Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washing machine When I wash and it gets to the rinse cycle the water dribbles in. It takes me about two hours to do a load of clothes. My washer is a whirlpool ultimate care II. I have replaced all the hoses and cleaned everything and it still does not work.
    Novelist:
  • 114 Answers
IS THIS HAPPENING ON COLD AND HOT WATER RINSE ??? THERE IS AN ELECTRIC SOLENOID VALVE FOR HOT AND COLD WATER SUPPLY. THESE SOLENOIDS HAVE STRAINERS AND ORFICES THAT CAN CLOG UP WITH SEDIMENT IN THE WATER SUPPLY ... MOST ALL OF THEM ARE CLEANABLE. THIS IS NOT AN EXPENSIVE REPAIR ... BEWARE!!!
Posted on Apr 28, 2007
Hi can you tell me which programme is the short wash and spin please
I think I have the same type of washing machine as you do. Wash is when all the clothes get agitated or mixed with soap and water (ever look in there when its washing? the water can get pretty gross looking!) So in my washer, the rinse cycle is when all that gross water is drained, and the washer spins while spraying clean water over the clothes to get rid of the dirty water and soap. I think mine does this 5 or 6 times in the cycle. Next is the spin cycle, which is when the washer spins REALLY fast to **** as much water out of the clothes as possible, so that the clothes aren't sopping wet when you put them in the dryer.
It sounds like your mom has a newer washing machine, probably a front load one, and they do seem to keep using clean water, instead of just agitating the clothes in dirty water.
May 17, 2011 | Electrolux EW1000i Front Load Washer
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
My washer will not fill with water or do any functions when i turn the dial
My Hoover 7700l ...on "fill" cycle, the water dribbles in. Takes hours to fill so we use buckets to reach the required level.
Tried: Swapping cold and hot water inlet hoses, making sure that dial is in "hot". This solved the problem for filling, BUT when "rinse cycle appoars, it's back to the dribble again.
any ideas?
Jan 23, 2011 | Maytag LSE7806A Top Load Stacked...
Washing cycle on a 40degree op. takes more than
Don't forget that the reason you bought a front loading washer is for the efficiency of the washing. In other words, front loaders use less water and get clothes cleaner without all the harsh beating that the older agitator units do.
If you're using any of the pre-programmed wash cycles, you might want to tgry another cycle to see how it does for getting your clothes clean with a shorter cycle.
If you check your owners manual, it should provide the cycle times for the various wash and water temp settings. The colder the water you use, the longer the wash cycle typically is, since it takes more agitation and time to get clothes clean, especially with front loading machines. Hope this helps.
Jul 28, 2009 | Whirlpool WFW9200S Front Load Washer
Takes almost 2 hours to complete a wash cycle
Have you ever cleaned it out? Its likely due to a plugged drain, not allowing the system to drain fast enough for the normal cycle. Check out my solution on
http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
LG washer uses so little water, clothes aren't even damp and not clean
You will need to have a qualified LG technician come out and see what the problem is.  You may have a water level switch issue.
Jul 11, 2008 | LG WM1815CS Front Load Washer
Spin/rinse cycle
find tech sheet at bottom of washer and follow instructions for checking motor controller (at bottom rear)
Apr 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
116 people viewed this question
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
