Machine giving blank pages won't photocopy, faxs are blank. help!!!!!!!!!!!
SOURCE: Printer prints top 1" of page, then just spits out blank pages
try and click on file at the top left hand corner of your screen.hit print and see what happens
SOURCE: Canon MP730 won't print at all (blank pages).
try to move the blue nozzel over the printing head to the from the right to the left and try, it will work
SOURCE: canon image class mf5750 legal size paper
Hi ...
If you wish to print using a paper size which is different from the normal one A4, you need to specify the same to the printer else it will not recognize or will not accept the paper ...
Below are the steps that you can follow to:
1) Specify paper size
2) Specify paper type ..
Specifying the Paper Size
At the factory, the paper size has already been set to [LTR]. Normally, you can make copies in this setting. When making copies on other sizes of paper, you need to specify the paper size according to the following.
When [ENVELOPE] is selected:
Press <> or <> to select the type of envelopes (COM10, MONARCH, DL, or ISO-C5), then press <Set>.
When [FREE SIZE] is selected:
Press <> or <> to select [VERTICAL SIZE] or [HORIZONTAL SIZE], then press <Set>.
Use the numeric keys, or press <> or <> to specify vertical and horizontal sizes of the paper in millimeters (mm).
Available range in [VERTICAL SIZE]: 127 mm to 356 mm (5" to 14")
Available range in [HORIZONTAL SIZE]: 76 mm to 216 mm (3" to 8 1/2")
Press <Set>. Repeat the steps above to specify both vertical and horizontal sizes of the paper.
Specifying the Paper Type
[PLAIN PAPER] is selected as the default paper type. When making copies on paper other than plain paper, you can specify the paper type according to the following. Specifying the paper type can prevent poor copy quality, or the printout not being printed correctly.
Please vote if this helps ... Cheers :)
You can select from the following paper types:
Plain paper (17 lb to 24 lb (64 g/m2 to 90 g/m2 )): [PLAIN PAPER]
Heavy paper (25 lb to 34 lb (91 g/m2 to 128 g/m2 )): [HEAVY PAPER], [HEAVY PAPER H]*1
Transparency: [TRANSPARENCY]
Label*2 : [HEAVY PAPER], [HEAVY PAPER H]*1
Envelope: [HEAVY PAPER], [HEAVY PAPER H]*1*1 If print fixing is not sufficient when printed with [HEAVY PAPER] selected, select [HEAVY PAPER H].
*2 A label that can be loaded in the cassette is a standard type (label standard card) only.
SOURCE: CANON MF5770 PRINTER/SCANNER/FAX PRINTS BLANK
Nesecito los driver para poner a funcionar el printer. Fueron borados por un virus.
Sometimes turning it off and on again fixes it. However, we started having a problem where it would print out one page after you powered it back on again and then give the "incorrect paper size" message. I've found that by either holding down the green button or repeatedly pressing it while it powers back on (and held until the first page prints) fixes the problem.
