Question about Western Digital Passport 160GB External USB 2.0 Hard Drive - Black
Using the 160GB passportHard drive
I bought the Passport 160 GB external HD for my son. We used the USB to plug into the laptop. as he was trying to move his music to the HD. Now what do we do. No instruction came except a picture to connect with USB and then another picture that looked like a business letter.
I have never used before so can anyone walk me through the steps?
  • annesane Dec 29, 2008
    I dont know hwere to begin. I plug in the USB then what.
  • annesane Jan 13, 2009
    will the songs then be listed the same way or will he have to rename everything etc. That is his fear.
    Problem Solver:
  • 15 Answers
Are there any errors that popped up while copying the music files? if not, then it probably works fine. the files are now stored on the harddrive.
if you want to safely unplug and carry the HD over to another computer, you can., the files should be accessible... that's all a harddive does.
Posted on Dec 29, 2008
  • ironman123
    ironman123 Dec 29, 2008
    wait, so your son did not actually move his music to the HD? ok, when you plug it in, your computer should autodetect it.
    *open My Computer
    *plug in the HD
    *double click the new icon that pops up
    *find your son's music folder
    *right-click+drag it to the harddrive, an option that says "move" should pop up. select that.
    *wait while it moves that files.
    **this will probably cause windows media player to lose track of where the files are and the songs will disappear from the media player library. this is easily fixed, comment for a guide on how to do this if you find this to be a problem.
    *normally, whern you want to COPY and not MOVE from _another_ drive, you just click and drag, however, if you click and drag _within the same harddrive_ the files are moved.
I tried to format my 500gb WD passport essential with exfat using windows 7 for my mediastar pvr . Now neither pvr or windows 7 can see the harddrive
Windows 7 does _NOT_ support 'exfat' drives, as you have found out.
You can "format" the drive, to use 'FAT32' or 'NTFS' file-systems.
Dec 27, 2010 | Western Digital My Passport Essential...
some proble was in USB socket of your external HDD...poor contact...
try to use another HDD enclosure to use with you HDD..
that problem occur due to pluging in and out several times...maybe the connector was damaged...hope it helps..
or try another PC again...some problems are not detected due to virus in PC...
May 25, 2010 | Western Digital Passport WDXML800UE...
I have a maxtor III usb 2.0 500 GB external hard drive. the light on the front goes out and works sometimes. when the light goes out the external drive gets disconnected . i checked for loose connections....
Possibly, the USB is not receiving current enough and occasionally it resets the USB interface. Try connecting it to another system, or to a powered USB host, and see what happens.
Another possibility (but you'd need to disassemble the external enclosure and connect directly the disk inside to a SMART-capable motherboard) is that the hard disk is developing a fault.
Apr 15, 2010 | Maxtor 160GB OneTouch III Mini USB 2.0...
Internal hard drive
They do make cases that you can buy to turn an internal HD into an external. Best Buy I think sells them.
Dec 19, 2009 | Seagate 160GB 3.5" External USB Drive 160...
Need drivers
Below is the link for the FireLite 160GB portable HD. Drivers are only needed for win98. 2000/xp/vista are plug and play. The manuals are included at this link.
Additionally, there could be a problem with power supply. A switch is on the back...USB or EXT. EXT is for an external supply. ( USB is naturally for a USB cable. Clicking might indicate low power when using USB. Switch to the external adapter or get a USB cable with two connectors for the computer (the extral cable draws more power),
good luck.
Jul 10, 2009 | Verbatim 160GB USB FireLite: The "drive...
WD Passport Essential 160gb with PowerBook G4
The problem is that your powerbook G4 does not provide enough power to your 160gb passport HD. This does not happens to the new Macs with intel inside.
There are several ways to fix it:
1) Go to West Digital Website and buy a "Power Buster Cable USB" (that connect your 2 USB ports to your passport HD in order to provide more power). I think that it costs 10$. This is the link:
2) The other solution is easier. If you have an external USB hard drive with two USB ports, or a DVD/CD burner with two usb ports, you can pug your passport in one of the ports while the other HD or DVD/CD burner is connected to you PowerBook. You will be able to see and use your q60gb Passport HD.
Oct 21, 2008 | Western Digital Passport WDXML800UE...
HDD from dropped laptop
Could it be a power issue? Some older laptop HDs need more power than one USB port can provide and won't spin up properly. If you have a cable with your HD enclosure which had two USB connectors on the end, make sure you plug both into ports on your laptop.
When they don't spin up correctly, you tend to hear them clicking as they try to spin & then cut out. Have a listen to it when you plug it in & see what you can hear.
Sep 01, 2008 | Seagate 160GB 3.5" External USB Drive 160...
Usb seagate 160 gb hard disk
Your hard-drive is crashed and unreadable by win32.dll what you can do is try kick starting by using your friend computer it just might do it. I had same problem and I asked my son to using my hard-drive on his PC. It worked and still working. good luck
Jul 26, 2008 | Seagate 160GB 3.5" External USB Drive 160...
160 gb hard disk
Some of its space is use for table allocation or indexing .
Apr 16, 2008 | Maxtor 160GB OneTouch III Mini USB 2.0...
Western Digital Passport 160GB External USB 2.0 Hard Drive - Black Logo
209 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
