Speed queen makes a lot of noise, has a new motor as of two yeas ago works very well.
The washer work fine but makes a lot of noise.
  • 15,935 Answers
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Speed queen washing machine fills water but does not agitate but all other cycles spin and rinse working perfect. i took out the belt and started the cycle and the motor was moving fine.
the motor spins with out the belt , makes me tend to discount the capacitor
I would be looking for a tub brake that is not being opened to allow the tub to agitate
there are solenoid activated brake under the machine the applies a brake when you lift the lid during wash, when the program is finished
have a technician check it out
Nov 10, 2015 | Speed Queen AWS44NW Top Load Washer
Washer motor overheating
Check the drum for ease of rotation, bearing noise. Make sure all support springs are good and at the same position.
Nov 27, 2013 | Speed Queen SWT921 Top Load Washer
I bought a new Speed Queen AWN432. Installed it, filled it with water. When the water stopped filling the motor does not run.I've pushed the lid switch on the back side to make sure it was close
If there is too much weight to 1 side, sensors in it will stop it from spinning. If you evenly distribute the weight of your clothes this may fix it.
Jan 29, 2012 | Speed Queen AWN432 Washer
I have a Speed Queen top loader(older model). It let's water in but does not wash or let water out. I have checked the control pannel and motor. All seems to be ok. The reset used to work but now it does...
Make sure that the lid switch is working as it can make the program from advancing forward. So check the continuity of the switch that goes to trigger the main board.
If Ok then the program controller is not functioning, if you can try to change manually then the control board is faulty.
Jan 13, 2011 | Speed Queen AWS17NW Top Load Washer
Speed Queen model no.AFN50RSP111TW01 Washer makes humming sound all the time in off position,i am being told by dealer that its the transformer which is normal,replaced transformer and still hums,unplugged...
Usually a transformer hums when it does not have the proper voltage being supplied to it. I would check this first. If the voltage is correct contact a parts supplier and request a new transformer. Speed Queen has a great parts warranty. As Speed Queen is really a commercial machine it is not unusual to have them make more noise than other manufactures.
Dec 18, 2010 | Speed Queen ATS90AWN Front Load Washer
My speed queen washer made a high pitch noise when spinning. i took the front off and saw the belt was almost cut in half. how do i replace it?
Easy,It just slips over the fluid drive after disconnecting the link to the spin solenoid, then on to the pump pulley.
Adjustment is made by the motor mount.adjustment bolt.
Good luck.
Feb 23, 2010 | Speed Queen AWS52NW Top Load Washer
The washer quits at rinse and spin dry cycle
I've had the same experience with my Speed Queen washer. Approached the accredited Speed Queen agents for assistance, when tech support was deployed to diagnose the problem.
In the end, I was told that the "timer" went bust. So the wash cycle seems to work 100%, but when it comes to rinse and spin the contacts on the timer don't make contact, and the motor waits in anticipation for it's next command, and that the high pitch noise heard.
Jul 04, 2009 | Speed Queen AWS52NW Top Load Washer
Speed Control only works in Heavy Duty
sound like your motor is going out ,,,, the wiring at the motor may also be loose from out of balance loads
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
