Question about Onkyo TX-SR705 Receiver
Onkyo 805 : Display not on, but everything else works.
I have an Onkyo 805 receiver and it has worked great for the last 6 months. However, yesterday I powered it on with the same Harmony remote that I have always used, and the display on the unit did not turn on. However, the sound still comes through fine. I noticed this when playing ps3 using HDMI, xbox360 using HDMI.
Obviously this causes me great concern, but I'm hoping there is someone who knows about these things and can set me on the path to a resolution.
Thank you for you time and your technical prowess on this!!
  • Anonymous Apr 25, 2009
    I have an Onkyo 805 display screen suddendly not function at all.
    I felt disappointed with this product because i just bought it for 1 year plug. This product not doing well and simply release to market.
    Luckily i found 1 solution here, after i change 10ohm 1W resistor.
    My av receiver display screen function at normal condition.
    Need special thanks to Kerby2000 and Cambrian.
    kerby2000
    Rank: Apprentice
    Rating: 100%, 1 votes
    Finally one of us found the solution - thanks to cambrian
    Please follow the link
    http://www.avsforum.com/avs-vb/showthrea...
  • Anonymous Apr 29, 2009
    I had the same problem. i replace the two resistors and my display came on but it is displaying random numbers. hard to explain, but it constantly runs through 0's and the letters pth-00000000. I read somewhere else that sometimes a diode zenor may need to be replaced. Anyone know anything on this?
http://www.avsforum.com/avs-vb/showthread.php?t=857502&page=579
BTW: My knowledge of electronics is very limited, but nevertheless I could fix the problem. I hope you can do it too.
Posted on Mar 12, 2009
  • 24 Answers
The good news is that this is a common problem and can probably be fixed with some replacement lamps from Radio Shack. The bad news (you just knew it was coming...) is that the lamps are usually a pain to replace. Remove the top of the case and there should be a plastic cover over the area of the display. It may just snap off by pressing on some tabs. Inside there will be some small light bulbs that are the backlight for the display. If they burn out, it can't be seen unless you shine a bright light in through the front of the display. Carefully unsolder the bulbs and take one to Radio Shack. Look for a 12v bulb of approximately the same size. If you can't find one, buy one of the 12v bulbs with the red or green plastic panel mounts and remove the lamp from its case. Solder in the new lamps and you're good to go!
Posted on Dec 29, 2008
I have a onkyo tx-sr507 and it works great the only problem is the setup feature for the unit doesn't show up on my tv it only shows up on my receiver can anyone help me figure this out my cousin has...
A simple composite video connection from its Monitor Out to the appropriately-selected input on your TV may resolve that.
Or, from the manual...
"While the Pure Audio listening mode is selected, the video circuitry is turned off and only the HDMI OUT outputs video signals."
Jul 12, 2011 | Onkyo Tx-sr507 A/V Receiver
No sound with the tx-sr606
This is a problem of DSP. If enter service mode,
You will see a picture like this. You can do nothing
Except selling this amp cheaply. This DSP ??????
Causes NO SOUND in all channels. Besides, never
Buy 2nd hand onkyo from 5/6/7/805 to 5/6/7/848 Series amps. You will suffer the consequences!!!!
Feb 13, 2018 | Onkyo TX-SR606 Receiver
Bose 901 hookup with Onkyo SR 805 and Onkyo M282 amp and 901 EQ/
The good news. I have a setup similar to what I think you're trying to do and it works great!
The Onkyo M-282 stereo amp for the 901's is the perfect solution. Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
**Onkyo SR805 Pre-Out Front >>> Bose EQ Amplifer IN
Bose EQ Amplier OUT >>> Onkyo M-282 IN
Set the Input Level on the back of the Onkyo to MAX. The receiver controls everything just fine after you run through your level setup routine again.
I was looking a the 12v triggers on both units and it looks like you only have a Zone 2 trigger so that wouldn't work for turning on your M-282. I guess you're going to have to turn it on and off the old fashioned way, like I do mine.
Mar 15, 2009 | Onkyo TX-SR705 Receiver
Hi I have an Onkyo TX-SR875. The AV receiver display panel has gone, so I reset it to factory defaults to see if it would bring it back - it didn't. Worse can't now see the on-screen setup menu to setup...
This is a common problem on onkyo receivers like the 805, 875 etc. The front panel display board has 2 faulty resistors(marked 9304 & 9310) which can blow out easily. Replacing them with some very basic soldering, resolved the issue for me.
View this link on the AVS forum for detailed instructions .
Look for the post titled "805 Display fix"
http://www.avsforum.com/avs-vb/showthread.php?t=857502&page=578
Dec 06, 2008 | Onkyo TX-SR875 Receiver
Onkyo AV Receiver TX-SR 805 no display on the receiver
Nov 24, 2008 | Audio Players & Recorders
I have Onkyo R 330 HTS, and I recently moved my apartment and did not use it for last 6 months. When I plugged in the power yesterday (finally), none of the controls are working. The display comes up, but...
Hello, I am sorry about your issue. I am afraid that your receiver may need to be serviced. I suggest that you contact Onkyo at 800-229-1687 option #3 so that we can provide your options. Thank you, Onkyo USA
Jun 30, 2017 | Onkyo Audio Players & Recorders
ONKYO TX-SR805 Display screen does not light up.
Resetting the unit MAY work, however you will reset everything to factory and have to set it all up again. If resetting does not work, sounds like you will be looking for your local, friendly rrepair shop. Onkyo carries a two year warranty on these units, hopefully yours is still under. If not I would contact ONKYO directly because it seems they have had A LOT of problems with the screen on the 805 and 875 models
Sep 30, 2008 | Audio Players & Recorders
Onkyo TX-SR805 - surround sound problem
The speaker impedance is not the problem.
Apr 09, 2017 | Onkyo TX-SR803 Receiver
No video through HDMI section of Onkyo TX SR-805 receiver
My has problems with losing video on HDMI, component, or svideo, this is a piece of you know what!
Jul 03, 2008 | Televison & Video
I have a Onkyo 805 Receiver that while I was listening to DVD Video in DTS Mode the sound stopped and the TV went to input. I noticed the Display on the Receiver said E2PROM ERROR. Now I can't get anything...
WILL TRY TO GET A SOLUTION FOR YOU IN MORNING CALL ME ON 02870342354 LARRY. I HAVE NOT SEEN THIS ERROR BEFOR AND I SELL ONKYO IN THE SHOP I WORK IN,(LIGHTING,SOUND,AND VISION) IN NORTHERN IRELAND OR EMAIL ME AT LSVNI@YAHOO.CO.UK
RICKY.
Jun 19, 2008 | Onkyo Audio Players & Recorders
Onkyo TX-SR705 Receiver Logo
1,192 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
