Back to:
Tags:
IBM ThinkPad 600X PC Notebook
Error Code 07 301 (by 2 users)
posted by thecathouse on Apr 28, 2007
I have an error code, 07 301.
It doesn't boot up it just tells me the code number and asks me to switch off. Any idea how I can fix it?
Thanks, Roy
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Jun 06, 2008
ibm thinkpad 600x
00301 error with flying duck.
hold down Esc all ok except no keybd
tred external kbd =nogo.
the little num lock caps lock & scroll lock led's flicker on ext kboard?
help!!
michael
Solution #1
posted on Apr 28, 2007
Not Rated (0)
babb
Rank:Guru Guru
Rating: 87%, 172 votes
With IBM Thinkpad,it telling you that some hardware is faulty, check your keyboard to make sure nothing is stuck. Also it could also be your trackpoint. Usually, replacing the damaged part gets rid of the error!
However there is a bypass key sequence that allows your to continue booting the system even though it gives you error. I'm not 100% sure of what it is but somthing like ESC at boot or F1 or maybe your need the boot to the error page then press ok, then when the system comes up again press f1 or esc then. You'll have to play around with the key sequence a bit.
But to get rid of the error forever you need to replace the damaged part!
Regards,
Armando
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Error Code 07 301:
I don't want to Accept this solution
Can you Help with these PC Laptops problems?
PC Laptops
I dont know how to go about about setting up my home...
PC Laptops
power is on no display on screen green light remain...
PC Laptops
I have used Memorex dvd+r discs to do my back up on, what...
My laptop crashed and when everything was reinstalled,...
I am getting an error message 0175crc1 bad when i switch...
Loading problems.
Repair Service
Find PC Laptop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
