Question about OKIFAX 4500 Plain Paper LED Fax
OKI 4550 fax
Problem with faint printing on copy or rx faxes, I have changed toner, drum and cleaned the LED bar, calibrated it, selected dark during printing and ran a diagnostic check but it is still faint when printing, the drum and toner was checked in another machine and is fine, any assistance would be appreciated,
Cheers Dave
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 154 Answers
Try to boot the front cover and clean the glass over the lens
Posted on Apr 20, 2009
Incoming faxes have dark bands accross the page. The bands are 1/4" wide and spaced about 1 1/2 " apart.
Sounds like it needs a new drum. You'll have to replace the toner at the same time.
Oct 14, 2010 | OKIFAX 5650 Plain Paper LED Fax
Oki fax 5050 cleaning
There is a option in the OKI for maintence. Look for this option in the menu. Clean the drum and toner there
Feb 15, 2008 | Office Equipment & Supplies
After changing toner it still has a grey spot in the middle of the page that does not print dark enough
The LED array probably needs cleaning. This is located on the lid that you open when changing the drum/toner and is a dark coloured bar going left-right across the lid. Clean this with a cloth. Also check the opening in the drum where you can see the green cylinder from the top for any small obstructions and remove if necessary. Any obstructions or dirt on the LED will line up with the print defect on the page and should be easy to remove. Be careful not to damage the green cylinder.
Dec 28, 2009 | OKI B4250 Led Printer
Just replaced toner - now it prints so dark I can't even read the fax
Most common cause is a dirty corona wire and or drum. If after cleaning the corona wire and drum the copies are still mostly black and smeared, the drum may be broken.
Jul 15, 2009 | Brother IntelliFAX 2800 Laser Fax
Sent faxes not printing clear
Per Brother's User manual,
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_4100_4750e_5750e_EN_98.PDF
Clean the machine’s interior and the primary
corona wire of the toner cartridge This is a common cause for your printing/copying problem. This should solve your issue. Best of luck.
Greg
May 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Dark Bar only on Sent Faxes
open the top where you insert the paper to fax look at the strip of thin glass is there any white out or toner on it that is most likely your line, clean
Nov 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Fax prints to dark
have you replaced the drum??? are you using brother oem toner???? generic toner will give you all kinds of problems
Oct 29, 2008 | Brother IntelliFAX 2800 Laser Fax
Poor quality fax to fax, copy great, computor fax great.
beware of generic toner!
you may need to change out your drum unit
the drum unit may have been contaminated by the staples toner.
also clean laser window under drum cartridge.
Mar 17, 2008 | Brother IntelliFAX 2800 Laser Fax
Oki Fax 4580 problem
Does this happen when you perform a test print such as an activity report or config page? if it does you may have a transfer roller issue. The transfer roller is the long black spongy roller directly under the drum, the metal rod in the roller conducts a charge that interacts with the drum. If the roller is dirty (usually chocked up with toner) the necessary charge is diminished and the image will be lighter. You will have to remove the roller in order to clean it, (TURN THE POWER OFF) there is a bendable plastic tab at the right side end of the roller that will release the roller. I personally drench the roller with metho and then wrap a rag around it and squeeze the metho/toner out (dont do this with lexmark rollers, they deform) let dry and give it a try, also check the end of the metal rod and where it connects for contamination.
Mar 16, 2007 | OKIFAX 4580 Plain Paper LED Fax
OKIFAX 4500 Plain Paper LED Fax Logo
265 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
