Question about Onkyo TX-SR602 Receiver
Onkyo tx-sr602 as soon as i turn receiver on it flashes protect
And shuts right off. I have disconnected all wire from rear of unit.
  • 24 Answers
Does it display any message like "Protect" or something similar? Do you hear a relay click on then off?
Did the amp just not power up one day or did it stop working while you were listening to it? Finally, do you have teenage kids who might have been listening to your receiver and would have "neglected" to tell you that after listening to their music it suddenly stopped working?
It could be an internal fuse but chances are its something that requires a technician to repair (like the output transistors).
Posted on Dec 29, 2008
Onyko tx nr616 receiver keeps shutting off. Only stays on for approximately 3 seconds. Can you help?
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Sep 30, 2014 | Onkyo Tx-nr616 7.2 Thx Certified Network...
How do i check to see what is causing my receiver to shut off
Sep 25, 2014 | Onkyo Audio Players & Recorders
Hi, after i turn the power on and then press the stand-by button, it clicks off to stand-by mode instantly. This is an Onkyo TX-SR500
This indicates that the system is going into protect mode. First disconnect all speaker wires (with the power cable disconnected). Then turn the unit on and see if it sill shuts aff ofter a few seconds. If it does not, then you have a problem with the speakers or speaker wires. inspect the wires at both ends for frayed strands that may touch. If that all lookd good, plu the speakers in, one at a time, until the problem reappears. Be sure to turn the sytem off before plugging in any speaker just to prevent any accidental short which could be catastrophic. If the system goes into protect mode with all speakers disconnected, you probably have a shorted output transistor.
Apr 05, 2010 | Onkyo TX-SR500 Receiver
If I turn the volume yp over 60 on my Onkyo
disconnect speakers turn up to 60 and see if cuts out if it does not cut out check your speakers
Apr 04, 2010 | Onkyo TX-SR602 Receiver
Protect Mode on. Want to repair/return to normal
Sounds like your receiver is fried. Your best choice is probably to take it to a repair facility, where they can figure out what component failed, or to buy a new receiver.
May 18, 2009 | Onkyo TX-SR602 Receiver
Echo when connecting Samsung Plasma to Onkyo TX-SR602
Make sure you have the tv volume turned right down as this will cause an echo,also set amp to prologic 2, and set up xover to suit your speakers or go for the THX standard of 80 hrtz and as a rule of thumb set front L,C,R speakers to zero rears to about +4or5 and your sub to -5[ dont know which speakers you have but try setting the subs on board volume to the 10,o,cloak position],also make sure the speakers -,+ are wired the same at the amp and speakers.
Hope this helps.
CABLE GUY.
Jan 06, 2009 | Onkyo TX-SR602 Receiver
Hi I have an Onkyo TX-SR304E. When I try to play music via a dvd/cd player, it lasts for about 20 seconds then shuts off with the STAND BY light flashing on and off.When I try to turn it on , off it goes...
The unit is in protect mode. A problem was detected in the final stage of the amp and the unit shuts down to prevent further damage to either the amp or speakers. Check the speaker wires to be sure that they are not crossed anywhere. If with the sepaker wires disconnected, the amp still enters protect mode, the problem is internal to the amp. This is usually defective output transistors. Expect a parts cost between $15-$40.
Dan
Dec 04, 2008 | Onkyo Audio Players & Recorders
Onkyo TX-NR905 Protection Circuit Activated
The problem is not with the inputs. This unit is in protect because a problem has been detected in the output section. Try disconnecting the speaker wires and turning it on. If the unit remains on, there is a short in one of the speaker wires. If the unit still shuts down, there is an internal problem that will require repair. It sounds like this is a new piece. If so, it should be covered under warranty.
Keep us posted,
Dan
Jul 28, 2008 | Onkyo TX-NR905 Receiver
Protection mode
you have to verify your connection cause if you are a short circuit in your different output or input the protection mode is on. it's an internal security
first disconnect all your output speakers, and restart your amplifier if the protection mode is on again try to disconnect all your input device and restart your amplifier, the protection mode should be off, so after connect one device after one to check who makes your protection mode on
Mar 31, 2008 | Onkyo TX-SR502 Receiver
Onkyo TX-SR602 Receiver Logo
437 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
