Question about Toshiba Satellite Pro L300D-EZ1002X Notebook
Cant connect to wirless internet
My new toshiba laptop wont connect to the internet wirelessly i can plug the ethernet cable in and it works when i search for my home hub i connect enter the scces code but it doesnt connect can you help me out as i got it for christmas btw im running vista
  • ss_dangermou Dec 29, 2008
    yes i have but recantly i havnt been able to and my router is bt home hub
  • ironman123
    ironman123 May 11, 2010
    have you been able to connect to that wireless router before? The access code on the bottom of your router is NOT your wireless passord. when you enter the wrong wireless password, you do not get a "wrong password message". You will simply be unable to access the network, but you laptop may say "limited connectivity" or "unable to connect" something like that.
    what is the make and model of your router?  did you get any setup instructions for your wireless from your ISP?
    there is an IP address (something like 192.1.1.2 or 192.168.0.1) printed on the bottom of your wireless router. connect you laptop through ethernet, point your browser to that IP address (type it in you address bar and press enter), and follow the procedure for changing you wireless password. (this is proabbly also where you are asked to enter your _access code_ - to change your router settings). what exactly you do, I cannot help you with until you post the model/make of your router. contacting your ISP support may also be helpful of you bought your router from them.
Ethernet issues.
Can you plug pick up internet with a different laptop in the same place? If another laptop can plug in with the same ethernet cable and get a signal then you know its "your" laptop and not the cable or the connection, If it is your laptop that is the problem, check to see if your network card is working properly by going into device manager. My guess is you need a new network card.
Aug 20, 2012 | Toshiba Satellite L655-S5156 Notebook -...
Wireless router will not work without my ethernet cable connected
you need to go into the router settings and turn the wireless on and then it will work
Jan 12, 2011 | Toshiba Computers & Internet
The router wont set up a wireless connection in the xbox so the internet does not work.
you need a wirless device to plug into the xbox 360 or u can use a long ethernet cable
Jun 27, 2010 | Belkin N1 Vision Router
Cant connect my xbox to internet. i have a motorola sb5100 motem and i lose it at internet connection
Try getting a wireless adapter or a wirless router and buy a ethernet cable plug into the back of your x box 360 console tou get it working add me if u do on (XXXLONG HORN666)
Jan 22, 2010 | Microsoft Video Game Consoles & Games
How do I get internet on my laptop from my pc not using a cable?
what you would need to get is a wirless router. If you have high speed internet then you can plug the internet modem into the wireless router and then plug your main pc into the router via an ethernet cable and then set up your laptop to pick up the signal wirelessly. If you have dial up internet then you would still need a wireless router but it is a little more complicated. You could hook up the router to your main pc and then set up internet connection sharing so that way your laptop could pick it up wirelessly. hopefully this helps.
Apr 10, 2009 | HP Compaq Presario v3000z Notebook
I'm trying too connect to internet/
This depends if you connect with an ethernet cable or wireless connection. With the cable, just plug into your modem or router. If wireless, then you need to set up the wirless connection on your computer.
Dec 26, 2008 | Computers & Internet
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Tiscali wirless connection issue
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2
Subnet mask 255.255.255.0
Default gateway 192.168.0.1
Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Connecting my dynamode 6004 W G1 wireless router to modem
Cable modems and routers must be turned on in a specific way. First, unplug both the router and modem. Next, plug the ethernet cable from the modem, into the cable router, and unplug the cable from the modem to the computer. Next, turn on the modem, and wait for all of the lights to stay static (usually there's 4 lights, the main one we're interested in, is the status light). Next, plug in and turn on your router. You should now be able to access the router and configure it for your internet connection.
May 18, 2008 | Computers & Internet
Toshiba Satellite Pro L300D-EZ1002X Notebook Logo
180 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
