Question about Digital Blue QX5 Microscope
Qx5 is not responding
My Qx5 Microscope is plugged into the USB and has installed the software, but no matter which USB port i plug it into it will not respond. The light activate, the image will not show, and when I try to make any movies or take any photos, a message comes up saying "The microscope is not responding. Make sure your microscope is connected. If you are still having problems, try restarting the application or rebooting your computer.(61)", and despite that i've tried what the message says, it won't work and the instruction manuel diddn't have any solution on the parent quickstart side.
    Sniper:
  • 72 Answers
You must install the QX5 software before plugging in the microscope. Try uninstalling the software and removing the microscope in the Device Manager. Then follow the installation steps:
Important: DO NOT attach the microscope to your
computer until you have installed the software!
Here's how to get started using your microscope and software:
1. Insert the CD.
2. Wait for the installer to start automatically.
• If the installer does not launch automatically, go to the
desktop and double-click the icon named My Computer.
• Double-click the icon for the CD drive that contains the software CD.
If the software doesn't start automatically, open the setup folder,
double-click on setup.exe, and follow the setup steps.
3. Follow the steps by clicking the appropriate buttons.
Now you can start the software and attach your
microscope to your computer with the USB cable.
Posted on Aug 11, 2014
  • 661 Answers
The microscope may be trying to draw too much current from your USB ports, your computer will disable the device if it does this. When this happens one of the easiest (and cheapest) solutions is to acquire a Powered USB Hub (with it's own Plug top power supply). This should aleviate any extraneous current draw to the Power supply.
Posted on Sep 15, 2007
I have lost my software disk for QX5 digital blue microscope we are a school and have a mix of computers xp vista windows 7 what do i do?
Here are the links to the available downloads from Digital Blue:
QX5/Smithsonian Computer Microscope Drivers for WIN ME, 2000, XP, Vista 32-Bit
Download Drivers
QX5 V2 Computer Microscope Drivers for Windows Vista 64-Bit
Download for Windows Vista 64-Bit
QX5 V2 Computer Microscope Drivers for Windows 7
Download Windows 7 32-Bit
Download Windows 7 64-Bit
QX3, QX5 V1, QX5 V2 Computer Microscope for Mac OSX 10.4-10.6
Visit Webpage for Download
QX5 Computer Microscope V1 Video Codecs for 32 bit versions of Vista/Windows 7
Download Codecs
Feb 23, 2011 | Digital Blue QX5 Microscope
How do you set it up
Downloads and install the appropriate driver software from Digital Blue:
Download Drivers
Nov 15, 2010 | Digital Blue QX5 Microscope
109 error message when running microscope
According to the Digital Blue website, there are a variety of things that can cause this error, including USB configuration issues, QX5 connectivity problems, or an improperly installed device. To troubleshoot, try the following steps. If one does not work, try the next until the problem is resolved.
1. Exit from the application, unplug the QX5 from your computer, and restart your computer. Once your computer has rebooted, plug in the microscope and restart the application.
2. If you are using a USB hub (an external device that allows you to connect additional USB products to your computer), exit the application and plug the microscope directly into the USB port on your computer. If the microscope works when plugged directly into your computer, there may be a problem with your hub, or it may not be supplying enough power to run the microscope. If your hub does not have a power adapter, you will need to plug the QX5 into your computer's USB port or use a hub that is powered.
3. If you are not using a USB hub, try different USB ports. Always exit the application, unplug the QX5, and then plug into a new USB port. Wait at least one full minute to make certain that Windows recognizes the QX5. Then start the application again. If you are still experiencing the problem, try another USB device (if possible). If no USB devices are working, there is a chance your USB ports are not working properly and you should contact your computer manufacturer to resolve the problem.
4. If you have a laptop, make sure the laptop is using its power adapter. When running on battery, some laptop computers don't supply enough power to USB ports and as a result the QX5 will not work properly.
Note: The following steps require some experience with Windows computers. If you are comfortable modifying advanced settings on your computer (like the Device Manager or BIOS), proceed at your own risk. Otherwise, respond to this email and provide your phone number so a member of our technical support team can assist you.
5. Plug in the QX5. Go to Start > Settings > Control Panel and double click on the System icon. For each of the following items (if present), select that item, then click the Remove button:
  • Any devices that have a ? or ! next to them, or that are listed as "USB Camera Device."
  • The driver named "Digital Blue QX5™ Microscope #2" (located under Imaging devices).
After removing all the devices, click the Refresh button.
6. Try lowering the hardware acceleration of your video adapter. To do this, follow the steps below that apply to your operating system:
If using Windows 98, Windows 98 Second Edition, or Windows Me:
  1. Click on Start > Settings > Control Panel.
  2. Double-click on Display.
  3. Click on the Settings tab
  4. Click on the button labeled Advanced
  5. Click on the Performance tab
  6. -proceed to 'fix continued...
