Sony KP-51WS500 51 in. Rear Projection Television
Problem for Sony KP-51WS500 51 in. Rear Projection Television
Sony KP51WS500 Rear Projection TV,Convergence Problem
By bgybt on Dec 29, 2008
All three colors are Shadowed around images which are also blurry. I tried the flash focus button but it didn't do ay good. Thanks.
Same Problem
Feb 25, 2009
-   all 3 colors create shadow and do not align. Tried focus but no change. -   mailbaronout
Solution #1
posted on Feb 28, 2009
Not Rated)
Ecollier2012
Rank: Guru  Sony Televisions & Videos  Expert
Rating: 93%, 586 votes
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Was this helpful?
Yes
No
Solution #2
posted on Jan 15, 2009
Not Rated)
sauer_brando
Rank: Guide
Rating: 92%, 2 votes
sounds like one of two things. either the Lamps are off focus or the picture settings are off have you tried to set the picture to different setting (movie, normal, and I can't remember the others off hand) but try that and see if it helps
Was this helpful?
Yes
No
Popular Solutions for Sony KP-51WS500 51 in. Rear
Questions and Unsolved Problems for Sony KP-51WS500 51 in. Rear
Do you recommend Sony KP-51WS500 51 in. Rear Projection Television?
Answer
Answer
Keeps fading from normal color to yellow tint and then back to normal
Answer
filter cleaning , picture is getting shadey light only in the center of picture
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in , CO
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
