years ago.  It's making a whistling sound intermittantly. Do you remember when we were kids and we would blow over the top of a Coke bottle?  Well, that's what it sounds like--very strange.  It isn't constant.
  • parker705 Jan 06, 2009
    I have the same whistling noise and mine is also about 4 years old. Does anyone have any suggestions?
I have the same frig-- The sound is coming from the litttle fan behind the frid. Take the bottom silver cover off and you will see the fan in a plactic white frame thing. Unplug it and then put a little oil inside the fan motor-- (oil based solvent). You may have to take it out of the plastic frame. To get the oil into the motor really good. Just use some 3 in 1 oil or wd-40. You will probably have to repeat this every couple of months. But it gets rid of that awful nosie. I also found that if you give the frig more air to circulate than the oil will last longer. Meaning don't put the frig so close to the wall. Oh please remember to unplug the frig first. I hope this helps.
Posted on Jan 29, 2009
  • hovathegreat Jan 29, 2009
We bought our samsung ref side by side type last year. Lately, in fact 2 days ago, we noticed a sound ("ugong")coming from the motor at the back of the ref. If the right side door is opened,...
Hello Eloisa,
Call the place where you bought it and they will tell you to get IN HOME WARRANTY SERVICE
Fixya.com does not perform any in home service we just give advice to people who's appliance isn't in warranty so they make fix it theirself without calling someone for repairs
Aug 03, 2011 | Samsung RS2630SH Side by Side Refrigerator
Top compressor area is making a 'sing song' whistle noise, which appears to happen when it is not running. This is a 1990 model KSSS48DW BDWW00, KITCHEN AID SIDE BY SIDE. We got it used. We had a service...
If it's a whistle, or chirp like sound, then find what is rubbing together to cause the noise. If it is a low pumping sound that seems to be coming from internal to the compressor, then that is the way they sound.
I might caution you, if the tech's that are putting R-12 in the system are doing so through clamp on type service ports, they are violating the EPA mandate for the type of equipment used to service A/C and refrigeration equipment. Besides the fact that it will continue to leak because the type of fittings used will not hold R-12.
Dec 16, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Freezer fan in my GE side by side refrigerator surges and whistle
With you model and brand I would want to check the voltage on the fan and shaft play. Meaning the fan may be going bad or the voltage being altered at the motherboard. I do know your model with the control board that it has if a fan becomes defective the board is also affected. If the fan goes bad and replaced it is very possible that the board will fail and cause the new fan to fail. If you need help with diagnostics please let me know, Thanks, Sea breeze
Dec 13, 2009 | GE GSS20IEP Side by Side Refrigerator
How do I take the doors off to move the fridge to another room? Thanks
Hi
You can download the manual below and look for it
It is available from page 15 onwards
Click here RS2630
Happy to help
Dec 03, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung fridge RS2630, icing up on freezer and fridge not cooling
Could be the defrost element. If it does not work and melt the ice off of the evaporator, icing will continue and serve as an insulator. Freezer and refrigerator temps will suffer.
If you unplug the unit and let it defrost for a day and plug back in it will work fine till it freezes up again.
Jun 25, 2017 | Samsung RS2630WW Side by Side Refrigerator
Refrigerator
the fan behind the ice maker is iced up poss fault defrost heater gone try total defrost faor a list 36 hrs restart it noise come back then you need to repace the defrost heater hope this helps
Nov 13, 2008 | Samsung RS2630SH Side by Side Refrigerator
What if there are no reviews??? Kenmore 57906 side by side
I'm not sure where you can go for reviews so I will give my own.  I work on all brands of refrigerators and this one is a great model.  It is made by Whirlpool who in my opinion make the best refrigerators.  Whirlpool uses the best quality compressor as well as other parts.  Most models have what would be considered a "common problem" and this one doesn't have any that I can think of.  The brands I would stay away from are Samsung and LG.  Whirlpool now owns Maytag, Amana, Kitchenaid, & Jenn-air and they can do this because they make great products.  You might look for reviews on Whirlpool if your not having luck finding anything on this particular model.  Would appreciate a solved rating for expert advice.
Oct 21, 2007 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Samsung Side by Side Refrigerator RS2556SH - Making loud noise
Hi, had the same problem with my RS21DCNS engineer came and made a modification to drain hole (made the hole bigger!) this allows for a little more ice to form without causing the horrid noise. A new backplate was ordered as all new models have a larger hole in the backplate already. It only takes a few mins and it under guarantee if you bought less than 2 yrs ago, but you will have to empty fridge side to allow them to get to inside at the back. Good luck.
Sep 17, 2006 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
141 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
