Question about Garden
My garden tractor makes a funny noise when i put it in drive
Its an 20 hp automatic craftsman garden tractor, my drive belt broke last spring and i replaced it and ever since i did its been making funny noices, when i put it in drive or reverse. and now it wont even move it maks a loud noise its like a belt is sliping. so then to push it to the shed i had to disengage the rearend and its not disengaging. what can i do to fix this problem.
dan
bathurst nb
Wrong belt size? Did you put everything back the way you took it off to put the belt on? Usually, it's the belt, if it doesnt fit tight it will vibrate, have a burning smell and wont let you shift smoothly.
Posted on Dec 29, 2008
Craftsman lawn tractor will not engage in forward drive why
Check to see if brake lever is stuck on trans, keeping the brakes locked. should not be any squalling noises. Also make sure belt is routed right. and all idlers spin free.
Feb 01, 2018 | Craftsman Garden
Loose drive belt
the belt could be warn out or have a broken spring look under the foot rest there is a diagram for the drive belt under the foot rest
Jul 05, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Lawn tractor does not move repl. both belts pull
What brand of mower? You most likely have a broken return spring on the drive system.
Apr 11, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
On the clutch and brake peddle the clutch engadges at the very end of the peddle. The brake is working fine but as you let the peddle out on the last 1/16 of an inch the drive engades. this makes it where...
If you replaced the belt then you know there is a tensioner/guide pulley and another pulley which goes in and out with the clutch pedal movement to take slack out of the belt. I would closely examine both of those as well as the linkage and return spring on the clutch pedal.
Aug 05, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
19.5 hp 42 " automatic craftsman . The trans seems to be slipping,does not want to go up any incline. I have purged it and installed a new drive belt. did not help.
recheck ur drive belt either wrong belt or spring/idler/tentioner pulley needs attention adjustment replacement also check free wheel actuator that not partially activated
Jun 10, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 20 hp mower with 46 in deck is making a "train whistle" sound periodically when mowing. the belts were new last year. I have lost my manual and don't know if there is too much play in the belt or...
Hey Jan..my name is Keith..and if your belts was replaced last year..i wouldnt suspect them of the noise...my guess would be that is something on the deck that needs lubricating..like a spindle..and this problem is hard to pin point from not being there...so..i hope this suggestion will help..if not please write back
Jul 11, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman lawn tractor mower, automatic,917.273621, transmission will not pull mower up a slight hill. richard swint drive/motion belt seems normal,
The belt is probably slipping because it is not tight enough. look by the belt, inside there is a little spring, you may half to tighten it.
Jun 13, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
May 17, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
345 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
