Question about Garmin Nuvi 760 Handheld GPS Receiver
Charging I have a brand new garmin. I was curious why when I plug it up in the car using the adapter it is not charging?
    Scholar:
  • 91 Answers
1. please check if the charger socket in you car is working.
You could use other deivce like a MP3 player for charging in the same socket.
If other device is not charging then the problem could be with the socket.
Check the fuse associated with the car charger.output
2.Looks like Nuvi charger has a known lose contact issue.It would be advisable to let Garmin know the issue and they will send a new one.
Posted on Jan 03, 2009
I push the on/off button and nothing happens. (it is brand new and I am trying to acquire the satellite)
With the unit being brand new, the battery will require charging.
It is recommended to charge the battery for at least 4 hours before running it on the batteries alone.
Leaving it connected to the vehicle power cable while driving around will usually be enough to charge the unit after a day or so depending on how long the vehicle is running. Alternatively an AC power adapter can be purchased to keep the battery fully charged while away from the vehicle.
www.gpscity.com/garmin-nuvi-zumo-international-ac-adapter.html
Sep 22, 2011 | Garmin GPS
If my garmin is out of charge, how do recharge it from the computer?
I own a Garmin also, it can be charged two ways first through your computer and second through a adapter that plugs into your cigarette lighter in your vehicle. The USB connector you need is available through Garmin but they are kind of pricey and so is the cigarette adapter for your car. I usually buy these items on Ebay they are much cheaper on there.
I hope this helps you out if it does please leave me some feedback.
Mar 22, 2011 | Gomadic Flexible Car Windshield Holder...
How long does it take to charge my new Garmin gps in the car?
It shouldn't take too long maybe 15 to 20 minutes tops....
There is a fuse in the car cigarette adapter plug at the silver tip end of the unit, if it doesn't charge I would check the fuse
Be Careful the Silver tip end of plug is spring loaded
If you charged your gps by your computer using the USB port it takes a few hours
Nov 04, 2010 | Garmin nuvi 255W GPS Receiver
Battery
The unit will take a very slow charge via your computer. I tell most people no it doesnt charge VIA your PC just because it takes soooo long. I recommend getting a new power cable from GPSCity. Just call them up or follow the like to the cable you need.
** This cable is for the Nuvi 200 series GPS units
http://www.gpscity.ca/garmin-mini-usb-12v-cigarette-lighter-adapter-for-nuvi-in-web-packaging.html
Cheers
Jul 13, 2010 | Garmin nuvi 260W GPS Receiver
Can not charge only works plugged in
Your Garmin nuvi 5000 will never charge because it has NO internal battery. The only time it will operate is when it is plugged into a 12 volt power source. I have one and it really doesn't bother me at all. I bought a second cradle and a 12 volt adapter for use in the home.
May 19, 2009 | Garmin Nuvi 5000 GPS Receiver
Nuvi 260w no power.
Yes, you need to charge it. USE the charger that came with it for best results. Some off brand chargers will NOT work.
You plugged it into your car and nothing? Even if the batteries are bad it should still work. Is it the Garmin charger?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your unit will not charge in your vehicle, you may need to replace the fuse located in the tip of the vehicle power adapter.
  1. Unscrew and remove the silver or black, round end piece.
  1. Remove the fuse (glass and sliver cylinder) and replace with a new fuse.
  2. Ensure that the silver tip is placed in the end piece. Screw on the end piece.
Dec 26, 2008 | Garmin nuvi 260W GPS Receiver
Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 does not charge
I came here looking for solution and tried the "press eraser in bottom right corner and turn on" but didn't work for mine BUT if you look at the face plate (the part on the front that says "Garmin",) just under the word "Garmin" you see a small indent in the plastic, useing your finger nail, gently pull upwards and the face plate will come up. Also, be gentle while pulling the face plate being careful not to break it. ( I advise that you use your nail and not anythng that might scratch the plastic if you are intending on returning the unit, cause they may suggest that you tampered with it and that "voids the warrenty") Anyway, look at the USB plug (above the ON button on the side) and you see a tab, press it and the unit will reset.
Seems to me that with all the problems Garmin has had with their units freezing up that I should have found this solution on the garmin site! To think that there are people who will throw there unit away because of this problem OR who will pay 150.00 bucks to get it fixed through Garmin.
Jan 15, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin Nuvi 760 Handheld GPS Receiver Logo
145 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
