Question about Kenmore 24032\24036 Top Load Washer
Kenmore washer won't agitate,drain or spin.
Washer was washing a load and started to make a noise and a few mins later it quite agitating. I tried to get it to pump out the water and it wouldn't do that either nor will it spin. when I turn it on it sounds as though the motor is humming. I can turn the part of the agitater that sticks above the water, freely in a clockwise direction but not counterclockwise and the part of the agitater in the bottom of the drum won't move in either direction by hand.
  • hightrackcat Dec 29, 2008
    model # 110.29842991
    also I just found a small pencil shaped (3/4" long) white plastic part with a piece broken off it, that looks like it came from where the tansmission attaches to the motor. there is also what seems to be a pile of black belt dust under the washer on the floor. I was under the impression that there is no belt and it is gear driven? the washer is appx 9 yrs old: is it worth fixing?
    Thanks for your help.
  • Dan Webster
    Dan Webster May 11, 2010
    model number please
  • Kenmore Master
  • 8,220 Answers
What you have here is a broken drive coupling
the part looks like this:
To fix it CLICK HERE
Posted on Dec 29, 2008
Our Maytag PAV2300AWW Performa top load washer fills with water fine, draisn fine, spins fine, but after filling with water (even on "Mini" size load) it begins to agitate and then quits completely and...
If it was the bearing it should be leaking water out the bottom! It is more than likely the water pump. The seal in the pump drops down and then makes noise. The pump should be in rear. tilt machine back remove belt then try turning the pump by hand if tight replace.
List price is about $89.99 you can find it on Ebay cheaper
Jul 05, 2014 | Maytag PAV2300 Top Load Washer
Top load washer not agitating. buzzing noise from motor
1st check pump is pumping out water/ next could be motor not running due to fault, not sure if brushes are in this motor if so check for wear, quite old so could be the motor gone...
Oct 31, 2009 | Washing Machines
Kenmore Washing Machine won't agitate, spin, or drain
It sounds like the motor needs to be replaced, you can drain the water by taking the drain hose from the drain and lowering down water will drain.
Jun 01, 2009 | Kenmore 24032\24036 Top Load Washer
Loud noise
it sounds like you have something stuck under the agitator thats causing a rubbing noise when it goes to spin or agitate.maybe a penny or something like that
Dec 28, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
Front loading washer basket is loose and pump is making noise
The loud sounds you hear when the washer is on is coming from 5 possible sources 1. unbalance wash load, 2. a washer that is not level, 3. a broken agitator, 4. a blockage in the water pump, and 5. a worn transmission.
Solution, balance your load, level your washer, removed the hoses from the water pump to remove any blockage. If these solutions don't solve the problem contact a service provider to service your agitator and or your transmission.
Good luck
Aug 06, 2008 | Frigidaire ATF6000ES Front Load Washer
Um..... not quite sure....
Most likely the transmission on the motor has seized and will need to be repaired. Look under the washer, if there is black grease on the floor then its time to replace the motor and/or the transmission. If you have seen smoke then its probably the case.
Jun 20, 2007 | Whirlpool LSB6200KQ Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
132 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
