Question about LG LSC26905TT Side by Side Refrigerator
Express Freeze Bell Going Crazy
The "Express FRZ" light and associated bell on my LG 26922 has started to rapidly cycle between on and off. So rapidly that it sounds like a pinball arcade. It doesn't do it continuously but may rest for a couple of minutes then start up its beeping a new. The fridge seems to work OK but the bell is annoying. Is there a way to disable it as I never use that feature? What is the warranty on that feature? The unit is 3 years old... Thanks Purchased in Mexico: GR-L219ATH
    President:
  • 2,110 Answers
I use combinations of buttons to disable/change settings on my LG. To disable the bell press and hold Express Frz then press and hold Filter until the display 'flashes' once, the bell should cease.
Posted on Dec 29, 2008
  • LG Master
  • 19,396 Answers
I do not think there is aany easy way to sort out the problem, usually the control board must be replaced when you get this kind of problems.
Refrigerator freezer problem. Kenmore Elite bottom freezer refrigerator, model # 795.75546401, manufactured 9/2004 (LG is actual manufacturer). The Express Freeze LED turns on and 2 "beep"...
Press and hold FRZ TEMP button and REF TEMP button at the same time for 3 seconds.And see if that makes any difference in the problem. ---------- If the problem is same then try the manual reset procedure.In manual reset the unit has to be unplugged from power outlet for 24 hours.Then empty both the fridge and freezer section completely.Then after 24 hours.Clean the melted ice water from the inner parts.Then reconnect the power cord of the unit to power outlet.Set the temperature to normal settings.It will take near to 4 hours for your unit to run its regular cooling cycle.Once this is done then check,if the same problem is seen.-----------This will help.Thanks.Helpmech.
Dec 20, 2010 | Kitchen Ranges
The top freezer of my Maytag refrigerator does not keep ice cream firm. It will freeze water, but ice cream is like cool whip. Help!
Check your ref/frz settings. Check the condensing coil for dust/lint/other. You may also have a defrost problem. Check back panel in frz for ice/frost. Try emptying unit and leaving it off and doors open for 24 hrs. If it starts cooling afterwords, is probably dft cycle.
Nov 22, 2010 | Maytag Refrigerators
Warning bell won't stop sounding
Sounds like your door sensors are going bad and are not relaying to the computer that the doors are fully closed, with that being said you will need to replace them and also at the same time it will stop the door locks from going crazy
May 16, 2009 | 2000 Ford Windstar
1998 Saab Bell will not stop dinging, even when key is removed.
the lights are most likely the third brake light on the decklid... small line of led brake lights small unit.. i would clean the ignition switch with some quick start and cycle the key in and out to clean up the contact on the bottom some times soda or coffe gets in there and makes the car think that the cars key is in the ignition
Apr 18, 2009 | 1998 Saab 900
Water coming from bell housing.
If you are ABSOLUTLY POSITIVE this is where the Coolant is coming from the ONLY Sorce is Freeze plugs ,There are Usualy 2 Behind the Flywheel. Sorry For the BAD NEWS but this IS the only thing that can Leak Out of the Bell Housing, Transmissiou Must Come Out and Flywheel also, Once The Flywheel is OUT you will see the FREEZE PLUGS. Good Luck !! Please RATE ME !!!!!!!!!!!!
Mar 22, 2009 | 2007 Dodge Ram 2500 Mega Cab Laramie
Programm bell expressvu 4100 remote control
I had the same problem. I used the code 660 and that works fine for power, volume, and stations for my Insignia with the bell remote. Hold tv button till all 4 lights light up and then press 660 # and everything (minus the menu option) should work. I also tried these insignia codes (which might work if this dont.) 659, 573, 570, 405, 245, 456.
Mar 09, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
Getting VCR to record from Bell Express View
try this website
http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit-Old.doc
keep scrolling down in the list until you find the vcr codes.
i found the 3 digit code for my sony VCR. it gave me several codes, but i finally found the one that worked with my bell expressvu.
good luck
Jan 29, 2009 | Televison & Video
Bell rings
You have either a water fill or water temperature problem.  Not sure because you couldn't be specific on the error problem.  You will need to call a qualified LG technician to diagnose this properly.
Apr 10, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Wow, almost a year later but here goes;
Aug 25, 2007 | LG LRSC-26922 Side by Side Refrigerator
LG LSC26905TT Side by Side Refrigerator Logo
125 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