If using Windows 2000 or Windows XP (classic view):
  5. Click on the Troubleshoot tab
If using Windows XP (XP style category view):
  1. Click on Start > Control Panel
  2. Click Appearance and Themes
  3. Click Display
  4. Click on the Settings tab
  5. Click on the button labeled Advanced
  6. Click on the Troubleshoot tab
  7. -proceed to 'fix continued...
...'fix continued'
While in the Performance tab, move the slider for Graphics Hardware acceleration one notch to the left. After you do this, the panel should indicate "basic accelerator function". Click OK, then click OK again to exit from the Display Properties window. Restart your computer and launch the QX5 software. If this does not fix the problem, repeat the process until all the available HW acceleration settings have been tried. (Different video adapters disable the acceleration at different points on the slider.)
7. Unplug your QX5 microscope and restart your computer in "Safe Mode." To get into "Safe Mode," you must reboot your computer and press the appropriate key before the Windows logo screen appears. If you do not know how to do this refer to your computer's manual or contact your computer manufacturer.
If you are successful in starting in Safe Mode, there will be a "Safe Mode" logo in each corner of your desktop. Then follow these steps:
a. Click Start/Settings/Control Panel.
b. Double-click the System icon.
c. Go to the Device Manager tab.
d. For each of the following items (if present), highlight the item, then click the Remove button:
  • Any device that has a ? or ! next it or is listed as "USB Camera Device."
  • The "Digital Blue QX5(tm) Microscope #2" driver (located under Imaging Devices).
e. Close the device manager, and restart your computer
f. Go to Start/Settings/Control Panel and double click the Add New Hardware icon.
Go through the Add New Hardware Wizard. When the Wizard asks if you want Windows to search for new hardware, select "Yes".
Note: You may be asked to insert your Windows CD or the CD that came with the microscope. If you are prompted to insert one of these CDs, you MUST do so or the microscope will not be properly installed. (Contact your computer manufacturer if you cannot find your Windows CD.)
g. When the new hardware installation is complete, restart your system, then try running the QX5 software again. 8. Uninstall the QX5 software (which will not delete any video or images you may have captured as long as you re-install to the same directory) by following these steps:
a. From the start menu, open the QX5 program group and select the uninstaller.
b. Follow the instructions to uninstall.
c. Restart your computer.
d. Insert your QX5 CD-ROM and follow the install instructions.
e. Plug in your QX5, wait a minute for Windows to recognize and install.
f. Start the application.
Oct 19, 2010 | Digital Blue QX5 Microscope
I need the software for the QX5. Is there a spot to download this info?
Download Drivers
Aug 20, 2010 | Digital Blue QX5 Microscope
I didn't get any software with my QX5 digital microscope. Where can I download the driver
Download Drivers
Jun 29, 2009 | Digital Blue QX5 Microscope
Is the software downloadable on the Internet
The drivers can be found here...
http://digiblue.com/customer-service/downloads/drivers/QX5.zip
Jan 07, 2009 | Digital Blue QX5 Microscope
Load ffdshow
The white list black list gives me the impression that this is something on your network that is not allowing it to work. My school has a white list black list system for websites. Have you tried installing the qx5 on an freestanding computer to see if that works ok?
Sep 30, 2008 | Digital Blue QX5 Microscope
QX5 Problem with Windows Vista
Do not plug the QX5 in until the software is installed.
I got mine to work on Vista 32bit. Insert the cd, cancel autorun, view files on the cd. locate setup.exe, right-click on the setup and go to properties; then compatibility; then put a check in "run this program in compatibility mode for windows xp" AND put a check mark in "run this program as an administrator; the click Apply and click OK.
Right-click on the setup.exe again, this time choose, Run as Administrator.
Install away from the default. My recommendation is c:\users\(your user name\digitalblue.
Plug in the QX5, then go to Start, Programs, Digital Blue, click on QX5
Jun 10, 2008 | Digital Blue QX5 Microscope
Error message: qx5 not connected, please plug in usb.
Email Digital Blue and they will ask for your email address and shipping address. Looks like they're starting to send out the Vista version on cd via the mail, then make it available online for download later. Best of luck!
Dec 28, 2007 | Digital Blue QX5 Microscope
Qx5 microscope is shutting down.
Does this device run from USB power.. (no plug in power supply) if so, the problem may just be that this device (not limited to microscopes) is trying to draw too much power, as not all USB ports are born equal (a common problem in laptops). the solution is to either buy a power supply for the microscope or get a "powered" USB hub (a usb hub with it's own plug top power supply) I hope this helps
May 25, 2007 | Digital Blue QX5 Microscope
Digital Blue QX5 Microscope Logo
1,003 people viewed this question
Top Digital Blue Science & Laboratory Experts
Elton
Level 1 Expert
neil darnall
neil darnall
S J Parkin
S J Parkin
Are you a Digital Blue Science and Laboratory Expert? Answer questions, earn points and help others
