Question about WYSE WT9650XE 512MB/512MB LCD INTERG (90206830) Network Terminal
WT965 When i put my washing on a fast wash, it keeps going straight to rinceing an i can get it to was the clothes
0 characters
1 Points
How do you reset factory settings for a Wyse V10L? We tried holding down G and it will not go into reset settings. Thanks!
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
Hope this helps
Jan 20, 2011 | WYSE Network Terminals
The pointer is not stay still, it's moving fast and inch apart!
try cleaning the touchscreen there might be some dirt between the screen and the frame, if that fails, you need to replace the touchscreen
Dec 19, 2009 | Posiflex Jiva 5800 All-In-One...
Ho do the wyse winterm s50 worck? and ho do i, or can i use the?
There is documentation available for free from the wyse website on the knowledgebase. This will detail the full usage of the S50.
It can be used as a local web terminal, or linked to an external server, via RDP (terminal services) or ICA (citrix).
The admin guide (from will help you figure this out :)
Mar 24, 2009 | WYSE Winterm S50 Network Terminal
It depends on what blocker they are using to keep you away from my space. Tell me what company they go through and I'll give you a solution. I used to do it all the time when I was in High School.
- Ernest
Mar 25, 2008 | Network Terminals
Blue Screen of Death!!!!!
Can you detail what you were working on when you got this screen? most of the time when you get the blue screen its because new hardware was installed , if this was the case try uninstalling the hardware and booting up again.
Feb 06, 2008 | WYSE S90 THIN CLIENT KB/MSE XPE...
Wyse S10 Power UP issue after hung-up.
pull out the power cord for 5 minutes than put back in and turn on
Jan 29, 2008 | WYSE S10 (90210501) Network Terminal
Washing machine
f8 is shown when the heater circuit is on with no water in.. it doesnt do it when you unplug the pressure switch because your disabling the heat protect circuit
F08 indicates pressure switch stuck on full.
Unplug the appliance from the wall socket.
Take the top off the machine.
Locate the pressure switch, you can identify it by the thin tube attached to it.
Take the tube off, blow down this tube as hard as you can to shift any blockage or restriction in the pressure chamber. Give the pressure switch a couple of good taps with the screwdriver handle.
Refit the tube and try the machine again.
If still doing it, unplug again and follow the tube down.
This end will be attached to the pressure chamber.
Take this chamber off and thoroughly clean it out, clean out the port into the tub too.
Reassemble and try again.
If after this it's still faulty you'll need to start replacing parts.
I'd suggest trying a new pressure switch first.
Failing this, if all of the above fails to resolve the problem you're possibly looking at a faulty main control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 04, 2007 | WYSE WT9650XE 512MB/512MB LCD INTERG...
S30 Display Problems
In almost all cases of my dealing with Thin Clients over a 10/100bps network all problems usually are within the Terminal Servers hosting the Thin Clients. BPCS
May 01, 2007 | WYSE Winterm S30 Network Terminal
Network Terminals Logo
Top WYSE Network Terminals Experts
Rick Johnson
Rick Johnson
Mike Neath
Mike Neath
Are you a WYSE Network Terminal Expert? Answer questions, earn points and help others
