Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Dorr will not shut down all the way
The door keeps popping back up after it closes all the way down . I think the garage floor has heaved a little because of winter . How do you adjust the closing
  • Kevin Kodama
    Kevin Kodama May 11, 2010
    What make is your garage door opener?
  • 504 Answers
LOOK FOR THE TWO ADJUSTING SCREWA WITH A LITTLE PICUTE OF A DOOR OR THE WORDS UP DOWN.
TURN THE DOWN ADJUSTMENT ABOUT 1/4 TURN AND TEST - DON'T OVER ADJUST YOU WANT THE DOOR TO CLOSE SOLID ON THE FLOOR
HOPE THIS HELPS
Posted on May 29, 2010
Liftmaster 1265 closes and then immediately opens garage door. Pulling chain release does not release chain. Only way to keep door closed is power shut-off; performing very rapid return when reaches...
There are two possibilities here. First is if the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure the sensors are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Second is if the door is reversing when it hits the floor. This is a problem with the door traveling too far in the down direction. Locate the 'down limit' located on the side of the motor unit and turn it a bit in the opposite direction of the arrow printed on the cover. Some tweaking may be necessary.
To release the door with the rope - pull straight down and then pull the rope in the direction away from the door. This should lock the mechanism in the open position. To release this pull straight down and release.
Sep 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not stay down when closed
Sounds like the down limit is out of adjustment. Turn the Down limit switch opposite the direction of the arrow a quarter turn and try again. Repeat until the door stops before hitting the floor then fine tune to shut off at the floor.
Aug 14, 2011 | liftmaster Garage Door 1/2 Hp
The bottom door is not closing right. I can slide
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
COLD GARAGE
Not all refrigerators are insulated the same and not all condensers are in the same place. Your cold control is monitoring the temperature of the refrigerator section and is designed to turn off the compressor to keep things from freezing in that section. If it stays cold long enough outside in your garage the cold control thinks its cold enough and won't turn the compressor on. A makeshift closet to hold a little heat the unit generates will probably help.
Jan 02, 2010 | Kenmore 64802 Top Freezer Refrigerator
Door closes hits the floor and reverses. It appears that the door has a sensor or something that causes the door to reverse once it hits the garage floor. What would cause this problem? The eyes are lined...
Garage doors have a setting that will do this. The door is traveling too far down and when it hits the floor, it thinks it is hitting something. There should be adustment knobs on the back of the unit to solve this. Good luck!
Nov 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
GARAGE DOOR CLOSES TO THE FLOOR AND OPENS ALL THE
If the garage door is hitting the floor and reversing to the open position you need to adjust the 'down limit' which is on the side of the motor unit. Turn it in the opposite direction of the arrow printed on the cover. A little tweaking should get it just right.
Aug 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door keeps running after it is shut
to tell you how to fix this is tricky your limit switch is not working, if it is a liftmaster, or sears craftsman take the cover down, if it is a older allistar it is a dog limit on the chain, if a genie check the cherry switch in back of operator behind cover.
Mar 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door closes and then automatically opens half way
ADJUST THE DOWN LIMIT IT THINKS THERE IS AN OBSTRUCTION AND IS REVERSING LIKE IT SHOULD.
TURN THE LIMIT ABOUT 1/4 TURN AT A TIME.
HOPE THIS HELPS
Mar 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
After opening, my automatic garage door creeps back down a bit
There is a sensitivity switch for both directions, open and close. If you access the garage door opener in the ceiling, you will see two adjustment screws for calibrating these. I would highly recommend following the instructions in your manual, as these are life safety adjustments! Your sensitivity for closing the door is adjusted to the positive. You just need to back it off a little. Place a 2x4 on the floor of the garage where the door comes down. and when the door hits the 2x4, it should automatically come back up. If not, you adjusted it too far. Hope this helps. and remember, check the manual for your specific adjustment procedures.
Mar 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door will not stay down when I try to close it.
IF THE DOOR CLOSES ALL THE WAY WHEN HOLDING DOWN THE WALL BUTTON AND REVERSES 6" FROM THE FLOOR WHEN NOT HOLDING THE BUTTON.
I WOULD GUESS THAT THE SAFETY EYES ARE MOUNTED ON THE TRACK.
WHEN THE DOOR CLOSES THE TRACK AT THE BOTTOM IS TOO TIGHT CAUSING IT TO FLEX AS THE DOOR GETS NEAR THE BOTTOM. WHEN THE TRACK FLEXES THE EYES ARE POINTING FURTHER AWAY FROM THE DOOR AND EVENTUALLY THEY ARE TOO FAR OUT OF ALINMENT AND THE LED WILL GO OFF - THE DOOR GOES BACK UP.
SOLUTION: YOU CAN USE THE CLAW END OF A HAMMER TO TAP THE TRACK OUT A LITTLE WIDER - TAP NEXT TO THE WALL ON THE BRACKET THAT HOLDS THE TRACK TO THE WALL. MOVE THEM ABOUT 1/4" EACH SIDE.
OR
YOU CAN MOUNT THE BRACKETS TO THE WALL OR THE FLOOR.
THIS SHOULD SOLVE IT
HAVE A GREAT DAY
Dec 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
Automatic Garage door reverses and automatically opens after closing
I can't believe it! My opener works fine a 10 degrees and above but below 10 degrees it would go down a little ways stop and go back with the light flashing. I checked the electric eye and found it would go out of alignment when the temp drop. Who knew!
I made the adjustment and it now works fine.
Jan 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
78 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
