Question about GE Spacemaker JVM1640SJ Microwave Oven
GE JES1451 Microwave Food will not heat up.
Everything appears to be working!
  • Thomas F. Schneider May 11, 2010
    Microwave - Runs But Does Not Heat
    If the microwave runs, but does not heat, it could be one of many parts.
    For safety reasons, GE offers no do-it-yourself repair advice on microwave ovens due to:
    • Safety requirements due to high voltage (capacitor hold a high voltage charge even after it has been unplugged)
    • Complexity of electronic circuitry.
    • Special equipment needed to make diagnosis.
    GE urges our consumers NOT to attempt any microwave repairs.
    If you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-GE-CARES or you may schedule service online.
    http://www.geappliances.com/service_and_...
5 Suggested Answers
MicrowaveSvc
  • 8872 Answers
SOURCE: GE Spacemaker XL 1400 Microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 28, 2007
MicrowaveSvc
  • 8872 Answers
SOURCE: Microwave won't heat food.
This would be under warranty, so Maytag should take care of it for you: http://maytag.com/support/index.jsp
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 31, 2007
SOURCE: microwave will not heat food
I have the same problem and have figured out the following:
Most likely it is the magnetron - common problem for GE's. Replacement part list price is around $180 but you can find on ebay for about $80. Replacement is "doable" but tricky because the oven needs to be removed to replace the part. The GE replacement kit part # for magnetron and stirrer is WB27X10489. Expect a service tec to charge at least $200-$225 to make the repair so complete replacement of microwave might make more sense...unfortunately.
Posted on Dec 04, 2008
SOURCE: No more heating, GE Profile Microwave JVM 1870CF02
I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
Posted on May 14, 2009
heatman101
  • 43501 Answers
SOURCE: My GE Profile microwave just stopped heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
45xs
Posted on Sep 30, 2010
My microwave does not warm food!
Likely a magnetron problem that will cost you between $135 and $160 just for the part if searching on-line for replacement.
May 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Our microwave (GE) not longer heats food items.
heatman101
r
Sep 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave runs but food does not heat
If everything appears to work as normal but does not heat, then the magnetron will be faulty. This is the device which cooks the food, however this can be an expensive part to replace & may not be economical to fix.
Sep 23, 2009 | General Electric Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Aug 31, 2008 | GE JVM1850 1000 Watts Microwave Oven
GE Microwave doen't heat any food or liquids
PROBLEM MAY BE A RELAY ON THE CONTROL BOARD OR MAY BE A LOOSE WIRE FROM THE HV TRANSFORMER CKT.
Sep 06, 2007 | GE JVM1660 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
140 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
